Collapsible Steering Column
From Datsun 1200 Club
Category: Steering System
Datsun 1200 models for the USA used a Collapsible Steering Column to meet FMVSS safety standards, while most other models got a rigid Steering Column. The column will collapse in an accident, thus helping to avoid striking the driver. The column absorbs forces from both the accident, and if the driver is not wearing a seat belt, to absorb much of the force of the driver hitting the steering wheel. Special care is needed when removing or installing a collapsible column, as a sharp blow (such as dropping it) can cause it to partially collapse.
Collapsible Column
* North America 1200s
* Japan-market GL & GX 1200s
* Late ute Australia?
17660.jpgAlbum 17660
Collapsible Steering Column (under-dash view)
10824.jpgAlbum 10824
Also note that the column is permanently attached to the gearbox so a conversion would involve swapping the entire gearbox/column assembly. The steering post clamps are also special, using aluminum sliding blocks. Be careful to torque the clamp bolts to no more than:
  • clamp-to-column: 5.8 - 7.2 ft-lb
  • clamp-to-pedal box: 10.8 - 13.0 ft-lb
Clamp with steering post sliding blocks
15949.jpgAlbum 15949
48960-H1020 ASSY-CLAMP,STEERING POST [for collapsible column]
non-collapsible B110/B120 CLAMP
24706.jpgAlbum 24706
48324-H1005 CLAMP-upper
48326-H1005 CLAMP-lower
48325-04100 PACKING
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Collapsible_Steering_Column"
This page has been accessed 12,410 times. This page was last modified 21:00, 29 July 2018. Content is available under Datsun 1200 Club.
