Left: B110, Center: 1990-1994 B122, Right: JDM B310
Datsun 1200 (B110) uses Type D104 58 mm wide pad, while HB210 and HB310 use similar-looking but wider pads.
Pads: 63.5 mm (2.5 inch) vs 58 mm
B110/HB210/HB310
B110 Pad
Friction pad is 53.1 mm wide, backing plate is 58mm
NOTE: Aftermarket pads tend to be closer to 58mm
Type FMSI D41 41060-H1006 PAD ASS'Y-front disc brake B110 GL, GX, and all USA
Pad size: * Width: 42.5 mm * Thick: 10.3 mm * Length: 53.1 mm * Backing plate: 58 mm
Small Pad (58 mm for 212mm AN18 rotor) Fits: * 1971-1973 B110 USA * B110 JDM GL, GX * 1973-1974 Civic USA * 1976-1978 F10 USA * 1979-1982 N10 (Datsun 310) USA * 1978-May 1979 PA10 Stanza GL, GLX Raybestos PGD104 Wearever D41 Bendix D104 Beck/Arnley 0880100D? ACDELCO 17D104 (18028686) ACDELCO ACD39 ACDELCO ACD122 Akebono AK-37 GDB GDB126 tons of Datsuns & Nissans including: * B15 SR16VE * Y11 SR20VE
1974 HB210 Pad
Type D206 63.4 mm wide for 232 mm rotor (Annette 14/15 A) Original spec is a larger pad than the HB310 unit
Pad specs: * Width: 41.2 mm * Thick: 10 mm * Length: 63.4 mm * Backing plate: 63.5 mm * Material: D864P Nisshinbo 41060-S0100 KIT-PAD DISC BRAKE B210 USA -0475 41060-H7900 KIT-PAD DISC BRAKE B210 USA 0575-0775 41060-S0126 KIT-PAD DISC BRAKE B210 USA -0775 41060-H7926 KIT-PAD DISC BRAKE B210 USA -0775 $52.22 USD Can use the HB310 pad (2.5 inch backing plate)
1974-1975 HB210 (A14 powered B210) PB110 Sunny Excellent 1400 PB210 Sunny Excellent 1400 -1975.9 Skyline C10, C110, KC110 (1500, 1600) 1968-1975.9 Skyline 1800 PC10,KPC110,PC110 1968-1972.8 Laurel 1800 (C130K,C130) 1972.4-1973.9 Honda H1300
1976 HB210 Pad
61.4 mm wide for 245 mm rotor (Annette 14/15 AL) 41060-U6728 KIT-PAD DISC BRAKE B210 USA 0875- $45.02 USD 41060-U6725 KIT-PAD DISC BRAKE B210 USA 0875- Pad specs: * Width: 41.2 mm * Thick: 10 mm * Length: 61.4 mm * Backing plate: 63.5 mm * Material: S21B Akebono
Material was change to S21B for improved durability at high temperatures and frictional resistance compared to D864P.
B310 Pad
Pad for AN-18 (220 mm rotor) 41060-H7825 PAD KIT-DISC BRAKE B310 CAN.A12 1278-
* Beck/Arnley 0820100 Premium Organic $9.18 fits: * B310 A12A Canada (220mm AN18 rotor) [for 12" wheels]
Apparently the B110 pad (58mm) will fit.
HB310 Pad
2.5 inch backing plate width 41060-U6727 PAD KIT-DISC BRAKE A10 USA -0678 $86.98 USD 41060-U6728 PAD KIT-DISC BRAKE B310 USA $45.02 USD
B310 JDM
41060-A1126 PAD KIT-DISC BRAKE A15,GX,A14.S,K AKEBONO S17A $94.27 USD 41060-H8925 PAD KIT-DISC BRAKE A15 8108- AKEBONO S17A* Datsun 610 * Datsun 710 * Nissan Laurel HLC230 * Akebono A-1K * FMSI D37 * MK D1000 * KD-1
41060-M3226 PAD KIT-DISC BRAKE A13S,GL,A12.S,K TOKICO D64P * D41 type (see B110)
41060-H7825 PAD KIT-DISC BRAKE VAN AKEBONO S21B * D146 type
D117 Pad
Type D117 for backing plate 63.5 mm
RockAuto for AN20 rotor fits: * 1974-1978 Datsun B-210 USA * 1975-1979 Civic USA * 1977-1979 Datsun 200SX (S10) * 1979-1982 Datsun 210 (B310) USA * 1975-1976 Datsun 610 * 1975-1977 Datsun 710 Raybestos SGD117/PGD117/RPD117 Beck/Arnley 0870944/0820944/0880944D Wearever D103 Bendix D103 ACDELCO 17D117 (18028692)
D103 also D113. KD-29, MK D1008, AK A-33K
D146 Pad
Type D146 41060-U7426 PAD KIT-DISC BRAKE A10 USA 0778- $86.50 USD * Superceeded by D106M-N2087 Look similar to the Sunny pads, but are not flat on the bottom.
Friction Materials
- FMSI 782-D41
 - FMSI 7059 (D41) Nissan, Honda
 -  FMSI 7039 (D103) Nissan, Honda
- 1976-1982 Cherry
 - 1980-1982 Pulsar
 - 1970-1974 1200
 - 1974-1976 B210
 - 1979-1981 Sunny
 - 1972-1979 Civic
 - 1969-1970 S800
 - FMSI 7040 (D104)
 - FMSI 7064-D113
Nissan Competition
- 41060-H1020 PAD ASSY-Brake FR DS11 AN18 caliper for Long distance driving
 - 41060-H1021 PAD ASSY-Brake FR M59S AN18 caliper for Short-medium distance driving
Sunny Truck
Nissan 41060-G1985 PAD KIT-DISC BRAKE B120 8910- Width: 108.4 mm Height: 39.5 mm Thick: 16.0 mm
Aftermarket: Tokico TN289 Akebono AN-311K Kashiyama D1080-02 NiBK PN2306 Nisshinbo PF-2306 Sumitomo SN831
Tokico TN289 for B120 89/10-, box also says Akebono AN311, カシヤマ D1080-02
Akebono AN-31 1K (AN-311K) A311K
Labeled "Sunny Truck" and "89,10-" and "B12T,GB12T" [sic]
Mystery
109.5
Is this Sunny Truck?
-  Rotor about 8"(203 mm).
- total width of backing plate: 4-5/16 inch (109.5 mm)
 - Same as Subaru Justy for 12" wheel? Type 480
 - not 289, 291, 311, 314
108.5
108.5 x 40.3 mm
 -  108.5 mm total width x 40.3 mm x 14.7 mm thick
- ~4.272" x 1.587" x 0.579" (inch)
 - 4-17/64
 - Apec 379
 -  Interpart GBP666
- CHERRY 1.0 1.3 1.3VAN 1.5 DE 09/82 A 08/86
 - CHERRY 1.5TURBO DE 09/82 A 05/84
 - CHERRY 1.6 DE 09/85 A 08/86
 - SUNNY 1.0 DE 06/86 A 10/88
 - SUNNY 1.3 DE 05/82 A 05/89 + 1.3 KOMBI DE 05/82 A 08/90
 - SUNNY 1.4 DE 10/88 A 12/90
 - SUNNY 1.5 DE 05/82 A 09/88 + 1.5 KOMBI DE 09/83 A 05/86
 - SUNNY 1.6 1.6COUPE DE 08/86 A 05/89
 - SUNNY 1.6I 1.6I COUPE DE 10/88 A 09/90
 - Lockheed/Delphi LP261
 - Bendix 552206/552208
 - Bosch 986469580
 - Ferodo FDB293
 - Lucas/TRW GDB288/GDB988
 - Quinton Hazell BP229
 - Nissan 41060-01A25,41060-01A85,41060-12A25,41060-13A25,41060-13A90,41060-25A25,41060-61A86,41060-62A90,41060-62A92,41060-67A90,41060-89A90,41060-89A91,DA060-13A85
 -  Nissan 41060-77A91AS Pulsar, carb, 1984-1985 to -0485
- Part number 41060-01A25 was superceded by part number 41060-77A91AS
 -  Subaru 725191220 725191631 725191990 725193121
- Justy 1984-2003 front
- USA Nissan Pulsar 1984 2BBL carbureted
- Nissan 41060 77 A91AS
 -  WAGNER PD233/ZD233 or MX275, GUARDIAN 61233, MONROE DX275/CX275, AKEBONO ACT275, Brake Best MKD275, Raybestos RPD266M/RPD266/PGD233/RPD233, Centric 10002750, Beck/Arnley 0891243/0871243/0821243/0881243D/0881243M
- 1983 Nissan Pulsar L4 1.6 Liter Carbureted - VIN P
 - 1983-1986 Nissan Pulsar NX 1.6 Liter Carbureted
 - 1987 Nissan Pulsar NX XE L4 1.6 Liter FI - VIN P (CA16DE)
 - 1988-1990 Nissan Pulsar NX
 - 1982-1990 Nissan Sentra
 - 1984-1985 Nissan Stanza
-  1983 Pulsar 1.6
- http://www.rockauto.com/catalog/x,carcode,1382150,parttype,1000004,EPIsubcategory[235],Front%2BBrake%2BPads,partGroup,14
 -  BECK/ARNLEY 0821243/0871243/0881243M , GUARDIAN 65275, RAYBESTOS SGD275M/PGD275M/, WAGNER 7155A/D275/ZX275, AC/DELCO 17D275M/18028853, MONROE DX275/MX275/CMX275, AKEBONO ACT275,
- http://www.rockauto.com/catalog/x,carcode,1212758,parttype,1000004,EPIsubcategory[235],Front%2BBrake%2BPads,partGroup,14
 - 1989 Sentra 1.6
