Raw List 2
Revision as of 03:47, 2 January 2010; view current revision
16009-H7010	KIT-REPAIR B,CARBURETOR
16009-H3910	KIT-REPAIR B, CARBURETOR
16500-H3901	ASSY-CLEANER,AIR
16500-H7000	ASSY-CLEANER,AIR
16500-H3900	ASSY-CLEANER,AIR
01237-00011	NUT-WING
16551-08000	NUT-WING
16510-H3900	ASSY-MOTOR,VACUUM
16580-01B01	ASSY-SENSOR,TEMPERATURE
16580-H3900	ASSY-SENSOR,TEMPERATURE
16582-H3900	CLAMP-SENSOR & TUBE
22318-C0601	TUBE-VACUUM MOTOR TO TUBE L=200
22318-C0601	TUBE-VACUUM CONTROL L=320
16573-H1001	SUPPORT-AIR CLEANER
16574-H1001	SUPPORT-AIR CLEANER,FRONT
08120-61210	BOLT
08915-13610	WASHER-LOCK
08915-43610	WASHER-PLAIN
08915-53610	WASHER-PLAIN
16530-B3901	DUCT-COVER TO AIR CLEANER
08723-14400	CLAMP-DUCT
16590-H3900	ASSY-COVER,EXHAUST MANIFOLD
08190-81210	BOLT
08915-43810	WASHER-PLAIN
08915-13810	WASHER-LOCK
14896-25600	BAND-HOSE
14875-H1900	CONNECTOR-VACUUM
17201-H1902	ASSY-TANK FUEL 40L
17201-H2800	ASSY-TANK FUEL 40L
17201-H1901	ASSY-TANK FUEL 40L
17342-18000	RING-O
17343-H1001	PLATE-LOCK
17343-14801	PLATE-LOCK
25060-H1900	GAUGE-FUEL TANK
17312-14800	PACKING-DRAIN
17312-H1000	PACKING-DRAIN
17312-P0101	PACKING-DRAIN
17312-P0102	PACKING-DRAIN
08931-44210	PLUG
17310-H1000	PLUG-DRAIN
17310-P0100	PLUG-DRAIN
17251-H1900	CAP-FILLER
17251-H1000	CAP-FILLER
17251-H1901	CAP-FILLER
17251-H1902	CAP-FILLER
17264-18000	PACKING
17220-H1901	TUBE-FILLER UPPER
17222-H1000	NECK-FILLER
17221-H1000	PACKING FILLER NECK
08310-40812	SCREW
17229-H1900	HOSE-FILLER
08723-15800	CLAMP-HOSE
08360-82014	BOLT WITH LOCK WASHER
08915-53810	WASHER-PLAIN
17314-H1000	GROMMET
17350-H1900	ASSY-TANK RESERVOIR
17351-H1900	CONNECTOR-3 WAY
17351-H1901	CONNECTOR-3 WAY
17352-H1901	SEPARATOR
17352-H1902	SEPARATOR
A8742-20040	HOSE-FUEL RUBBER (10X17X2.2M)
08742-20040	HOSE-FUEL RUBBER (10X17X2.2M)
A7515-H1900	HOSE-FUEL RUBBER(10X16DX5M)
A7515-H1800	HOSE-FUEL RUBBER(6X13.5X5M)
08742-20020	HOSE-FUEL RUBBER (6X13.5X2.2M
08723-11400	CLAMP-HOSE 1
16439-22100	CLAMP-HOSE 1
17230-H1900	HOSE-FILLER 2ND
17230-H1901	HOSE-FILLER INNER
08723-13600	CLAMP-HOSE
17361-H1922	TUBE-EVAPO
17361-H1902	TUBE-EVAPO
17361-H1903	TUBE-EVAPO
17201-H1802	ASSY-TANK FUEL 38L
17342-18000	RING-"O"
25060-H1800	GAUGE-FUEL TANK
08931-44210	PLUG-DRAIN
17264-18000	PACKING
17220-H1802	HOSE-FILLER UPPER
17220-H1803	HOSE-FILLER UPPER
08310-40812	SCREW-MACHIN
17229-H1802	HOSE-FILLER
17228-H1400	GROMMET
17230-H1802	HOSE-FILLER INNER
17230-H1801	HOSE-FILLER 2ND(NOT ADOPTED)
A7325-H1000	TUBE-VINYLE(10X14DX5M)
A7515-H1900	TUBE-RUBBER(10X16DX5M)
08742-20040	TUBE-RUBBER
17324-H1800	GROMMET
08110-82062	BOLT WITH LOCK WASHER
17350-H1801	ASSY-TANK RESERVOIR
17350-H1802	ASSY-TANK RESERVOIR
63140-78500	NUT-JAM
08410-61610	SCREW
17335-H1801	TUBE-BREATHER RH
17335-H1802	CONNECTOR
17336-H1801	TUBE-BREATHER LH
17515-H1817	HOSE-FUEL FIX FUEL TANK TO EVAPO TANK(L
A7515-H1800	HOSE-FUEL(6X13.5X5M)
08742-20020	HOSE-FUEL(6X13.5X2200MM)
A7515-H1800	HOSE-FUEL(6X13.5X10M)
08742-20020	HOSE-FUEL (6X13.5X2.2M)
17351-H1800	CONNECTOR-3 WAY
17351-H1801	CONNECTOR-3WAY
17361-H1800	TUBE-EVAPORATION
17361-H1801	TUBE-EVAPORATION
24251-H1801	GROMMET
00951-10600	GROMMET
00951-11000	GROMMET
00951-11200	GROMMET
46115-C0400	GROMMET
17337-H1800	PROTECTOR-FUEL HOSE
24210-89964	CLIP
74890-H1800	PROTECTOR-FILLER HOSE
08110-62010	BOLT FIXING PROTECTOR
08915-23610	WASHER FIXING PROTECTOR
08915-43610	WASHER FIXING PROTECTOR
22100-H1001	ASSY-DISTRIBUTOR(HITACHI)
22167-H2300	SET-CAP CLAMP
22108-H2300	ASSY-SHAFT
22108-H2301	ASSY-SHAFT
22109-71300	WEIGHT-GOVERNOR
22110-H1000	SPRING-GOVERNOR SET
22132-21005	ASSY-CAM
22132-22005	ASSY-CAM
22119-18000	SET-PINION
22136-H2300	ASSY-BRAKER
22145-18005	SET-CONTACT
22182-71300	WIRE-EATH
22183-71300	WIRE-LEAD
22403-18005	ASSY-TERMINAL
22157-78500	ROTOR-HEAD
22157-H1000	ROTOR-HEAD
22162-21007	ASSY-CAP
22165-30101	POINT-CARBON
22301-H1000	ASSY-CONTROL VACUUM
22102-00801	CONDENSER
22248-A5502	SEAL-DUST
22750-H2300	SET-SCREW
22180-71200	RING-"0"DISTRIBUTOR SUPPORT
08110-61210	BOLT-HEX FIXING DISTRIBUTOR TO BLOCK
08915-13610	WASHER-LOCK FIXING DISTRIBUTOR
08915-43610	WASHER-PLAIN FIXING DISTRIBUTOR
22318-18000	TUBE-DISTRIBUTOR VACUUM ADVANCE
B2318-73002	TUBE-DISTRIBUTOR VACUUM ADVANCE(5M)
22328-H1000	CLAMP-TUBE VACUUM CONTROL
22328-H1001	CLAMP-TUBE VACUUM CONTROL
22328-H1002	CLAMP-TUBE VACUUM CONTROL
22450-18228	SET-CABLE HIGH TENSION
22450-H1025	SET-CABLE,HIGH TENSION
22450-18201	CABLE-HIGH TENSION COIL TO DISTRIBUTOR
22450-18202	CABLE-HIGH TENSION COIL TO DISTRIBUTOR
22451-18200	CABLE-HIGH TENSION NO.1
22451-18201	CABLE-HIGH TENSION NO.1
22452-18201	CABLE-HIGH TENSION NO.2
22452-18200	CABLE-HIGH TENSION NO.2
22453-18201	CABLE-HIGH TENSION NO.3
22453-18200	CABLE-HIGH TENSION NO.3
22454-18200	CABLE-HIGH TENSION NO.4
22454-18201	CABLE-HIGH TENSION NO.4
22433-14806	COIL-IGNITION(HITACHI)
22433-14606	COIL-IGNITION(HITACHI)
22433-A5400	COIL-IGNITION (HITACHI)
22433-U2000	COIL-IGNITION (HITACHI)
22433-14816	COIL-IGNITION(HANSHIN)
22433-14616	COIL-IGNITION(HANSHIN)
22433-A5410	COIL-IGNITION (HANSHIN)
22433-U2010	COIL-IGNITION (HANSHIN)
22460-14606	RESISTER-IGNITION COIL (HITACHI)
22460-U2210	RESISTER-IGNITION COIL (HANSIN)
22460-U2200	RESISTER-IGNITION COIL (HITACHI)
22460-14615	RESISTER-IGNITION COIL (HANSHIN)
08513-61212	SCREW-MACHINE M6 IGNITION COIL TO BODY
08915-53610	WASHER-PLAIN M6 IGNITION COIL TO BODY
22401-A4804	PLUG-SPARK L44PW(HITACHI)
22401-A4617	PLUG-SPARK
22401-75507	PLUG-SPARK BP-7E(N.G.K)
22401-75500	PLUG-SPARK BP-6E(N.G.K)
22401-75504	PLUG-SPARK BP-4E(N.G.K)
22401-A4707	PLUG-SPARK L47PW(HITACHI)
22401-21007	PLUG-SPARK L47P(HITACHI)
22401-21005	PLUG-SPARK L45P(HITACHI)
22401-A4704	PLUG-SPARK L47PW(HITACHI)
22401-21004	PLUG-SPARK L44P(HITACHI)
22401-A4706	PLUG-SPARK L46PW(HITACHI)
22401-A4705	PLUG-SPARK L45PW(HITACHI)
22401-21000	PLUG-SPARK L46P(HITACHI)
22401-A4605	PLUG-SPARK BP-5ES(N.G.K)
22401-A4616	PLUG-SPARK BP-6ES(N.G.K)
11710-H0100	BRACKET-ALTERNATOR
08131-02210	BOLT-HEX M10 FIXING ALTERNATOR B
08915-14010	WASHER-SPRING M10 FIXING ALTERNATOR B
08130-83010	BOLT-HEX M8 ALTERNATOR FIXING
08911-20810	NUT-HEX M8 ALTERNATOR FIXING
08915-43810	WASHER-PLAIN M8 ALTERNATOR FIXING
08915-13810	WASHER-SPRING ALTERNATOR FIXING
11715-18001	BAR-ADJUSTING ALTERNATOR
11715-H2300	BAR-ADJUSTING ALTERNATOR
11715-M0100	BAR-ADJUSTING ALTERNATOR
08110-81610	BOLT-HEX M8 BAR FIXING
22401-A4725	SET-IGNITION(HITACHI)
22401-A4706	PLUG-SPARK(L46-PW)
23300-H6900	MOTOR-STARTER (HITACHI S11
23300-H0100	MOTOR-STARTER (HITACHI S11
23300-H0101	MOTOR-STARTER (HITACHI S11
23300-H5000	MOTOR-STARTER (HITACHI S11
23300-H3900	MOTOR-STARTER (HITACHI S11
23310-H3900	ASSY-ARMATURE
23310-19900	ASSY-ARMATURE
23321-09900	WASHER-THRUST
23312-10600	ASSY-PINION
23312-10605	ASSY-PINION
23312-E3000	ASSY-PINION
23465-E6800	SET-STOPPER PINION
23383-10600	ASSY-BEARING CENTER
23441-10600	METAL-CENTER BEARING
23306-15801	ASSY-COIL FIELD
23306-M0100	ASSY-COIL FIELD
23305-09500	SCREW-POLE,CORE
23337-18005	ASSY-COVER REAR
23337-H0100	ASSY-COVER,REAR
23337-10605	ASSY-COVER,REAR
23338-09900	METAL-COVER REAR
23380-19900	BRUSH (+)
23380-10600	BRUSH (+)
23379-19900	BRUSH (-)
23379-09900	BRUSH (-)
23333-09900	SPRING-BRUSH
23333-21001	SPRING-BRUSH
23340-15805	BOLT-THROUGH
23340-18005	BOLT-THROUGH
23318-H0100	ASSY-GEAR CASE
23319-10600	METAL-GEAR CASE
23322-M0100	SET-LEVER SHIFT
23309-H5000	ASSY-COVER BRUSH
23309-18005	ASSY-COVER BRUSH
23309-19905	ASSY-COVER BRUSH
23343-18005	ASSY-SWITCH MAGNETIC
23470-M0100	SET-DUST COVER
23390-18005	BOLT M5
23480-M0100	SET-SCREW
24012-H7000	HARNESS-ENGINE ROOM
24012-H7005	HARNESS-ENGINE ROOM
24012-H2112	HARNESS-ENGINE ROOM
24012-H2111	HARNESS-ENGINE ROOM
24012-H7001	HARNESS-ENGINE ROOM
24012-H2102	HARNESS-ENGINE ROOM
24012-H2101	HARNESS-ENGINE ROOM
24012-H2108	HARNESS-ENGINE ROOM
24012-H1900	HARNESS-ENGINE ROOM
24012-H2118	HARNESS-ENGINE ROOM
24013-H1905	HARNESS-INSTRUMENT
24013-H2118	HARNESS-INSTRUMENT
24013-H2112	HARNESS-INSTRUMENT
24013-H7000	HARNESS-INSTRUMENT
24014-H1011	HARNESS-BODY
24014-H1811	HARNESS-BODY
24015-H1900	HARNESS-TAIL
24015-H7000	HARNESS-TAIL
24015-H1910	HARNESS-TAIL
24272-H1000	PROTECTOR-WIRING
24039-H1900	ASSY-CABLE HAND BRAKE SWITCH
24150-H1020	ASSY-CABLE INDICATOR LAMP
24250-89927	GROMMET
24029-H1400	CABLE-TANK UNIT
24220-89937	CLIP FIXING TO BODY SIDE INNER
24220-89953	CLIP FIXING TO REAR COMB LAMP
25442-H1100	LINK-FUSIBLE,TYPE C
25442-H2500	LINK-FUSIBLE,TYPE C
24110-H1600	CABLE-BATTERY(+)
24110-H1605	CABLE-BATTERY (+)
24110-H1900	CABLE-BATTERY(+)
24080-H1900	CABLE-BATTERY(-)
24160-H1100	CABLE-ROOM LAMP
24100-H1600	CABLE-FOG LAMP
24163-H1900	CABLE-HEAT GLASS D
24220-89931	CLIP-CABLE
24161-H2200	CABLE-HEAT GLASS A
24161-H1900	CABLE-HEAT GLASS,A
24162-H2200	CABLE-HEAT GLASS B
24163-H2200	CABLE-HEAT GLASS C
24163-H2000	CABLE-HEAT GLASS
24338-H4600	CABLE-SEAT BELT WARNING
24338-H7005	CABLE-SEAT BELT WARNING
25160-H1010	COMP-SWITCH LIGHTING WITH FOG SWI
25160-H4600	COMP-SWITCH LIGHTING
B5160-B6800 	COMP-SWITCH LIGHTING
25160-H1001	COMP-SWITCH LIGHTING
25165-H1000	KNOB-LIGHTING SWITCH
25165-H4600	KNOB-LIGHTING SWITCH
25165-T3000	KNOB-LIGHTING SWITCH
25199-H1000	SPRING-SWITCH KNOB
25260-H1001	COMP-SWITCH WIPER
25260-H4600	COMP-SWITCH WIPER
25260-H7000	COMP-SWITCH WIPER
25260-H7001	COMP-SWITCH WIPER
25265-H1000	KNOB-WIPER SWITCH
25265-H4600	KNOB-WIPER SWITCH
25265-H7000	KNOB-WIPER SWITCH
25265-H7001	KNOB-WIPER SWITCH
25265-H5200	KNOB-WIPER SWITCH
25199-H1000	SPRING
25170-H2510	ASSY-LAMP,ILLUMINATION
08964-10510	NUT-SPRING
08540-51612	SCREW
25330-H1000	COMP-CIGALETTE LIGHTER
25330-H1001	COMP-CIGALETTE LIGHTER
B5331-H5001	COMP-CIGALETTE LIGHTER
B5330-H1001	ELEMENT-CIGAR LIGHTER
25290-H1900	COMP-SWITCH HAZARD
25290-H4600	COMP-SWITCH HAZARD
25290-H4601	COMP-SWITCH HAZARD
08513-30812	SCREW FIXING HAZARD SWITCH
08915-13310	WASHER-SPRING
25540-H1100	COMP-SWITCH TURN SIGNAL & DIMMER WITH
25540-H1006	COMP-SWITCH TURN SIGNAL & DIMMER
25540-H1007	COMP-SWITCH TURN SIGNAL & DIMMER
25410-H1000	BLOCK-FUSE
25410-B5102	BLOCK-FUSE
B5415-H1000	COVER-FUSE BLOCK
08941-11000	FUSE (10A)
08941-11500	FUSE (15A)
08510-51212	SCREW
08915-13510	WASHER-SPRING
25240-G150A	SWITCH-OIL PRESSURE ENGINE
25240-89910	SWITCH-OIL PRESSURE ENGINE
25360-89900	SWITCH-DOOR
25360-89915	SWITCH-DOOR
25320-H1000	SWITCH-STOP LAMP
25520-89911	UNIT HAZARD FLASHER
25520-89997	UNIT HAZARD FLASHER
25520-89990	UNIT HAZARD FLASHER
08510-51012	SCREW-TAPPING
B5520-89993	UNIT-FLASHER 12V 50W
25520-89901	UNIT-FLASHER 12V 50W
26310-H1000	HORN-HIGH
26310-H1800	HORN-HIGH
26330-H1000	HORN-LOW
25620-G2501	HORN-LOW
26330-H1800	HORN-LOW
08110-81410	BOLT-HEX M8
26320-14800	RELAY-HORN
08310-51062	SCREW-MACHINE WITH LOCK WASHER
26320-89905	ASSY-RELAY,PASSING
08513-51012	SCREW
25390-20300	SWITCH-KICK DOWN
36011-89901	SWITCH-HAND BRAKE
36011-H1900	SWITCH-HAND BRAKE WARNING
25230-H2200	SWITCH-HEAT GLASS
08510-51212	SCREW
22110-N0901	ASSY-SWITCH, THERMOSTAT
08510-51212	SCREW
25235-P0101	ASSY-RELAY,HEATER,AUTO CHOKE
25235-P0100	ASSY-RELAY,HEATER,AUTO CHOKE
08513-61212	SCREW
26350-89905	BUZZER
08513-51012	SCREW
48780-H1900	BRACKET-BUZZER
25230-89918	ASSY-RELAY
25231-H4600	BRACKET-RELAY
08513-51012	SCREW
26495-H4600	LAMP-SEAT BELT WARNING
08961-44810	NUT-PUSH
25310-H4600	SWITCH-SEATING
27010-H1600	KIT-ROOM HEATER
27013-H1001	ASSY-CORE HEATER
27013-H1000	ASSY-CORE HEATER
27014-H1000	ASSY-MOTOR HEATER
27015-H3100	ASSY-RESISTANCE WITH FUSE
27135-H1600	COMP-CONTROL HEATER
27137-H1000	KNOB-HEATER CONTROL'A'
27138-H1000	KNOB-HEATER CONTROL'B'
08310-30612	SCREW
08915-13310	WASHER
27139-H1600	ASSY-CABLE HEATER CONTROL'A'
27140-H1600	ASSY-CABLE HEATER CONTROL'B'
27141-H1600	ROD-HEATER CONTROL
27142-H1000	PIN-CONTROL ROD
27143-H1000	WASHER CONTROL ROD
08915-13510	WASHER
08410-51212	SCREW
08310-61014	SCREW
27018-H1000	VALVE-ROOM HEATER
27161-H1000	HOSE-DEFROSTER
27161-H1001	HOSE-DEFROSTER
27171-H1000	NOZZLE-DEFROSTER
27171-H1001	NOZZLE-DEFROSTER
08513-51212	SCREW
08915-43510	WASHER
27020-H1000	HOSE-WATER
27020-G1900	HOSE-WATER
27021-H1000	HOSE-WATER
B7021-H1002	HOSE-WATER
08723-12000	CLAMP-HOSE
27051-E0100	CLIP-WATER
27070-H1000	CONNECTOR-WATER INLET
27075-H1000	CONNECTOR-WATER OUTLET
27078-B2000	CLIP
08915-43510	WASHER-PLAIN
27363-18001	GROMMET-HEATER
27363-18200	GROMMET-HEATER
08915-13610	WASHER-SPRING
08460-61612	SCREW
27012-H1000	PLATE-AIR INTAKE FOR HEATER LESS
08915-53610	WASHER-PLAIN PLATE FIX
X2160-30231	KNOB-VENTIRATOR
X2160-30213	ASSY-PANEL HEATER BOX
X2160-30600	ASSY-VALVE WATER CONTROL
X2161-30600	ASSY-VALVE WATER CONTROL
B7017-B8500 	ASSY-VALVE WATER CONTROL
X2160-30503	HOSE-HEATR
27022-H1000 	HOSE-HEATR
27900-H1105	KIT-RADIO WITH ANTENNA (CLARION)
27900-H1110	KIT-RADIO WITH ANTENNA (HITACHI)
27900-H1102	KIT-RADIO WITH ANTENNA (CLARION)
27962-H1100	ASSY-ANTENNA
99993-00090	ASSY-ANTENNA
27962-H1110	ASSY-ANTENNA
27984-89900	CONDENSER-TYPE B
27984-H5001	CONDENSER-TYPE B
68470-H1100	MASK-RADIO DATSUN MARK
27978-H1000	PLUG-RUBBER
27979-H1000	PLUG-RUBBER
27380-H2000	ASSY-CLOCK
27389-H2300	SPACER FIXING CLOCK TO CONCOLE BOX
24410-03021	BATTERY,DRY,N50(12-50AH)
24410-38301	BATTERY,DRY,N50Z (12-60AH)
28800-H1600	ASSY-DRIVE WINDSHIELD WIPER
B8800-H1900	ASSY-DRIVE WINDSHIELD WIPER
28800-H1602	ASSY-DRIVE WINDSHIELD WIPER
28810-H1600	ASSY-MOTOR(ISO THREAD)
B8810-H1900	ASSY-MOTOR(ISO THREAD)
28810-H1602	ASSY-MOTOR (ISO THREAD)
26389-H1600	ARM-WIPER MOTOR
28835-H1600	ASSY-BRACKET WIPER MOTOR (ISO THREAD)
26389-73000	RING-STOP
28860-H1600	ASSY-CONNECTING ROD NO.1
28865-H1000	ASSY-CONNECTING ROD NO.2
28870-H1600	ASSY-PIVOT NO.1
28875-H1000	ASSY-PIVOT NO.2
08360-61614	SCREW MOTOR FIX
08915-43610	WASHER MOTOR FIX
08320-51419	SCREW MOTOR FIX
28876-H1000	SEAL-PIVOT WINDSHIELD WIPER
26380-H1600	ASSY-ARM WIPER
26375-A4601	ASSY-BLADE WIPER
26375-A4600	ASSY-BLADE WIPER
26381-H1000	NUT-WIPER ARM
27400-H1000	KIT-WINDSHIELD WASHER
27400-H1001	KIT-WINDSHIELD WASHER
27400-G1600	KIT-WINDSHIELD WASHER
27480-89901	ASSY-BAG WINDSHIELD WASHER
27480-H1001	ASSY-BAG WINDSHIELD WASHER
27410-H7020	SET-TANK &BRKT WINDSHIELD WASHER
27480-H7020	ASSY-TANK
27440-H6200	BRKT-WASHER TANK
27446-89901	BRACKET-BAG
08513-61212	SCREW BACK FIX
08915-43610	WASHER BACK FIX
27440-H1001	NOZZLE-WINDSHIELD WASHER
27441-H1000	CLIP
24220-89964	CLIP
B7460-89910	TUBE-VINYL
27461-89955	TUBE-VINYL
26010-H1611	ASSY-LAMP HEAD RH(KOITO)
26010-H1610	ASSY-LAMP HEAD RH(KOITO)
26010-H1600	ASSY-LAMP HEAD RH(ICHIKHO)
26010-H1900	ASSY-LAMP HEAD RH(ICHIKHO)
26060-H1600	ASSY-LAMP HEAD LH(ICHIKHO)
26060-H1900	ASSY-LAMP HEAD LH(ICHICHO)
26060-H1610	ASSY-LAMP HEAD LH(KOITO)
26705-89905	UNIT-SEALED BEAM (KOITO)
26705-04201	UNIT-SEALED BEAM (ICHIKHO)
26705-89925	UNIT-SEALED BEAM (ICHIKHO)
26022-H1010	SCREW-ADJUST(KOITO)
26022-H1000	SCREW-ADJUST(ICHIKHO)
26023-H1000	NUT(ICHIKHO)
26023-H1010	NUT(KOITO)
26024-58000	SPRING(ICHIKHO)
26024-H1000	SPRING (ICHIKHO)
26024-H1010	SPRING(KOITO)
26024-H1011	SPRING(KOITO)
26017-14801	RING-RETAINING(ICHIKHO)
26017-18010	RING-RETAINING(KOITO)
26029-A4601	COVER-TERMINAL
26029-A4600	COVER-TERMINAL
26120-H1900	ASSY-LAMP FRONT COMBINATION RH(ICHIKHO)
26120-H1901	ASSY-LAMP,FRONT COMBINATION R.H
26120-H7000	ASSY-LAMP,FRONT COMBINATION R.H
26125-H1900	ASSY-LAMP FRONT COMBINATION LH(ICHIKHO)
26125-H1901	ASSY-LAMP,FRONT COMBINATION L.H
26125-H7000	ASSY-LAMP,FRONT COMBINATION L.H
26121-H1000	LENS RH AMBER(ICHIKHO)
26121-H1901	LENS RH AMBER(ICHIKHO)
26126-H1000	LENS LH AMBER(ICHIKHO)
26126-H1901	LENS LH AMBER(ICHIKHO)
26123-H1000	PACKING RH(ICHIKHO)
26128-H1000	PACKING LH(ICHIKHO)
26717-89920	BULB 12V-23-8W(ICHIKHO)
08310-44020	SCREW TO FIX LENS(ICHIKHO) (M4X0.7)
26127-04100	SEAT TO FIX LENS(ICHIKHO)
01221-00023	FLANGE NUT
26180-H1900	ASSY-LAMP SIDE MARKER FRONT RH (ICHIKHO)
26180-H7000	ASSY-LAMP SIDE MARKER FRONT RH
26185-H7000	ASSY-LAMP SIDE MARKER FRONT LH
26185-H1900	ASSY-LAMP SIDE MARKER FRONT LH(ICHIKHO)
26181-H1900	LENS(ICHIKHO)
26182-H1900	RIM(ICHIKHO)
26184-H1900	PACKING RH(ICHIKHO)
26189-H1900	PACKING LH(ICHIKHO)
01451-00041	SCREW(ICHIKHO)
08964-10410	NUT-SPRING(ICHIKHO)
26715-89902	BULB 12V-8W(ICHIKHO)
26190-H1910	ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO)
26190-H1900	ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO)
26195-H1900	ASSY-LAMP SIDE MARKER REAR LH(ICHIKHO)
26195-H1910	ASSY-LAMP SIDE MARKER REAR LH(ICHIKHO)
26191-H1900	LENS(ICHIKHO)
26194-H1900	PACKING RH(ICHIKHO)
26194-H1910	PACKING RH(ICHIKHO)
26199-H1900	PACKING LH(ICHIKHO)
26199-H1910	PACKING LH(ICHIKHO)
01451-00061	SCREW(ICHIKHO)
26550-H1902	ASSY-LAMP REAR COMBNATION RH(ICHIKHO)
26550-H7000	ASSY-LAMP REAR COMBINATION RH
26555-H1902	ASSY-LAMP REAR COMBNATION LH(ICHIKHO)
26555-H7000	ASSY-LAMP REAR COMBINATION LH
26552-H1001	ASSY-RIM (ICHIKHO)
26553-H1000	ASSY-PACKING (ICHIKHO)
26599-H1000	SEAT (ICHIKHO)
26551-H1902	ASSY-LENS RH RED-RED-WHITE (ICHIKHO)
26556-H1902	ASSY-LENS LH RED-RED-WHITE (ICHIKHO)
26563-H1600	ASSY-HARNESS,R.H
26564-H1600	ASSY-HARNESS,L.H
26717-89900	BULB 12V-23W (ICHIKHO)
26717-89920	BULB 12V-23/8W (ICHIKHO)
08911-10410	NUT (ICHIKHO) 1
08915-13410	WASHER-SPRING 1
08915-43410	WASHER-PLAIN 1
26510-H1900	ASSY-LAMP LICENCE(ICHIKHO)
26511-H1000	LENS
26512-H1000	COVER
26513-H1000	PACKING
08310-41420	SCREW
08915-13510	WASHER-PLAIN
08911-10510	NUT
26715-89901	BULB 12V-7.5W(ICHIKHO)
26510-H7000	ASSY-LAMP LICENCE,RH
26515-H7000	ASSY-LAMP LICENCE,LH
26715-89901	BLUB 12V-7.5W
01221-00011	NUT-FLANGE
24147-H7000	CABLE-LAMP,LICENCE
26410-H1000	ASSY-LAMP ROOM(ICHIKHO)
26411-H1000	LENS
26736-89902	BULB
08310-41210	SCREW-MACHINE (M4X0.7)
08510-41212	SCREW-TAPPING ROOM LAMP FIX
22100-H1901	DISTRIBUTOR(HITACHI)
22100-H1902	DISTRIBUTOR (HITACHI D412-63A)
22100-H7100	DISTRIBUTDR (HITACHI)
22100-H3900	DISTRIBUTOR(HITACHI)
22100-H3901	DISTRIBUTOR (HITACHI D412-80A)
22167-H2300	SET-CLAMP,CAP
22108-H1900	ASSY-SHAFT
22160-M0800	SET-WASHER THRUST
22110-H1900	SPRING-GOVERNOR
22110-H1901	SPRING-GOVERNOR
22110-H7100	SPRING-GOVERNOR
22132-H1901	ASSY-CAM SET
22132-H1900	ASSY-CAM SET
22136-H2300	ASSY-BRAKER PLATE
22136-E4600	ASSY-BRAKER PLATE
22145-89901	SET-CONTACT
22182-71300	ASSY-WIRE,EARTH
22183-71300	ASSY-WIRE,LEAD
22157-78500	ASSY-ROTOR,HEAD
22157-H1000	ASSY-ROTOR,HEAD
22157-D1290	ASSY-ROTOR,HEAD
22301-B3000	ASSY-CONTROL,VACUUM
22301-B3001	ASSY-CONTROL,VACUUM
22301-H1900	ASSY-CONTROL,VACUUM
22301-E4603	ASSY-CONTROL,VACUUM
22301-H3900	ASSY-CONTROL,VACUUM
22301-H3901	ASSY-CONTROL,VACUUM
22102-00801	ASSY-CONDENSER
22102-D1100	ASSY-CONDENSER
22180-18000	PLATE-FIX
22201-18005	BOLT
23100-U0100	ASSY-ALT.12V-35A (HITACHI LT135-13)(DE
23100-A5501	ASSY-ALTERNATOR(HITACHI)
23108-A5501	ASSY-ROTOR
23120-14801	BEARING-BALL
23102-A5501	ASSY-STATOR
23127-H0300	ASSY-COVER,REAR
23127-61700	ASSY-COVER,REAR
23127-61701	ASSY-COVER REAR
23236-H0300	COVER-DIODE
23236-H0301	COVER-DIODE
23230-H0300	ASSY-DIODE
23133-H0300	ASSY-HOLDER,BRUSH
23133-H0301	ASSY-HOLDER,BRUSH
23135-H0300	ASSY-BRUSH,F
23135-H0301	ASSY-BRUSH,E
23156-H0300	ASSY-TERMINAL BOLT
23118-H0300	ASSY-COVER,FRONT
23122-21000	PACKING
23121-21000	RETAINER-PACKING
23120-14800	BEARING-BALL
23123-21005	RETAINER-BEARING
23164-H0100	BOLT-SETTING
23131-H0300	BOLT-THROUGH,L=85
23131-H0301	BOLT-THROUGH,L=95
23150-21001	ASSY-PULLEY
23150-21002	ASSY-PULLEY
23153-H0100	ASSY-NUT
23200-E3400	SCREW-SET
23500-N3300	REGULATOR-VOLTAGE (HITACHI TLI
23500-29906	REGULATOR-VOLTAGE (HITACHI TLI
23500-29902	REGULATOR-VOLTAGE (HITACHI TLI
23500-29901	REGULATOR-VOLTAGE (HITACHI TL1
23500-29911	REGULATOR-VOLTAGE (MITSUBISHI
08513-61212	SCREW-TAPPING
08916-13610	WASHER-LOCK (INTERNAL TOOTH)
23100-U0100	ASSY-ALTERNATOR 12V-35A (LT135-13)
23108-U0100	ASSY-ROTOR
23102-U0101	ASSY-STATOR
23102-U0100	ASSY-STATOR
23127-U0100	ASSY-COVER,REAR
23127-U0101	ASSY-COVER,REAR
23133-U0100	ASSY-HOLDER,BRUSH
23133-U0101	ASSY-BRUSH
23135-H0300	ASSY-BRUSH(F)
23135-H0301	ASSY-BRUSH(E)
23193-P0100	TERMINAL-N
23236-U0100	COVER-BRUSH
23230-U0100	DIODE
23156-H0300	ASSY-BOLT,TERMINAL
23247-H0300	SLEEVE
23122-21000	PACKING
23153-H0100	ASSY-NUT,PULLEY
23200-E3400	SET-SCREW
24820-H1911	COMBINED-INSTRUMENT 100MILE/H
24820-H7000	COMBINED-INSTRUMENT 100MPH
24850-H1816	ASSY-SPEEDOMETER 100MILE/H
24850-H7000	ASSY-SPEEDOMETER 100MILE/H
24860-H1800	GAUGE-FUEL
24880-H1800	GAUGE-WATER TEMP
25010-H1701	LID-CLUSTER
25010-H4600	LID-CLUSTER
25010-H7000	LID-CLUSTER
25012-H1800	COVER-FRONT
25013-H1800	GASKET
25014-H1800	PLATE-SHADOW
25030-H1701	ASSY-CASE REAR
25030-H1710	ASSY-CASE REAR
26260-89900	SOCKET-WEDGE
26261-89902	BLUB 1.7W
26260-H1800	SOCKET-WITH LIED WIRE
26711-89900	BLUB 1.7W
25005-H1810	MASK-TACHOMETER "DATSUN"
24855-H1800	ASSY-TACHOMETER
24854-78501	KNOB-TACHOMETER
25006-H1000	SCREW
25050-H1601	ASSY-SHAFT FLEXIBLE L=1700
25050-H1602	ASSY-SHAFT FLEXIBLE
25080-89900	GAUGE-TEMP ENGINE UNIT
25251-30100	NUT
25035-H7000	ASSY-AMPLIFIER SPEED SWITCH
66502-H1000	ASSY-PLATE, AIR VENTILATOR
66511-H1000	ASSY-LID, AIR VENTILATOR
66504-18001	SPRING-AIR VENTILATOR R.H.
66505-18001	SPRING-AIR VENTILATOR L.H.
66507-18000	PIN-AIR VENTILATOR
66520-H1000	ASSY-CONTROL, AIR VENTILATOR
84371-78200	HOLDER-ROD
08460-61612	SCREW M6
08310-51214	SCREW M5
66522-H1600	ROD-CONTROL, VENTILATOR
26550-H1911	ASSY-LAMP REAR COMBINATION RH(ICHIKHO)
26550-H7100	ASSY-LAMP REAR COMBINATION RH
26555-H1911	ASSY-LAMP REAR COMBINATION LH(ICHIKHO)
26555-H7100	ASSY-LAMP REAR COMBINATION LH
26521-H1911	LENS-TURN SIGNAL RED (ICHIKHO)
26541-H1800	LENS-REVERSE LAMP RH UNCOLOR(ICHIKHO)
26546-H1800	LENS-REVERSE LAMP LH UNCOLOR(ICHIKHO)
26551-H1910	LENS-TAIL & STOP RH RED (ICHIKHO)
26556-H1910	LENS-TAIL & STOP LH RED (ICHIKHO)
26552-H1800	RIM (ICHIKHO)
26533-H1800	PACKING-LENS (ICHIKHO)
26553-H1800	PACKING-BODY (ICHIKHO)
26534-H1910	ASSY-HARNESS RH (ICHIKHO)
26539-H1910	ASSY-HARNESS LH (ICHIKHO)
08310-31410	SCREW 1
08911-10510	NUT 1
08915-13510	WASHER-SPRING 1
08915-43510	WASHER-PLAIN 1
26558-H1800	WASHER-SPONGE 1
26510-H1800	ASSY-LAMP LICENCE(ICHIKHO)
26511-H1800	LENS(ICHIKHO)
26513-H1800	PACKING(ICHIKHO)
26513-H1801	PACKING(ICHIKHO)
08310-41420	SCREW FIXING LENS
08310-51412	SCREW-MACHINE
