Empson
From Datsun 1200 Club
Category: User Community
Club member twitch3au later jempson
28215.jpgAlbum 28215
Datsun 1000 Coupe
KB10 circa 1969 'APA201' NSW
28215.jpgAlbum 28215 28216.jpgAlbum 28216 28217.jpgAlbum 28217
A-series Turbo Setup
See also: Turbo
archive: A series suck through turbo setup by James Empson (twitch@bigpond.com)
POST A15 draw-thru Turbo :)
It's a suck through setup. The turbo is an IHI RB6, originally off a Mitsubishi Galant 2 litre. The setup consists of a factory A15 exhaust manifold that's had a turbo flange welded onto it, and the standard exhaust flange is welded shut. The inlet manifold has been made from scratch and looks like it should flow evenly, there's a 'U' shaped pipe that connects the turbo to the inlet manifold. There's a 1.5 inch English SU which mounts onto the front of the turbo. The inlet manifold is suited to an Oval port head, the SU is a 1.5 inch. There is a Hobbs switch on the inlet manifold, this could be used to trigger water injection spray.
28218.jpgAlbum 28218 28219.jpgAlbum 28219 28220.jpgAlbum 28220 28221.jpgAlbum 28221 28222.jpgAlbum 28222
Mitsubishi IHI turbo
28223.jpgAlbum 28223 28224.jpgAlbum 28224 28225.jpgAlbum 28225
Oval-port inlet log style manifold
28226.jpgAlbum 28226 28227.jpgAlbum 28227 28228.jpgAlbum 28228
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Empson"
This page has been accessed 2,472 times. This page was last modified 04:18, 17 November 2021. Content is available under Datsun 1200 Club.
