08913-10700 NUT-SPPING M3.5 68631-H1900 ASSY-LOCK GLOVE BOX LID 68632-H1900 STRIKER-LOCK 08330-41020 SCREW-MACHINE M4 FIX LOCK 08310-51212 SCREW-MACHINE M5 FIX STRIKER 08915-43510 WASHER-PLAIN M5 FIX STRIKER 72613-H1913 GLASS-WINDSHIELD TINTED PLT T=6.6 72613-H1910 GLASS-WINDSHIELD TINTED T=6.6 72610-H1800 WEATHERSTRIP-WINDSHIELD 72610-H1801 WEATHERSTRIP-WINDSHIELD 72810-H1800 SET-MOULDING WINDSHIELD 72810-H1801 SET-MOULDING WINDSHIELD 72812-H1800 MOULDING-WINDSHIELD UPPER 72811-H1801 MOULDING-WINDSHIELD UPPER RH 72812-H1801 MOULDING-WINDSHIELD UPPER LH 72810-H1801 MOULDING-WINDSHIELD LOWER 72813-H1800 MOULDING-WINDSHIELD LOWER 72814-H1801 MOULDING-WINDSHIELD RH 72814-H1800 MOULDING-WINDSHIELD RH 72815-H1800 MOULDING-WINDSHIELD LH 72815-H1801 MOULDING-WINDSHIELD LH 72814-13600 CLIP-MOULDING WINDSHIELD 73111-H1800 PANEL-ROOF 73200-H1800 ASSY-ROOF RAIL FRONT 73222-H1800 BOW-ROOF 08410-61212 SCREW-MACHINE M6 08915-43610 WASHER-PLAIN M6 08915-13610 WASHER-LOCK M6 73230-H1800 ASSY-ROOF RAIL REAR 73910-H1800 ASSY-CLOTH,HEAD LINING, (WHITE) 73910-H1801 ASSY-CLOTH,HEAD LINING, (WHITE) 73910-H2500 ASSY-CLOTH,HEAD LINING, (BEIGE) 73910-H2501 ASSY-CLOTH,HEAD LINING (BEIGE) 73910-H7100 ASSY-CLOTH,HEAD LINING (BEIGE) 73923-H1801 WIRE-LISTING 73923-H1800 WIRE-LISTING 73924-H1801 WIRE-LISTING 73924-H1800 WIRE-LISTING 73930-H1100 INSULATOR-ROOF FRONT 73930-H7100 INSULATOR-ROOF FRONT 73931-H1800 INSULATOR-ROOF REAR 73931-H7100 INSULATOR-ROOF REAR 73945-H1000 HANGER-COAT GRAY #1618 96750-E8201 HANGER-COAT GRAY 08330-62020 SCREW-MACHINE M6 08310-61412 SCREW WITH WASHER 08916-33610 WASHER-LOCK 73950-H1800 ASSY-SUN VISOR 73950-H7100 ASSY-SUN VISOR (BEIGE) 08530-51620 SCREW-TAPPING M5 73940-H1101 ASSY-RAIL ASSIST 08310-61412 SCREW-MACHINE M6 96321-H1900 ASSY-BACK MIRROR INSIDE 08330-51420 SCREW-MACHINE M5 74300-H1021 ASSY-FLOOR,FRONT 74300-H1010 ASSY-FLOOR FRONT 74310-H1000 ASSY-MEMBER CROSS FRONT SEATRH 74311-H1000 ASSY-MEMBER CROSS FRONT SEATLH 74314-H1000 BRACKET-FRONT SEAT INSIDE RH 74314-H1001 BRACKET-FRONT SEAT INSIDE RH 74315-H1000 BRACKET-FRONT SEAT INSIDE LH 74316-H1000 BRACKET-FRONT SEAT OUTSIDE RH 74317-H1000 BRACKET-FRONT SEAT OUTSIDE LH 74320-H1000 ASSY-FLOOR SIDE RH 74321-H1000 ASSY-FLOOR SIDE LH 74500-H1800 ASSY-FLOOR REAR 74500-H1905 ASSY-FLOOR REAR 74500-H1906 ASSY-FLOOK REAR 74500-H7100 ASSY-FLOOR REAR 74528-H1800 REINFORCEMENT-BUMPER STAY REAR 84122-H1800 BRACKET-SEAT REAR SIDE 74860-H1000 ASSY-MEMBER CROSS REAR SEAT LOWER 74870-H1800 ASSY-MEMBER CROSS SHOCK ABSORBER 74882-H1800 MEMBER-CROSS REAR END 74850-H1800 ASSY-MEMBER SIDE REAR RH 74850-H2501 ASSY-MEMBER SIDE REAR RH 74851-H1800 ASSY-MEMBER SIDE REAR LH 55208-H1000 ASSY-BRACKET SHACKLE RH 55208-H1800 ASSY-BRACKET SHACKLE LH 84106-H1800 BRACKET-TRUNK ROOM TRIM REARSIDE 74810-H1001 ASSY-MEMBER SIDE FRONT RH 74811-H1001 ASSY-MEMBER SIDE FRONT LH 54532-H1001 ASSY-BRACKET TENSION ROD RH 54533-H1001 ASSY-BRACKET TENSION ROD LH 74800-H1000 ASSY-MEMBER CROSS FRONT 74933-H1000 INSULATOR-TUNNEL FRONT 74933-H1020 INSULATOR-TUNNEL,FRONT 74931-H1000 INSULATOR-FLOOR FRONT RH 74932-H1000 INSULATOR-FLOOR FRONT LH 74934-H1000 INSULATOR-FLOOR REAR 74934-H1025 SET-INSULATOR FLOOR REAR RH 74937-H1000 INSULATOR-TUNNEL REAR 74965-H1000 BOOT-HAND BRAKE 74936-H1000 INSULATOR-REAR SEAL LOWER 84124-H1801 BRACKET-FUEL TANK MOUNTING RH 01658-00021 PLUG-RUBBER 25D 01658-00041 PLUG-RUBBER 39D 57210-18000 HANDLE-SPARE WHEEL CLAMP 74630-21002 HANDLE-SPARE WHEEL CLAMP 99606-H1800 CLAMP-JACK HANDLE 74962-H1905 PROTECTOR-BREATHER TUBE 74365-73000 PLUG-ANCHORAGE 74963-20900 BOOT-CONTROL LEVER 32021-35000 PLUG-INSPECTION HOLE 55D 74891-H2500 ASSY-COVER INSPECTION HOLE 08510-61212 SCREW 74902-H1605 MAT-FLOOR FRONT RH 74902-H2031 CARPET-FLOOR FRONT RH 74903-H1605 MAT-FLOOR FRONT LH 74903-H2031 CARPET-FLOOR FRONT LH 74904-H2025 CARPET-FLOOR TUNNEL 74904-H2031 CARPET-FLOOR TUNNEL 74907-H1102 CARPET-FLOOR REAR 74907-H1105 MAT-FLOOR REAR 74907-H1101 CARPET-FLOOR REAR 74907-H2011 CARPET-FLOOR REAR 08530-52512 SCREW-TAPPING 1 74943-H1111 JUTE-TUNNEL FRONT 74943-H1121 JUTE-TUNNEL FRONT 74941-H2011 JUTE-FRONT FLOOR 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LH-20 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LB-211 74921-H1100 COVER-FLOOR SIDE FRONT RH 74922-H7000 COVER-FLOOR SIDE FRONT LH (BLUE,LB-211 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LH-20 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13 74922-H1100 COVER-FLOOR SIDE FRONT LH 74925-H7102 COVER-FLOOR SIDE REAR RH (BLACK,LG-13 74925-H1800 COVER-FLOOR SIDE REAR RH 74925-H7100 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 74925-H7101 COVER-FLOOR SIDE REAR RH (BEIGE,LH-20 74926-H7102 COVER-FLOOR SIDE REAR LH (BLACK,LG-13 74926-H7101 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20 74926-H7100 COVER-FLOOR SIDE REAR LH (BLUE,LB-211 74926-H1800 COVER-FLOOR SIDE REAR LH 74914-H1100 COVER-REAR SEAT LOWER RH 74914-H7000 COVER-REAR SEAT LOWER RH (BLUE,LB-211 74914-H7002 COVER-REAR SEAT LOWER RH (BEIGE,LH-20 74914-H7004 COVER-REAR SEAT LOWER RH (BLACK,LG-13 74914-H7001 COVER-REAR SEAT LOWER LH (BLUE,LB-211 74914-H7003 COVER-REAR SEAT LOWER LH (BEIGE,LH-20 74914-H1101 COVER-REAR SEAT LOWER LH 74914-H7005 COVER-REAR SEAT LOWER LH (BLACK,LG-13 74915-H1800 COVER-REAR WHEEL HOUSE RH 74915-H1801 COVER-REAR WHEEL HOUSE RH YELLOW 74915-H7100 COVER-REAR WHEEL HOUSE RH (BLUE,LB-211 74915-H7101 COVER REAR WHEEL HOUSE RH (BEIGE,LH-20 74915-H7102 COVER REAR WHEEL HOUSE RH (BLACK,LG-13 74916-H1801 COVER-REAR WHEEL HOUSE LH YELLOW 74916-H7102 COVER REAR WHEEL HOUSE LH (BLACK,LG-13 74916-H7101 COVER REAR WHEEL HOUSE LH (BEIGE,LH-20 74916-H1800 COVER-REAR WHEEL HOUSE LH 74916-H7100 COVER-REAR WHEEL HOUSE LH (BLUE) 74917-H1800 PAD-REAR WHEEL HOUSE 74917-H7000 PAD-REAR WHEEL HOUSE 74951-H1200 PLATE-KICKING FRONT RH 74951-H3600 PLATE-KICKING FRONT RH 74952-H3600 PLATE-KICKING FRONT LH 74952-H1200 PLATE-KICKING FRONT LH 08540-41242 SCREW-TAPPING M4 08540-41242 SCREW-TAPPING M4 1 74961-H1100 TRIM-SEAT RISER RH 74962-H1100 TRIM-SEAT RISER LH 74962-G1000 TRIM-SEAT RISER,LH 74980-H1801 ASSY-BOX CONSOL 74980-H7000 ASSY-BOX CONSOL 74980-H1921 ASSY-BOX CONSOL 74980-H7001 ASSY-BOX CONSOLE 74980-H2010 ASSY-BOX CONSOL 74982-H1801 FINISHER-CONSOL BOX 74986-H1801 ASSY-BOOT 74986-H7000 ASSY-BOOT 08510-51242 SCREW 08915-43542 WASHER-PLAIN 01241-00061 NUT-SPRING 74990-H1800 MASK-CLOCK 08513-41212 SCREW 08915-43410 WASHER-PLAIN 76200-H1800 ASSY-FRONT PILLAR RH 76201-H1800 ASSY-FRONT PILLAR LH 76230-H1800 ASSY-WINDSHIELD PILLAR INNERRH 76231-H1800 ASSY-WINDSHIELD PILLAR INNERLH 64120-H1000 REINF-HOODLEDGE UPPER RH 64118-H1000 REINF-HOODLEDGE UPPER RH 64121-H1000 REINF-HOODLEDGE UPPER LH 64119-H1000 REINF-HOODLEDGE UPPER LH 76240-H1000 ASSY-DASH SIDE,RH 76241-H1000 ASSY-DASH SIDE,LH 76312-H1851 ASSY-PANEL ROOF RAIL SIDE OUT RH 76310-H4050 ASSY-RAIL ROOF SIDE OUTER RH 76313-H1851 ASSY-PANEL ROOF RAIL SIDE OUT LH 76311-H4050 ASSY-RAIL ROOF SIDE OUTER LH 76322-H1800 PANEL-RAIL ROOF SIDE INNER RH 76323-H1800 PANEL-RAIL ROOF SIDE INNER LH 76320-H1805 ASSY-PANEL BODY SIDE INNER RH 76320-H1855 ASSY-PANEL BODY SIDE INNER RH 76321-H1805 ASSY-PANEL BODY SIDE INNER LH 76321-H1855 ASSY-PANEL BODY SIDE INNER LH 76412-H1800 PANEL-SILL OUTER RH 76413-H1800 PANEL-SILL OUTER LH 76500-H1809 ASSY-PILLAR LOCK RH 76500-H7100 ASSY-PILLAR LOCK RH 76500-H1850 ASSY-PILLAR LOCK RH 76501-H1850 ASSY-PILLAR LOCK LH 76501-H1809 ASSY-PILLAR LOCK LH 76501-H7100 ASSY-PILLAR LOCK LH 76720-H1800 ASSY-WHEEL HOUSE INNER REAR RH 76721-H1800 ASSY-WHEEL HOUSE INNER REAR LH 76742-H1800 PLATE-CLOSING SILL REAR RH 76743-H1800 PLATE-CLOSING SILL REAR LH 78120-H1800 ASSY-DRIP FENDER REAR RH 78121-H1800 ASSY-DRIP FENDER REAR LH 76808-H1800 RUBBLER-FINISH LOCK FILLER 76880-H1000 MOULDING-BODY SILL 76880-H3100 COMP-BODY SILL MOULDING 76486-H1000 RETAINER-SILL MOULDING 76486-N1600 BOLT-SILL MOULDING 76488-21600 CLIP-SILL MOULDING 08911-10610 NUT-HEX M6 01221-00033 NUT-HEX M6 TO FIX SILL MOULDING 08915-13610 WASHER-LOCK 76806-H1801 MOULDING-LOCK PILLAR RH 76807-H1801 MOULDING-LOCK PILLAR LH 72832-32200 SCREW-TAPPING #4 76876-H1800 MOULDING-REAR FENDER RH 76877-H1800 MOULDING-REAR FENDER LH 72832-32200 SCREW-TAPPING #4 76878-H1800 FASTNER-REAR FENDER MOULDING 73800-H1800 SET-MOULDING ROOF DRIP RH 73800-H1801 SET-MOULDING ROOF DRIP RH 73801-H1800 SET-MOULDING ROOF DRIP LH 73801-H1801 SET-MOULDING ROOF DRIP LH 73810-H1800 MOULDING-ROOF DRIP FRONT RH 73810-H1801 MOULDING-ROOF DRIP FRONT RH 73811-H1800 MOULDING-ROOF DRIP FRONT LH 73811-H1801 MOULDING-ROOF DRIP FRONT LH 73812-H1800 MOULDING-ROOF DRIP REAR RH 73812-H1801 MOULDING-ROOF DRIP REAR RH 73813-H1800 MOULDING-ROOF DRIP REAR LH 73813-H1801 MOULDING-ROOF DRIP REAR LH 73815-H1100 CLIP-MOULDING ROOF DRIP K5040-00067 TAPE MASKING FOR ACCENT STRIPE 76900-H1800 ASSY-FINISH,BODY SIDE,RH (BLACK) 76900-H7100 ASSY-FINISH,BODY SIDE,RH (BLUE) 76900-H1801 ASSY-FINISH,BODY SIDE,RH (YELLOW) 76900-H7101 ASSY-FINISH,BODY SIDE,RH (BEIGE,LH-20 76900-H7102 ASSY-FINISH,BODY SIDE,RH (BLACK,LG-13 76901-H1800 ASSY-FINISH,BODY SIDE,LH (BLACK) 76901-H7102 ASSY-FINISH,BODY SIDE,LH (BLACK,LG-13 76901-H7101 ASSY-FINISH,BODY SIDE,LH (BEIGE,LH-20 76901-H7100 ASSY-FINISH,BODY SIDE,LH (BLUE) 76901-H1801 ASSY-FINISH,BODY SIDE,LH (YELLOW) 80919-25700 CLIP-DOOR FINISH 80919-89900 CLIP-DOOR FINISH 08510-51212 SCREW 08915-43540 WASHER-PLAIN 76911-H7100 CLOTH-WINDSHIELD PILLAR,RH (BEIGE) 76911-H1800 CLOTH-WINDSHIELD PILLAR,RH 76911-H2501 CLOTH-WINDSHIELD PILLAR,R.H (BEIGE) 76912-H7100 CLOTH-WINDSHIELD PILLAR,LH (BEIGE) 76912-H1800 CLOTH-WINDSHIELD PILLAR,L.H 76912-H2501 CLOTH-WINDSHIELD PILLAR,L.H (BEIGE) 76951-H1100 PAD-WEATHER STRIP,PILLAR 76951-H7100 PAD-WINDSHIELD PILLAR 76913-H1800 CLOTH-LOCK PILLAR,R.H 76913-H2501 CLOTH-LOCK PILLAR,R.H(BEIGE) 76913-H7100 CLOTH-LOCK PILLAR,RH(BEIGE) 76914-H1800 CLOTH-LOCK PILLAR,L.H 76914-H7100 CLOTH-LOCK PILLAR,LH(BEIGE) 76914-H2501 CLOTH-LOCK PILLAR,L.H(BEIGE) 76953-H1800 PAD-LOCK PILLAR 76953-H7100 PAD-LOCK PILLAR 76917-H1800 ASSY-CLOTH,REAR PILLAR,R.H 76917-H2501 ASSY-CLOTH,REAR PILLAR,R.H (BEIGE) 76917-H7100 ASSY-CLOTH,REAR PILLAR,RH (BEIGE) 76918-H2501 ASSY-CLOTH,REAR PILLAR,L.H (BEIGE) 76918-H7100 ASSY-CLOTH,REAR PILLAR,LH (BEIGE) 76918-H1800 ASSY-CLOTH,REAR PILLAR,L.H 76957-H7100 PAD-REAR PILLAR 76957-H1800 PAD-REAR PILLAR 08520-51220 SCREW-TAPPING M5 76921-H1000 WELT-BODY SIDE 76922-H1200 WELT-SIDE WINDOW 96502-H1001 ASSY-ASH TRAY,REAR 08520-51220 SCREW-TAPPING M5 78110-H1955 ASSY-FENDER REAR RH 78110-H1956 ASSY-FENDER REAR RH 78110-H1905 ASSY-FENDER REAR RH 78111-H1955 ASSY-FENDER REAR LH 78111-H1956 ASSY-FENDER REAR LH 78111-H1905 ASSY-FENDER REAR LH 78120-H1800 ASSY-DRIP FENDER REAR RH 78121-H1800 ASSY-DRIP FENDER REAR LH 78135-H1800 ASSY-COVER GAS FILLER 76500-H7100 ASSY-PILLAR LOCK RH WITH PATCH 76500-H1850 ASSY-PILLAR LOCK RH WITH PATCH 76500-H1809 ASSY-PILLER LOCK RH WITH PATCH 76501-H7100 ASSY-PILLAR LOCK LH WITH PATCH 76501-H1850 ASSY-PILLAR LOCK LH WITH PATCH 76501-H1809 ASSY-PILLAR LOCK LH WITH PATCH 78124-H1800 PANEL-AIR DUCT SIDE RH 78125-H1800 PANEL-AIR DUCT SIDE LH 79100-H1905 ASSY-PANEL REAR 79120-H1800 ASSY-REINF REAR PANEL 96224-H1800 BRACKET-REAR LICENCE PLATE 79312-H1800 PANEL-REAR WAIST OUTER 79314-H1800 PANEL-REAR WAIST INNER 78130-H1800 ASSY-LID GAS FILLER 77760-89902 BUMPER-RUBBER GAS FILLER LID 08310-51012 SCREW-MACHINE M5 FIX LID 78843-H2225 SET-GRILLE AIR OUTLET UPPER 78844-H2225 SET-GRILLE AIR OUTLET LOWER 08961-44810 PUSH 08915-43410 WASHER-PLAIN 08915-13410 WASHER-SPRING 08911-10410 NUT-HEX 74993-73000 PLUG-REAR FENDER 76802-H1801 WEATHERSTRIP-SIDE WINDOW RH 76803-H1801 WEATHERSTRIP-SIDE WINDOW LH 76822-H1805 GLASS-SIDE WINDOW RH TINTED T=4.0 76823-H1805 GLASS-SIDE WINDOW LH TINTED T=4.0 76824-H1801 ASSY-SASH SIDE WINDOW RH 76825-H1801 ASSY-SASH SIDE WINDOW LH 76826-H1806 RUBBER-SIDE WINDOW 76826-H1807 RUBBER-SIDE WINDOW 08310-41218 SCREW-MACHINE WITH TOOTH WASHER FIX H 76870-H1200 ASSY-HANDLE SIDE WINDOW RH 76871-H1200 ASSY-HANDLE SIDE WINDOW LH 76872-18000 PIN-HANDLE SIDE WINDOW 08430-41619 SCREW-MACHINE M4 08916-43410 WASHER-TOOTH M4 76873-18000 SHIM-HANDLE SIDE WINDOW 76873-H1200 SHIM-HANDLE SIDE WINDOW (T=1.00) 76873-H1210 SHIM-HANDLE SIDE WINDOW (T=2.00) 80100-H7100 ASSY-PANEL FRONT DOOR WITH SASH RH 80100-H1800 ASSY-PANEL FRONT DOOR WITH SASH RH 80101-H1800 ASSY-PANEL FRONT DOOR WITH SASH LH 80101-H7100 ASSY-PANEL FRONT DOOR WITH SASH LH 80152-H1200 PANEL-FRONT DOOR OUT SIDE RH 80153-H1200 PANEL-FRONT DOOR OUT SIDE LH 80210-H1800 ASSY-SASH FRONT DOOR RH 80211-H1800 ASSY-SASH FRONT DOOR LH 80280-H1801 SET-COVER DOOR SASH RH 80281-H1801 SET-COVER DOOR SASH LH 80270-H1800 ASSY-FRAME DOOR VENTILATOR RH 80271-H1800 ASSY-FRAME DOOR VENTILATOR LH 80244-H1800 GLASS-DOOR VENTILATOR RH (ANTI-SUN T= 80245-H1800 GLASS-DOOR VENTILATOR LH (ANTI-SUN T= 80250-H1800 ASSY-CHANNEL VENTILATOR GLASS RH 80251-H1800 ASSY-CHANNEL VENTILATOR GLASS LH 80247-H1000 WASHER-STOP 80248-H1000 SPRING H0285-H1000 RUBBER-GLAZING DOOR VENTILATOR 80246-H1000 RUBBER-GLAZING DOOR VENTILATOR 80260-H1800 ASSY-CATCH HANDLE RH 80261-H1800 ASSY-CATCH HANDLE LH 80238-H1800 BRACKET-PIVOT TOP LOW 80234-H1000 WASHER-BRACKET PIVOT 80284-H1000 WASHER-RUBBER A 80285-H1000 WASHER-RUBBER B 08330-51020 SCREW-MACHINE M5 80292-73000 RIVET-SPECIAL 80282-H1800 WEATHERSTRIP-DOOR VENTILATORRH 80283-H1800 WEATHERSTRIP-DOOR VENTILATORLH 80336-H1801 RUBBER-GLASS RUN B 80336-H1800 RUBBER-GLASS RUN B 80311-H1800 GLASS-DOOR WINDOW TEMP TINTED T=4.0 80312-H1800 GLASS-DOOR WINDOW TEMP TINTED T=4.0 80302-H1800 ASSY-BOTTOM CHANNEL FRONT RH 80303-H1800 ASSY-BOTTOM CHANNEL FRONT LH 80317-H1800 RUBBER-GLAZING 80335-H1800 RUBBER-GLASS RUN 'A' 80335-H1801 RUBBER-GLASS RUN 'A' 80400-H7000 ASSY-HINGE FRONT DOOR UPPER RH 80400-H1000 ASSY-HINGE FRONT DOOR UPPER RH 80400-H1001 ASSY-HINGE FRONT DOOR UPPER RH 80401-H7000 ASSY-HINGE FRONT DOOR UPPER LH 80401-H1000 ASSY-HINGE FRONT DOOR UPPER LH 80401-H1001 ASSY-HINGE FRONT DOOR UPPER LH H0400-73002 BUSH-DOOR HINGE UPPER 80402-H1000 ASSY-HINGE FRONT DOOR LOWER 80402-H1001 ASSY-HINGE FRONT DOOR LOWER H0402-H1001 BUSH-DOOR HINGE LOWER 77720-89913 BOLT-SPECIAL M8 FILLER FIX 1 77740-89912 WASHER-PLAIN M8 FILLER FIX 1 08120-82062 BOLT-WITH SPRING LOCK WASHERDOOR FIX 1 80500-H3600 ASSY-DOOR LOCK & REMOTE CONTROL FRON 80501-H3600 ASSY-DOOR LOCK & REMOTE CONTROL FRON 80502-H1201 ASSY-DOOR LOCK FRONT RH 80502-H3600 ASSY-DOOR LOCK FRONT RH 80503-H1201 ASSY-DOOR LOCK FRONT LH 80503-H3600 ASSY-DOOR LOCK FRONT LH 80504-H1001 ASSY-REMOTE CONTROL DOOR LOCK RH 80505-H1001 ASSY-REMOTE CONTROL DOOR LOCK LH 80508-H1000 SPRING-DOOR LOCK RH 80509-H1000 SPRING-DOOR LOCK LH 08320-61012 SCREW-MACHINE M6 TO FIX DOORLOCK 08916-43610 WASHER LOCK TOOTH TO FIX DOOR LOCK 08310-61214 SCREW-MACHINE WITH WASHER 08915-43610 WASHER-PLAIN TO FIX REMOTE CONTROL 80570-E6000 ASSY-STRIKER DOOR LOCK RH 80571-E6000 ASSY-STRIKER DOOR LOCK LH 80575-24800 SHIM-STRIKER DOOR LOCK 80577-21000 BOLT-SPECIAL TO FIX STRIKER 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH 08330-50820 SCREW-MACHINE M5 TO FIX ESCUTCHEON 80595-21003 KNOB-DOOR LOCK 80595-N1600 KNOB-DOOR LOCK 80970-21000 GROMMET-LOCK KNOB 80605-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT RH 80605-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT RH 80606-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT LH 80606-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT LH 80608-H1000 ASSY-ROD OUT SIDE HANDLE 08915-13510 WASHER-SPRING LOCK 08915-43510 WASHER-PLAIN M5 08911-10510 NUT-HEX M5 80760-H1000 ASSY-HANDLE DOOR WINDOW REGULATOR 80675-H1000 WASHER-HANDLE 08330-51220 SCREW-MACHINE 80700-H1800 ASSY-REGULATOR DOOR WINDOW RH 08310-61012 SCREW-MACHINE 1 08915-13610 WASHER-SPRING LOCK M6 1 80701-H1800 ASSY-REGULATOR DOOR WINDOW LH 08915-43610 WASHER-PLAIN M6 80830-H1202 ASSY-WEATHERSTRIP,FRONT DOOR,R.H 80830-H1800 ASSY-WEATHERSTRIP FRONT DOOR RH 80831-H1800 ASSY-WEATHERSTRIP FRONT DOOR LH 80831-H1202 ASSY-WEATHERSTRIP,FRONT DOOR,L.H 80834-H1000 SPACER-WEATHERSTRIP FRONT DOOR RH 80835-H1000 SPACER-WEATHERSTRIP FRONT DOOR LH 80820-H1200 ASSY-MOULDING FRONT DOOR OUTER RH 80820-H3600 ASSY-MOULDING FRONT DOOR OUTER RH 80821-H1200 ASSY-MOULDING FRONT DOOR OUTER LH 80821-H3600 ASSY-MOULDING FRONT DOOR OUTER LH 80825-H1000 CLIP-MOULDING DOOR OUTER 80836-H1200 WEATHERSTRIP-FRONT DOOR INSIDE 80860-H1000 ASSY-STOPPER DOOR GLASS 08310-61214 SCREW-MACHINE WITH SPRING WASHER M6 80832-H1000 RUBBER-BUMPER FRONT DOOR 80804-H1200 SCREEN-SEAL FRONT DOOR INSIDE 80840-21001 COVER-DRAIN HOLE 80886-H1200 RUBBER-DOOR COVER RH 80887-H1200 RUBBER-DOOR COVER LH 80212-H1800 ASSY-DOOR SASH LOWER RH 80213-H1800 ASSY-DOOR SASH LOWER LH 08410-61012 SCREW-MACHINE TO BODY IN SIDE FIX 08915-13610 WASHER-SPRING LOCK TO BODY IN SIDE FIX 80900-H1801 ASSY-FINISH,FRONT DOOR,R.H (YELLOW) 80900-H1800 ASSY-FINISH FRONT DOOR RH BLACK #1742 80900-H7101 ASSY-FINISH,FRONT DOOR,RH (BEIGE,LH-20 80900-H7102 ASSY-FINISH,FRONT DOOR,RH (BLACK,LG-13 80900-H7100 ASSY-FINISH FRONT DOOR RH (BLUE) 80901-H1800 ASSY-FINISH FRONT DOOR LH BLACK #1742 80901-H7100 ASSY-FINISH FRONT DOOR LH (BLUE) 80901-H1801 ASSY-FINISH,FRONT DOOR,L.H (YELLOW) 80901-H7101 ASSY-FINISH FRONT DOOR,LH (BEIGE,LH-20 80901-H7102 ASSY-FINISH FRONT DOOR,LH (BLACK,LG-13 80919-89900 CLIP-DOOR FINISH 80929-32200 CAP-DOOR FINISH CLIP 80940-H1100 COMP-ARM REST BLACK #766 08410-62012 SCREW-MACHINE M6 08915-13610 WASHER-PLAIN M6 80517-H1000 SHIELD-INSIDE HANDLE 79710-H1800 WEATHERSTRIP-REAR WINDOW 79713-H1805 GLASS-REAR WINDOW TINTED T=4.0 79713-H2201 GLASS-REAR WINDOW,TINTED HEAT RIGHT,T 79810-H1800 SET-MOULDING REAR WINDOW 79812-H1800 MOULDING-REAR WINDOW UPPER 79813-H1800 MOULDING-REAR WINDOW LOWER 79814-H1800 MOULDING-REAR WINDOW SIDE RH 79815-H1800 MOULDING-REAR WINDOW SIDE LH 79816-H1800 CLIP-MOULDING UPPER 79817-H1800 CLIP-MOULDING LOWER 84300-H1800 ASSY-TRUNK LID 84420-H1800 ASSY-STRIKER TRUNK LID LOCK 08310-61614 SCREW-MACHINE WITH WASHER M6X1.0 08915-43610 WASHER-PLAIN M6 84430-H1800 ASSY-LOCK TRUNK LID 84460-H1800 ASSY-CYLINDER LOCK TRUNK LID 84460-H1801 ASSY-CYLINDER LOCK TRUNK LID 08310-61612 SCREW-MACHINE M6 08915-13610 WASHER-LOCK M6 08915-43610 WASHER-PLAIN M6 84520-H1800 ASSY-HINGE TRUNK LID RH 84521-H1800 ASSY-HINGE TRUNK LID LH 84532-H1800 BAR-TORSION TRUNK LID RH 84533-H1800 BAR-TORSION TRUNK LID LH 84542-H1800 ROLLER-TRUNK LID SPRING 08310-51018 SCREW M5 W/WASHER FIX HINGE TO BODY 1 77720-89921 SCREW-MACHINE M6 W/WASHER FIX HINGE TO 84810-H1800 WEAHERSTRIP-TRUNK LID 85011-H1905 BUMPER-REAR CENTER 85011-H7100 BUMPER-REAR CENTER 85012-H1000 BUMPER-REAR RH 85013-H1000 BUMPER-REAR LH 62663-18000 BOLT-SPECIAL M6 FIX BUMP CENTER TO SI 08915-13610 WASHER-LOCK FIX BUMP CENTER TO SIDE 08911-10610 NUT-HEX M6 FIX BUMP CENTER TO SIDE 85204-H7100 ASSY-STAY BUMPER REAR 85204-H1000 STAY-BUMPER REAR 62663-18000 BOLT-SPECIAL M6 FIX STAY TO BUMPER 08144-01610 BOLT 08915-43610 WASHER-PLAIN M6 FIX STAY TO BUMPER 08915-44010 WASHER-PLAIN 08915-13610 WASHER-LOCK 08915-14010 WASHER-LOCK 08911-10610 NUT-HEX M6 85206-H1801 BRACKET-BUMPER REAR SIDE RH 85206-H7100 BRACKET-BUMPER REAR SIDE RH 85207-H1801 BRACKET-BUMPER REAR SIDE LH 85207-H1000 BRACKET-BUMPER REAR SIDE LH 85207-H7100 BRACKET-BUMPER REAR SIDE LH 62663-18000 BOLT-SPECIAL M6 FIX BRACKET TO BUMPER 08915-43610 WASHER-PLAIN M6 08915-13610 WASHER-LOCK M6 FIX BRACKET TO BUMPER 08911-10610 NUT-HEX M6 08110-82010 BOLT-HEX M8X1.25 FIX STAY TOBODY 08915-53810 WASHER-PLAIN M8 FIX STAY TO BODY 08915-13810 WASHER-LOCK M8 62678-21000 SHIM-BRACKET BUMPER SIDE 08110-61810 BOLT-HEX M6 FIX BRACKET TO BODY 08915-53610 WASHER-PLAIN M6 FIX BRACKET TO BODY 08915-13610 WASHER-LOCK M6 FIX BRACKET TO BODY 85020-H1900 OVERRIDER-REAR BUMPER RH 85020-H7000 OVERRIDER-REAR BUMPER RH 85021-H1900 OVERRIDER-REAR BUMPER LH 85021-H7000 OVERRIDER-REAR BUMPER LH 85024-H1900 RUBBER-OVERRIDER 84902-H2500 TRIM-TRUNK FLOOR CENTER 84902-H7100 TRIM-TRUNK FLOOR CENTER (BLUE,LB-211 84902-H7101 TRIM-TRUNK FLOOR CENTER (BEIGE,LH-20 84902-H7102 TRIM-TRUNK FLOOR CENTER (BLACK,LG-13 84902-H1800 TRIM-TRUNK FLOOR CENTER 76983-68400 LOCK-MALE 84903-H7100 TRIM-TRUNK FLOOR RH (BLUE,LB-211 84903-H7101 TRIM-TRUNK FLOOR RH (BEIGE,LH-20 84903-H2501 TRIM-TRUNK FLOOR RH 84903-H1900 TRIM-TRUNK FLOOR RH 84903-H1800 TRIM-TRUNK FLOOR RH 84903-H7102 TRIM-TRUNK FLOOR RH (BLACK,LG-13 84904-H1800 TRIM-TRUNK FLOOR LH 84904-H2500 TRIM-TRUNK FLOOR LH 84904-H7100 TRIM-TRUNK FLOOR LH (BLUE,LB-211 84904-H7101 TRIM-TRUNK FLOOR LH (BEIGE,LH-20 84904-H7102 TRIM-TRUNK FLOOR LH (BLACK,LG-13 08510-51612 SCREW-TAPPING M5 FIX TRIM 1 08963-20540 NUT-SPRING TYPE A M5 FIX TRIM 1 08915-43510 WASHER-PLAIN M5 FIX TRIM 1 76982-68400 ASSY-LOCK FEMALE 08410-41210 SCREW-TAPPING 08915-43410 WASHER-PLAIN 08915-13410 WASHER-LOCK 84905-H1800 STOPPER-TRIM TRUNK FLOOR 84911-H1800 FINISH-TRUNK LID T=1.5 84921-H1900 FINISH-TRUNK SIDE RH T=2 84922-H1800 FINISH-TRUNK SIDE T=1.5 84921-H1800 FINISH-TRUNK SIDE RH T=1.5 84921-H2500 FINISH-TRUNK SIDE RH T=1,5 84922-H1800 FINISH-TRUNK SIDE LH T=1.5 84922-H2500 FINISH-TRUNK SIDE LH T=1.5 84931-H1800 FINISH-TRUNK REAR T=2 84931-H1801 FINISH-TRUNK REAR T=2 84931-H2501 FINISH-TRUNK REAR T=2 66919-H1001 CLIP-TRIM 1 66919-H1099 CLIP-TRIM 1 84932-H1800 MASK-REAR LAMP T=2 84932-H2500 MASK-REAR LAMP T=2 84941-H1800 COVER-TRUNK LID HINGE 84939-H1800 WELT-TRUNK FINISH 87000-H1803 COMP-SEAT RECLINING FRONT (YELLOW) R.H 87000-H4005 COMP.-SEAT RECLINING FRONT (BLACK) R.H. 87000-H4007 COMP.-SEAT RECLINING FRONT (YELLOW) R.H 87000-H4750 COMP.-SEAT RECLINING FRONT (BLACK) R.H 87000-H4751 COMP.-SEAT RECLINING FRONT (YELLOW) R.H 87000-H7100 COMP-SEAT RECLINING FRONT (BLUE) L.H 87000-H7101 COMP-SEAT RECLINING FRONT (BEIGE) L.H 87000-H7102 COMP-SEAT RECLINING FRONT (BLACK) 87000-H1802 COMP-SEAT RECLINING FRONT (BLACK) R.H. 87000-H1902 COMP-SEAT RECLINING FRONT (BLACK) L.H. 87050-H7102 COMP-SEAT RECLINING FRONT (BLACK) L.H 87050-H7101 COMP-SEAT RECLINING FRONT (BEIGE) L.H 87050-H7100 COMP-SEAT RECLINING FRONT (BLUE) L.H. 87050-H4701 COMP-SEAT RECLINING FRONT (YELLOW) L.H 87050-H4700 COMP-SEAT RECLINING FRONT (BLACK) L.H. 87000-H3509 COMP.-SEAT RECLINING FRONT (YELLOW) L.H 87000-H1903 COMP-SEAT RECLINING FRONT (YELLOW) L.H 87000-H3508 COMP.-SEAT RECLINING FRONT (BLACK) L.H. 87300-H7101 ASSY-CUSHION FRONT SEAT (BEIGE) R.H. 87300-H4010 ASSY-CUSHION FRONT SEAT (BLACK) R.H 87300-H7102 ASSY-CUSHION FRONT SEAT (BLACK) R.H 87300-H1802 ASSY-CUSHION FRONT SEAT (BLACK) R.H. 87300-H1803 ASSY-CUSHION FRONT SEAT (YELLOW) R.H 87300-H4007 ASSY-CUSHION FRONT SEAT (YELLOW) R.H 87300-H7100 ASSY-CUSHION FRONT SEAT (BLUE) R.H. 87350-H7102 ASSY-CUSHION FRONT SEAT (BLACK) L.H 87350-H1802 ASSY-CUSHION FRONT SEAT (BLACK) L.H 87350-H1803 ASSY-CUSHION FRONT SEAT (YELLOW) L.H 87350-H4010 ASSY-CUSHION FRONT SEAT (BLACK) L.H 87350-H4007 ASSY-COUSHION FRONT SEAT (YELLOW) L.H 87350-H7100 ASSY-CUSHION FRONT SEAT (BLUE) L.H. 87350-H7101 ASSY-CUSHION FRONT SEAT (BEIGE) L.H. 87600-H7102 ASSY-BACK FRONT SEAT (BLACK)RH 87600-H7101 ASSY-BACK FRONT SEAT (BEIGE)R.H. 87600-H7100 ASSY-BACK FRONT SEAT (BLUE) R.H. 87600-H4007 ASSY-BACK FRONT SEAT(YELLOW)R.H. 87600-H4010 ASSY-BACK FRONT SEAT (BLACK)R.H. 87600-H1802 ASSY-BACK FRONT SEAT (BLACK)R.H. 87600-H1803 ASSY-BACK FRONT SEAT (YELLOW) R.H 87650-H7100 ASSY-BACK FRONT SEAT (BLUE) L.H. 87600-H1902 ASSY-BACK FRONT SEAT (BLACK)L.H. 87600-H1903 ASSY-BACK FRONT SEAT (YELLOW) L.H 87600-H3501 ASSY-BACK FRONT SEAT (YELLOW) L.H 87650-H7101 ASSY-BACK FRONT SEAT (BEIGE)L.H. 87650-H7102 ASSY-BACK FRONT SEAT (BLACK)L.H. 87600-H3500 ASSY-BACK FRONT SEAT (BLACK)L.H. 87320-H1802 TRIM-CUSHION FRONT SEAT (BLACK) R.H. 87320-H1803 TRIM-CUSHION FRONT SEAT (YELLOW) R.H 87320-H7100 TRIM-CUSHION FRONT SEAT (BLUE) R.H. 87320-H7101 TRIM-CUSHION FRONT SEAT (BEIGE) R.H. 87320-H7102 TRIM-CUSHION FRONT SEAT (BLACK) R.H. 87370-H1803 TRIM-CUSHION FRONT SEAT (YELLOW) L.H 87370-H7102 TRIM-BACK FRONT SEAT (BLACK)L.H. 87370-H7100 TRIM-CUSHION FRONT SEAT (BLUE) L.H. 87370-H1802 TRIM-CUSHION FRONT SEAT (BLACK) L.H. 87370-H7101 TRIM-BACK FRONT SEAT (BEIGE)L.H. 87620-H1802 TRIM-BACK FRONT SEAT (BLACK)R.H. 87620-H1803 TRIM-BACK FRONT SEAT (YELLOW) R.H 87620-H7100 TRIM-BACK FRONT SEAT (BLUE) R.H. 87620-H7101 TRIM-BACK FRONT SEAT (BEIGE)R.H. 87620-H7102 TRIM-BACK FRONT SEAT (BLACK)R.H. 87670-H7101 TRIM-BACK FRONT SEAT (BEIGE)L.H. 87670-H7100 TRIM-BACK FRONT SEAT (BLUE) L.H. 87670-H1803 TRIM-BACK FRONT SEAT (YELLOW) L.H 87670-H1802 TRIM-BACK FRONT SEAT (BLACK)L.H. 87670-H7102 TRIM-BACK FRONT SEAT (BLACK)L.H. 87400-H1101 ASSY-DEVICE RECLINING R.H. SEAT 87450-H1101 ASSY-DEVICE RECLINING L.H. SEAT 87500-H1602 ASSY-SLIDE R.H. SEAT 87500-H1603 ASSY-SLIDE R.H. SEAT 87550-H1602 ASSY-SLIDE L.H. SEAT 87550-H1603 ASSY-SLIDE L.H. SEAT 08310-81410 SCREW-MACHINE M8X1.25 SLIDE FIX TO FLOOR 08915-13810 WASHER-LOCK M8 SLIDE FIX TO FLOOR 08915-43810 WASHER-PLAIN M8 SLIDE FIX TO FLOOR 08310-81812 SCREW-MACHINE M8X1.25 FRAME FIX TO SLIDE 08915-13810 WASHER-LOCK FRAME FIX TO SLIDE 87401-H1001 BOLT-SPECIAL CUSHION FIX TO BACK 87408-P2000 BOLT-SPECIAL CUSHION FIX TO BACK 86099-14800 WASHER-PLAIN CUSHION FIX TO BACK 08915-13810 WASHER-LOCK M8 CUSHION FIX TO BACK 08915-43810 WASHER-PLAIN M8 08330-82020 SCREW-MACHINE M8X1.25 DEVICE FIX TO CUSH 08916-43810 WASHER-TOOTH COUNTER SUNK M8 DEVICE FIX 08110-81610 BOLT-HEX M8X1.25 DEVICE FIX TO BACK 08915-13810 WASHER-LOCK M8 DEVICE FIX TO BACK 88300-H1803 ASSY-CUSHION REAR SEAT (YELLOW) 88300-H7100 ASSY-CUSHION REAR SEAT (BLUE) 88300-H7101 ASSY-CUSHION REAR SEAT (BEIGE) 88300-H7102 ASSY-CUSHION REAR SEAT (BLACK) 88300-H1802 ASSY-CUSHION REAR SEAT (BLACK) 88600-H1802 ASSY-BACK REAR SEAT (BLACK) 88600-H1803 ASSY-BACK REAR SEAT (YELLOW) 88600-H7100 ASSY-BACK REAR SEAT (BLUE) 88600-H7101 ASSY-BACK REAR SEAT (BEIG) 88600-H7102 ASSY-BACK REAR SEAT (BLACK) 88631-H7100 PANEL-SEAT BACK 88631-H7101 PANEL-SEAT BACK 88631-H1800 PANEL-SEAT BACK 88631-H7102 PANEL-SEAT BACK H8612-H1400 ASSY-HANDLE REAR SEAT BACK H8619-H1400 WASHER-HANDLE H8613-H1400 WASHER-NYLON H8614-H1400 PIN-LOCK H8615-H1400 SPRING-LOCK H8617-H1400 RUBBER-BUMPER H8618-H1400 WIRE-RELEASE 88320-H7102 TRIM-CUSHION REAR SEAT (BLACK) 88320-H1802 TRIM-CUSHION REAR SEAT (BLACK) 88320-H1803 TRIM-CUSHION REAR SEAT (YELLOW) 88320-H7100 TRIM-CUSHION REAR SEAT (BLUE) 88320-H7101 TRIM-CUSHION REAR SEAT (BEIGE) 88620-H1802 TRIM-BACK REAR SEAT (BLACK) 88620-H1803 TRIM-BACK REAR SEAT (YELLOW) 88620-H7100 TRIM-BACK REAR SEAT (BLUE) 88620-H7101 TRIM-BACK REAR SEAT (BEIGE) 88620-H7102 TRIM-BACK REAR SEAT (BLACK) 88641-H1400 CATCHER-BACK REAR SEAT RH 88641-H1900 CATCHER-BACK REAR SEAT RH 88642-H1400 CATCHER-BACK REAR SEAT LH 88642-H1900 CATCHER-BACK REAR SEAT LH 88643-H1800 SHIM-CATCHER REAR SEAT BACK 88643-H1900 SHIM-CATCHER REAR SEAT BACK 08310-61212 SCREW-MACHINE M5X0.8 08915-13810 WASHER-SPRING LOCK 08310-81210 SCREW-MACHINE M5X0.8 88606-H1800 ASSY-HINGE REAR SEAT BACK 08320-61012 SCREW-MACHINE M6X1.0 08510-41040 SCREW-TAPPING M4 1 08915-43540 WASHER-PLAIN M5 1 88653-H1800 WASHER-PLAIN M5 1 84950-H1825 SET-COVER,TONNEAU 84950-H1800 ASSY-COVER,TONNEAU 84951-H1800 HOOK-COVER 74933-30000 FASTNER 08510-61242 SCREW TO FIX HOOK 08520-41612 SCREW TO FIX FASTENER 86830-H1001 SET-SAFTY BELT FRONT SEAT 3 POINT TYPE 86830-H4600 S/BELT F/SEAT 3 POINT TYPE (AUTO LOCK R 86830-H1000 SET-SAFTY BELT FRONT SEAT 3 POINT TYPE 86820-H1000 SET-SAFTY BELT FRONT SEAT 2 POINT TYPE 86820-H1001 SET-SAFTY BELT FRONT SEAT 2 POINT TYPE 86810-H1000 ASSY-SHOULDER BELT FRONT SEAT 86810-H1001 ASSY-SHOULDER BELT FRONT SEAT 87700-H7001 ASSY-HEAD REST FRONT SEAT (BEIGU) 87700-H7000 ASSY-HEAD REST FRONT SEAT (BLUE) 87700-H1001 ASSY-HEAD REST FRONT SEAT 88830-H1800 SET-SAFTY BELT REAR SEAT 3 POINT TYPE 88830-H1801 SET-SAFTY BELT REAR SEAT 3 POINT TYPE 88820-H1800 SET-SAFETY BELT REAR SEAT 2 POINT TYPE 88820-H1801 SET-SAFETY BELT REAR SEAT 2 POINT TYPE 88820-H4600 SET-SAFETY BELT REAR SEAT 2 POINT TYPE 88810-H1001 ASSY-SHOULDER BELT REAR SEAT 88810-H1000 ASSY-SHOULDER BELT REAR SEAT H4460-H1001 ASSY-CYLINDER LOCK TRUNK LID 62312-H1626 SET-ORNAMENT, RADIATOR GRILLE 62312-H1826 SET-ORNAMENT, RADIATOR GRILLE 62312-H1825 SET-ORNAMENT, RADIATOR GRILLE 84822-H1856 EMBLEM-'DATSUN 1200' TRUNK LID 76854-H1600 EMBLEM-'DATSUN' BODY SIDE 84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID 84822-H1806 EMBLEM-'DATSUN 1200' TRUNK LID 79855-N2200 MARK-NISSAN AUTOMATIC 79202-H1826 SET-ORNAMENT, REAR PANEL 84823-H1000 MARK-DELUXE 76852-H1000 BADGE-DELUXE 62312-H1825 SET-ORNAMENT,RADIATOR GRILLE 62312-H1826 SET-ORNAMENT,RADIATOR GRILLE 08915-43410 WASHER-PLAIN 08915-13410 WASHER-LOCK 08911-10410 NUT 84822-H1856 EMBLEM-'DATSUN 1200'TRUNK LID 76854-H1600 EMBLEM-'DATSUN'BODY SIDE 84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID 84822-H1806 EMBLEM-'DATSUN 1200' TRUNK LID 79855-N2200 MARK-NISSAN AUTOMATIC 79202-H1826 SET-ORNAMENT REAR PANEL 84823-H1000 MARK-DELUXE 76852-H1000 BADGE-DELUXE 80010-H1902 SET-CYLINDER LOCK & KEY FOR STEERING 80010-H1903 SET-CYLINDER LOCK & KEY 80010-H1904 SET-CYLINDER LOCK & KEY WITHOUT HOLD 80010-H1911 SET-CYLINDER LOCK & KEY FOR STEERING 80010-H1912 SET-CYLINDER LOCK & KEY FOR STEERING 80010-H1913 SET-CYLINDER LOCK & KEY 80010-H1914 SET-CYLINDER LOCK & KEY WITHOUT HOLD 80010-H1901 SET-CYLINDER LOCK & KEY FOR STEERING KEY00-00034 KEY-BLANK FOR VOSS TYPE STEERING LOC KEY00-00035 KEY-BLANK FOR VOSS TYPE 96901-H1701 PLATE-MODEL NO.(SPANISH) 96901-H1600 PLATE-MODEL NO.(ENGLISH) 96901-H1700 PLATE-MODEL NO.(ENGLISH) 08510-70812 SCREW-TAPPING M3.5 14806-N2200 LABEL-AUTO CHOKE CONTROL PAINT-DN645 BLUE #645 PAINT-DN006 SUNBIRD ORANGE #006 PAINT-UC003 DARK GREEN #003 PAINT-DN932 RED #932 PAINT-DN820 RED #820 PAINT-DN665 YELLOW #665 PAINT-DN567 BLUE #567 PAINT-DN930 GREEN #930 PAINT-DN703 GREEN #703 PAINT-DN554 LIGHT GREEN #554 PAINT-DN821 WHITE #821 PAINT-DN931 GOLD #931 SBNLL-C0001 COOLANT-NISSAN LONG LIFE 2 LITTER(0.4 SBNLL-C0002 COOLANT-NISSAN LONG LIFE 4 LITTER(0.8 SBNLL-C0003 COOLANT-NISSAN LONG LIFE 18LITTER(3.9 10125-62200 N.C.S. SEALER (1 CARTON-96 99500-H1902 KIT-TOOL 99500-H1901 KIT-TOOL 99500-H1900 KIT-TOOL 99545-16500 WRENCH-WHEEL NUT 99545-89900 WRENCH-WHEEL NUT 99550-H1000 SET-JACK 99550-H7400 SET-JACK 99595-18000 BAG-TOOL 99504-50Y00 BAG-TOOL 99751-H1000 SET-JACK CLAMP 99751-H1001 SET-JACK CLAMP 08310-41012 SCREW-MACHINE M4 08915-13410 WASHER-LOCK ST093-50000 SET-C TOOL ST110-80000 REAMER SET-VALVE GUIDE FOR ENGINE ST113-20000 DRIFT-VALVE GUIDE FOR ENGINE ST116-70000 CUTTER SET-VALVE SEAT FOR ENGINE ST130-40000 PRESS STAND-PISTON PIN FOR ENGINE ST161-10000 DRIFT-CAMSHAFT BEARING FOR ENGINE ST166-80000 PULLER-PILOT BUSH FOR ENGINE ST206-10000 BAR-CLUTCH ALIGNING FOR CLUTCH ST223-50000 DRIFT-MAIN SHAFT BEARING FOR TRANSMIS ST230-30000 PRESS STAND-COUNTER SHAFT BEARING FOR ST230-50000 HEIGHT GAUGE-COUNTER GEAR FOR TRANSMIS ST235-20000 PUNCH-SOLID FOR TRANSMISSION ST236-20000 GUIDE-FORKE ROD FOR TRANSMISSION ST238-20000 PLATE-ADAPTER SETTING FOR TRANSMISSION ST227-30000 PULLER-BEARING FOR TRANSMISSION ST306-00000 DRIFT-DRIVE PINION BEARING FOR DIFFEREN ST311-20000 GAUGE-DRIVE PINION ARANGEMENT F ST315-40000 WRENCH-DRIVE PINION FLANGE FOR DIFFEREN ST325-00000 WEIGHT-SIDE BEARING ADJUST FOR DIFFEREN ST332-20000 DRIFT-SIDE BEARING FOR DIFFERENCIAL ST311-90000 GAUGE-PRELORD FOR DIFFERENCIAL ST312-30000 ASSY-DUMMY SHAFT FOR DIFFERENCIAL ST353-10000 DRIFT-FRONT WHEEL HUB BRG OUTER RACE F ST355-50000 GUIDE-GRAND PACKING FOR AXLE ST371-30000 PULLER-REAR AXLE SHAFT BEARING FOR ST382-70000 PRESS STAND-REAR AXLE SHAFT BEARING FOR ST367-20000 REPLACER SET-TRANSVERS LINK BUSHING FOR ST271-90000 PULLER-STEERING LINKAGE JOINT FOR AX D4160-00011 LEATHER-TOP(BLACK) D4160-00004 LEATHER-TOP(BLACK) D4160-00012 LEATHER-TOP(BLACK) D4160-00005 LEATHER-TOP(BLACK) D4160-00006 LEATHER-TOP(BROWN) D4160-00007 LEATHER-TOP(BLACK) 80610-H1000 ASSY-KEY [with holder] 80610-H1900 ASSY-KEY (WITHOUT HOLDER) 80610-H1001 ASSY-KEY [with holder]
