Automatic Shifter
From Datsun 1200 Club
Category: Automatic Transmission
Datsun 1200 with Automatic Transmission was fitted a floor shifter and a console.
Console
The short console was used with the automatic
See also: Console
DX console:
13667.jpgAlbum 13667 20399.jpgAlbum 20399
GL console:
12526_4fe135ad71545.jpgUpload click to view
shift plate
B110%20auto%20bezel%20c.jpg B110%20auto%20bezel%20b.jpg B110%20auto%20bezel%20d.jpg
Shift Control
セレクト レバー
The shift lever unit bolts to the floor. The lever extension is on the right side, and via a Cross Rod, goes under the extreme rear of the transmission, then connects to the Shift Rod which is on the left side of the car.
Automatic Transmission Control
This photo shows the Shift Rod lever on the right side of the transmission. Note the Cross Shaft Bracket (bracket with a hole) bolted to the rear of the transmission.
14851.jpgAlbum 14851
B110
* 34952-H1100 COMP.-BRACKET, cross shaft
B210 is slightly different in that the gearbox rubber insulator incorporates one of the Brackets for the Cross Rod
23297.jpgAlbum 23297
* 11343-H5020 SUPPORT ASS'Y-cross shaft [left side hole]
* Insulator, Mounting [has right-side hole]
23298.jpgAlbum 23298 23299.jpgAlbum 23299 , B210 shift mechanism is simplified in several ways. It may interchange if all the parts are used (bracket + Mount + shifter + shift Rod).
Interior Shift Unit
14853.jpgAlbum 14853
Shift Knob
* 34919-H1100 LEVER-hand B110
* 34920-P4926 KNOB-CONTROL LEVER B210
Bushings
34907-25820 BUSH-HAND LEVER BRACKET
B210: 34430-73001 BUSH-CROSS TUBE (2)
34462-18000 BUSH-SPHERICAL CROSS SHAFT
B210: 34552-89900 INSULATOR
Shift Linkage
Bushings
34462-18000 BUSH-SPHERICAL CROSS SHAFT (2) B110,B210
34552-89900 INSULATOR-ROD (4) B110,B210 [34410A, 34413B]
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Automatic_Shifter"
This page has been accessed 13,089 times. This page was last modified 03:18, 12 December 2023. Content is available under Datsun 1200 Club.
