Diff Baffles
Revision as of 08:09, 18 December 2009; view current revision
Categories: Rear Axle And Rear Suspension | Racing
The rear axle housing may be fitted with axle baffles. They are designed to contain the differential oil in the center section.
Datsun Competition H145 Axle baffles
These baffles can be installed in any Datsun equipped with an H145 rear axle assy.
  • 43015-25720 AXLE BAFFLE/RH
  • 43016-25720 AXLE BAFFLE/lH
Datsun Competition axle baffles welded into the housing
RS240 Setup
At the rear there are two plugs fitted. The top plug is for checking oil level and the second for fitting an oil pickup for the diff oil cooler pump. The return from the cooler sprays directly onto the pinion gera to cool it.
