Nissan Engineering Section (N.E.S.) specified six- to nine-digit Part Number formats for bolts and screws and other small hardware. During the 1970s these numbers were replaced by regular 10 digit Nissan Part Numbers.
Also See: Nissan Part Numbers
NES hardware parts originally used a six-digit format:
Type + Kind + dimensions (d) + length (L)
t-kddLL or t-kkdLL e.g: 1-10612
Around 1968, the digit '8' was added to the beginning:
81-10612
Finally in the early 1970s they transformed into Nissan standard 10 digit numbers, by adding a 0 to the beginning and two numbers to the end:
08110-612xx
Example:
- 81-10612 BOLT, fixing timing chain tensioner support [B10 model]
- Part: 81: Hexagon bolt
- Kind: 1= Low carbon steel
- Dimension: 06=6mm diameter thread
- Length: 12=12mm
Example:
- 9-16114 WASHER-lock to fix timing chain tensioner [410 model]
- New number would be 89-16114
- Part-Kind: 9-16: Washer, Tooth-lock
- Shape & material: 1=Spring-lock medium thickness
- Dimension: 14=14mm
Example: B10 steering column cover screw
- 83-30414-1
- 33= Machine screw, Oval head
- 04= 4mm diameter
- 14= 14mm length
- 1= Zinc cadmium coated
Example: B110 steering column cover screw
- 08330-41410
- 33=Machine screw, Oval head
- 04= 4mm diameter
- 14= 14mm length
- 0= filler to complete ten digits
Kind
1- Bolts
- 11ddLL: Hexagon bolt, Low carbon steel
- 12ddLL: Hexagon bolt, Medium carbon steel
- 13ddLL: Hexagon bolt, Alloy steel
- 81-4ddLL:
- 81-5ddLL:
- 81-6ddLL:
- 17dLLL: Carriage bolt, Round head
- 18dLLL: Carriage bolt, Flat head
- 19dLLL: Carriage bolt, Step
2- Studs
- 21ddLL: Stud, Low carbon steel (for cast iron)
- 22ddLL: Stud, Medium carbon steel (for cast iron)
- 23ddLL: Stud, Low carbon steel (for light alloy)
- 24ddLL: Stud, Medium carbon steel (for light alloy)
- 82-5ddLL:
- 82-6ddLL:
3- Machine Screws
- 31ddLL: Machine screw, Pan head
- 32ddLL: Machine screw, Flat head
- 33ddLL: Machine screw, Oval head
- 34ddLL: Machine screw, Truss head
- 35ddLL: Machine screw, Blind head
- 36ddLL: Machine screw, Hexagon head
84- Pointed Machine Screw
- 84-1ddLL: Pan head
- 84-2ddLL: Flat head
- 84-3ddLL: Oval head
- 84-4ddLL: Truss head
- 84-5ddLL: Blind head
- 84-6ddLL: Hex head
5- Other Screws
- 51ddLL: Tapping screw, Pan head
- 52ddLL: Tapping screw, Flat head
- 53ddLL: Tapping screw, Oval head
- 54ddLL: Tapping screw, Truss head
- 57dLL: Wood screw, Round head
- 58dLL: Wood screw, Flat countersunk head
- 59dLL: Wood screw, Oval head
- a) pan, b) button, c) round, d) truss, e) countersunk, f) oval
6- Rivets
- 61ddLL: Rivet, Round head
- 62ddLL: Rivet, Flat countersunk head
- 63ddLL: Rivet, Flat head
- 66ddLL: Rivet, Tubular flat head
- 67ddLL: Rivet, Tubular flat countersunk head
- 68ddLL: Rivet, Split oval head
87-11 Flared Nuts
- 87-111dd Inpe-ted
- 87-112dd Standard
87-12 Connectors
- 87-121dd Straight
- 87-122dd Elbow
- 87-123dd Elbow
87-2 Hose Clamps
- 87-211dd: A
- 87-211dd: B
87-31 Clevis
- 87-311dd: A?
- 87-312dd: B?
- 87-313dd: ???
9-11 Hex Nuts
- 9111dd: Hexagon nut, low carbon steel
- 9112dd: Hexagon nut, medium carbon steel
- 9113dd: Hexagon nut, Low, low carbon steel
- 9115dd: Hexagon nut, High, low carbon steel
- 9116dd: Hexagon nut, High, medium carbon steel
- 9117dd: Hexagon nut, Recess, high, low carbon steel
- 9118dd: Hexagon nut, Recess, high, medium carbon steel
- 9119dd: Hexagon nut, Recess, low, low carbon steel
- 9110dd: Hexagon nut, Recess, low, high carbon steel
9-12 Lock Nuts
Self-locking nut (stopper nut)
- 89-121dd: ???
- 89-122dd: ???
- 9123dd: Self-locking hexagon nut, N, low carbon steel
- 9124dd: Self-locking hexagon nut, N, medium carbon steel
- 9125dd: Self-locking hexagon nut, low, low carbon steel
- 9126dd: Self-locking hexagon nut, low, medium carbon steel
- 89-127dd: ???
- 89-128dd: ???
9-13 Square & Wing Nuts
- 9131dd: Nut, Square
- 9134dd: Nut, Wing (forged)
- 9135dd: Nut, Wing (sheet)
89-14 Hex Weld Nuts, Tapping Discs, Plate Nuts
- 89-141dd: ?
- 89-142dd: ?
- 89-143dd: Tapping Disc A?
- 89-144dd: Tapping Disc B?
- 89-145dd: Plate
9-15 Washers
- 9151dd: Washer, Sring lock medium
- 9152dd: Washer, Sring lock thick
- 9154dd: Washer, Plain standard
- 9155dd: Washer, Plain large
- 9158dd: Washer, Finish
9-16 Tooth-lock Washers
Tooth Lock washer (shakeproof)
- 9161dd: Washer, toothed inside ratchet (outside dia. msall)
- 9162dd: Washer, toothed inside ratchet (outside dia. large)
- 9163dd: Washer, toothed outside ratchet
- 9164dd: Washer, toothed 80° countersunk
- 9165dd: Washer, toothed 90° countersunk
- 89-166dd: Washer, ???
- 89-167dd: Washer, ???
- 9168dd: Washer, toothed both side ratchet
9-17, 89-19 Nut Retainers
- 9-171dd/89-191dd: Nut retainer, Both shanks round hole
- 9-172dd/89-192dd: Nut retainer, One shank round hole
- 9-173dd/89-193dd: Nut retainer, Both shanks long hole
- 9-174dd/89-1914dd: Nut retainer, One shank long hole
- 89-195dd: ????
9-2 Pin & Key
- 921dLL: Cotter pin
- 6 Semicircular key
- 8 Parallel key
9-31 Thread Plugs
- 9311dd: Plug, threaded, square head taper thread
- 9312dd: Plug, threaded, square hole taper thread
- 9312dd: Plug, threaded, recessed taper thread
- 9313dd: Plug, threaded, hex head taper thread
- 9314dd: Plug, threaded, hex head parallel thread
9-32 Grease Nipples
- 9321dd: Grease nipple, Straight
- 9322dd: Grease nipple, 67.5°
- 9323dd: Grease nipple, 90°
9-4 Electric Parts
- 94*1dd: Electric parts
9-5 Rubber Parts
- 95*1dd: Rubber Grommet
89-6 Spring Nuts
- 89-631dd: A1 type
- 89-632dd: A2 type
- 89-641dd: B type
- 89-651dd: C type
- 89-661dd: D1 type
- 89-662dd: D2 type
- 89-663dd: D3 type
- 89-664dd: D1 type
89-61 Push-on Spring Nuts
- 89-611dd: A1 type
- 89-612dd: A1 type
- 89-613dd: B type
- 89-614dd: C type
Dimension Digits
Distinction by alias dimension of diameter and width. Each number may be either a size, inch dimension or metric dimension.
- 01: #1, 1/16", 1mm
- 02: #2, , 2mm
- 03: #3, 3/32", 3mm
- 04: #4, 7/64", 4mm
- 05: #5, 1/8", 5mm
- 06: #6, n/64", 6mm
- 08: #8, 5/32", 8mm
- 09: ,,9m
- 10: #10, 3/16", 10mm
- 12: #12, 7/32", 12mm
- 13: ,, 13mm
- 14: #14, 1/4", 14mm
- 15: ,5/16", 15mm
- 16: #16, 3/8", 16mm
- 17: ,7/16", 17mm
- 18: ,1/2", 18mm
- 19:, 9/16",
- 20:, 5/8", 20mm
- 22: ,3/4",
- 24: ,7/8",
- 26: ,1",
- 28: ,1-5/8",
Also add 30, 60, or 50 to above.
Length Digits
LL as shown above:
- 07: 1/4 inch
- 10: 3/8
- 13: 1/2
- 16: 5/8
- 19: 3/4
- 22: 7/8
- 26: 1 inch
- 28: 1-1/8
- 32: 1-1/4
- 35: 1-3/8
- 38: 1-1/2
- 41: 1-5/8
- 44: 1-3/4
- 48: 1-7/8
- 51: 2 inch
- 54: 2-1/8
- 57: 2-1/4
- 64: 2-1/2
- 70: 2-3/4
- 76: 3 inch
Suffix
For parts that have surface finishing or cotter pin hole, symbols showing these proceedings are added at the end of the part number.
Two digits mean it has a cotter pin hole. Single digit: No cotter pin hole.
- 1: Zinc cadmium coated
- 2: Chrome coated
- 3: Copper coated
- 4: Phosphoric acid coated
- 5: Brass
- 6: Copper
With Cotter Pin Hole
- 10: surface not processed
- 11: Zinc cadmium coated
- 21: Chrome coated
- 31: Copper coated
- 41: Phosphoric acid coated
- 51: Brass
- 61: Copper
