The Reverse Lamp Switch is the little switch in the transmission that causes the reverse lamps on the back of the 1200 to light up when you put the gearshift lever in the R position.
4-speed switch Comparo (late vs early):
Green arrow points to reverse lamp switch
Top: 4th gear switch (some newer transmissions 8910-)
Bottom: reverse switch
Reverse lights switch
Top switch (emission controlled models)
Top switch is for emission control. Timing is modified differently in top gear. Not all 56 gearboxes have a Top Switch, but different years do. E.g:
* 1972-up USA
* 1989-up JDM
Top switch is same part number as reverse switch.
1200 5-speed vs 4-speed Comparo
Pink arrow is reverse lamp switch
Custom
When fitting a 5-speed into a 1200, there may not be enough room for the switch.
Plug the hole for the exising switch:
Replace with a shifter switch:
56-series
32005-K121A Rev Lamp B110 $33.70 USD FS4W56L replaced 32005-21101 COMP-SWITCH REVERSE LAMP replaced 32005-K1214 COMP-SWITCH REVERSE LAMP replaced 32005-K1201 COMP-SWITCH REVERSE LAMP replaced 32005-H5000 COMP-SWITCH REVERSE LAMP Also used as 4TH-gear switch
32010-G1651 -8910 B120 FSW56A replaced 32005-21101 SWITCH ASSY-REVERSE LAMP
60-series
32005-K102A Switch Rev Lamp $36.47 USD FS5W60L, FS5W60A replaced 32005-K1002
