AUS range
From Datsun 1200 Club
Category: Documentation
<-- back to Brochures
Title: Datsun 1200 [sedan inset on blue cover]
1972 sedan B110
Format:1 page tri-fold (6 panels) Size:unknown Publication Number:unspecified size: 9 x 9 inches
Comments? Questions? More photos or info? Reply to main forum: POST Brochures wanted
Cover
Datsun 1200
2 door coupe 5 door wagon 4 door deluxe
27405.jpgAlbum 27405 30.jpgAlbum 30
Sheet Front
27403.jpgAlbum 27403
Sheet Back
27404.jpgAlbum 27404
Sedan
4 door deluxe
31.jpgAlbum 31
Datsun 1200 4 door deluxe gives you all the extras the others try to sell you. Small car economy and handling. Big car luxuty and power with rapid acceleration and 90 m.p.h. -- plus top speed. A five bearing crank shaft ensures the smoothest performance. Available with 4-on-the-floor manual, or 3-speed 'T-Bar' automatic. Standard equipment includes: radio, wall-to-wall carpet, 2 speed heater/demister, 2 speed wipers, contoured bucket seats, locking fuel cap, deluxe wheel trims, powerful and reliable 69 b.h.p. engine.
Wagon
5 door wagon
32.jpgAlbum 32
It's like a family car with a room on the back. Big, accessible spaciousness combined with small car economy makes this the greatest value-for-money station wagon available. Counter-balanced rear door opens with a featherlight touch. Comfort for a family of five -- or, with the rear seat folded flat, 54 cu. ft. of space. The biggest wagon in its class. Reliable 69 b.h.p. engine with five bearing crankshaft gives you all the pull you'll ever need -- and you'll still have power to spare.
Coupe
2 door coupe
33.jpgAlbum 33
The Datsun 1200 Coupe has the character and the ability to put a lot of expensive sports cars to shame. Aggressive fastback styling, Italian influenced interior. Reclining bucket seats, luxurious transmission console and a full range of big round instruments including tacho. Front disc brakes. Simulated mag-wheel covers and radial ply tyres all round. The powerful 69 b.h.p. engine with five bearing crankshaft is coupled to a fast 4-on-the-floor transmission, giving real sports performance.
Equipment
all new Datsun 1200 gives you the extras the others try to sell you
34.jpgAlbum 34
Standard Equipment — on all 1200 models
Two speed windscreen wipers. Reversing lights. Lap-sash belts. Ashtray front and rear. Interior bonnet lock. Flo-thru ventilation system. Front, rear and side indicator lights. Contoured bucket seats. Lockable fuel tank. Windscreen washers.
1200 Coupe also includes push button radio. Two-speed heater/demister. Wall to wall carpet. Cigarette lighter. Reclining bucket seats. Central transmission console.
1200 4 door deluxe — also includes push button radio. Two speed heater/demister. Wall to wall carpet. Cigarett lighter.
Safety Equipment — on all 1200 models
The following safety features are standard on 1200 series models. Precise and light steering. Non-glare instruments, windscreen wipers, mirror stays. Padded sun visors. Fresh air ventilation. Heater/demister (sedan, coupe). Large rear tail-light assembly with back-up lights. Impact absorbing body sections. Padded facia panel with soft switches and control knobs. Break-away type rear vision mirror and ash tray. Anti-burst door locks with recessed insided and outside door handles. Seat belts. Zone tempered safety glass. Rigidly anchored seats. Front passenger head restraints. Steering Lock.
[handwritten:] Coupe Auto $2976
[handwritten:] 4 Door Auto $2644
Back Cover - Specifications
you'll love your new Datsun 1200 forever
[stamped]
Benson and Robbins Pty. Ltd.
507-511 PRINCES HIGHWAY, KIRRAWEE
Phone: 521-2033
35.jpgAlbum 35
SPECIFICATIONS
Dimensions 4 Door 2 Door Coupe 5 Door Wagon
Overall length 150.8" 150.4" 152.2"
Overall width 58.9" 59.7" 58.9"
Overall height 54.7" 53.1" 55.3"
Wheelbase 90.6" 90.6" 90.6"
Track front 48.4" 48.4" 48.4"
Track rear 49.0" 49.0" 49.0"
Ground Clearance 6.69" 6.69" 6.69"
Weight Manual 1532 lbs 1520 lbs 1609 lbs
Weight Automatic 1609 lbs
Turning Circle 26.8 ft. 26.8 ft. 26.8 ft.
Fuel Tank Capacity 8.8 gal. 8.8 gal. 8.8 gal.
ENGINE
Four cylinder: OHV
Bore x stroke: 73 x 70mm. (2.87 x 2.6 ins.)
Displacement: 1171 cc. (71.5 cu. ins.)
Horsepower: 69 at 6000 rpm (SAE)
Maximum torque: 70 ft.-lbs. at 4000 rpm.
Five main bearing crankshaft.
Compression ratio: 9.0 to 1
SUSPENSION
Independent front suspension by struts and coil springs with tension rods, telescopic shock absorbers and stabiliser. Rear suspension by semi-elliptic leaf springs with shock absorbers. Semi-floating rear axle with hypoid type final drive.
TRANSMISSION
Manual: Four-speed, all synchro-mesh gearbox with floor change. Single dry disc clutch with diaphragm springs.
Ratios: 1st 3.76:1; 2nd 2.17:1; 3rd 1.40:1; Top 1:1; Reverse 3.64:1. Final drive ratio, 3.90:1.
STEERING
Recirculating ball type. Gear ratio: 15:1. Two-spoked, dished steering wheel.
BRAKES
Coupe:
Front wheel disc brakes. Rear 8" drums. Parking brake is mechanically operated on rear wheels.
4 door and 5 door:
Hydraulic service brakes. Front has two leading shoes and rear leading to trailing shoes. Parking brake is mechanically operated on rear wheels. Drum brakes are eight inches in diameter and have a total lining area of 84.6 sq. ins.
WHEEL AND TYRES
Steel disc wheels. Tyre size: 6.00 x 12 x 4 front and rear.
FUEL SYSTEM
Two barrel, down-draft type carburettor. Mechanical type diaphragm fuel pump. Paper element type air cleaner.
ELECTRICAL SYSTEM
12-volt with alternator and magnetic shift starter motor.
COOLING SYSTEM
Pressurized radiator, belt-driven fan and centrifugal water pump with thermostat.
INSTRUMENTS
Speedometer. Fuel gauge. Water temperature gauge. Oil pressure warning light. Turn signal warning light. Main beam warning light.
Datsun 1200 2 door coupe:
Round instrument cluster including tacho. Speedometer with odometer. Fuel gauge. Water temperature gauge. Oil pressure warning light. Turn signal warning light. Main beam warning light.
Variation
November 1972 version
  • Text added: "Specifications subject to alteration without notice"
  • changed: overall length 4 Door sedan from 150.9" to 150.8"
  • Publication number & date added: "NM 6002 11 72"
  • [stamped] CITY DATSUN PTY. LTD.
27406.jpgAlbum 27406
  • Text added: "Front passenger head restraints. Steering lock."
27407.jpgAlbum 27407
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=AUS_range"
This page has been accessed 3,614 times. This page was last modified 08:01, 8 July 2019. Content is available under Datsun 1200 Club.
