Davo's Datsun 1200
From Datsun 1200 Club
Categories: Tech Section | Featured Cars
This is the old Tech Section article
Davo's Datsun 1200
Published by: Davo1200 , On: Sep-26-2002
Scott Davo's Datsun 1200
Type: Coupe
Build Date: 4/71
Engine: A15
Gearbox: Datsun Sunny 5 speed
Diff: 10 bolt Salsbury LSD
Brakes: 10" front, solid disc rear
Suspension: C210 skyline front struts 2" lowered springs, reverse eye 2" lowered rear springs
Extra information:
1. Engine.
The A15 engine has been heavily modified. In now runs an A14 crank, forged race pistons, bored 120thou, larger valves, big ports, double valve springs, twin 45 webers and a rea lumpy cam.
Power is in excess of 150hp. Rev range is above 7500rpm
2. Gearbox
The gearbox is from a late model Sunny. The 5th gear is great but have not used it yet. Clutch is a heavy duty unit. Didnt need a brass button cause the gearbox wont hold up.
3. Diff
The differential is a 10 bolt Salsbury. Very strong and unbreakable. Axles have been cut down to suit the Datsun 1200. Track width is around 1400mm.
4. Brakes
Front rotors are 10" vented discs with Toyota Land Cruiser 4 spot calipers. Rear discs are from standard Skyline as are the calipers. Bendix Metal King pads are also used
5. Suspension
Front struts are c210 skyline parts with modified spring cups, 2" lower springs, Koni shocks Adjustable strut tops, Stanza control arms, 120y sway bar with all new bushes
Rear Suspension are reversed eye springs lowered 2". New bushes all around. Koni adjustable shocks.
6. Interior
Recovered standard dash with extra instruments. Leather Recaro front seats. Sports wheel and short shifter. Stock black trim.
7. Paintwork
All in primer! Color to be chosen at later date.
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Davo%27s_Datsun_1200"
This page has been accessed 5,214 times. This page was last modified 03:10, 28 July 2015. Content is available under Datsun 1200 Club.
