Fuel Part Numbers
From Datsun 1200 Club
Category: Catalog
Raw parts Listing
Also see: Parts Reference Index
USA Catalog
  • 18410-H1601 COMP-WIRE CHOKE CONTROL 1 - superceded
  • 18410-H1602 COMP-WIRE CHOKE CONTROL 1 - 2 18410-H1601 $13.38
  • 18415-H1000 ASSY-KNOB CHOKE CONTROL 1 - superceded
  • 18415-H1001 ASSY-KNOB CHOKE CONTROL 1 SEDAN & COUPE 0171- 2 18415-H1000 $4.72
  • 00951-10400 GROMMET 1 -
  • 21010-18026 ASSY-PUMP WATER WITH GASKET 1 A12 - 2 21010-18003 superceded
  • 21010-18027 ASSY-PUMP WATER WITH GASKET 1 A12 0870-0871 12 21010-18026 superceded
  • 21010-H1025 ASSY-PUMP WATER WITH GASKET 1 A12 0971-1072 22 21010-18027 superceded
  • 21010-H5025 ASSY-PUMP WATER WITH GASKET 1 A12 1172- 2 21010-H1025 superceded
  • BA010-M6626 ASSY-PUMP WATER WITH GASKET 1 A12 1172- 2 21010-H5025 $42.71
  • 21010-18003 ASSY-PUMP WATER 1 A12 - superceded
  • 21022-18003 VANE-WATER PUMP 1 A12 -
  • 21026-73000 ASSY-SEAL WATER PUMP 1 A12 -
  • 21027-73000 ASSY-SEAT 1 A12 -
  • 21035-13202 BEARING-WATER PUMP 1 A12 -
  • 21054-18000 HUB-WATER PUMP 1 A12 -
  • 21014-18000 GASKET-WATER PUMP COVER 1 A12 -
  • 08911-10810 NUT-HEX M8 FIXING WATER PUMP 3 A12 -
  • 08110-84810 BOLT-HEX M8 FIXING WATER PUMP 2 A12 -
  • 08110-85010 BOLT-HEX M8 FIXING WATER PUMP 2 A12 1172- 2 08110-84810
  • 08915-13810 WASHER-LOCK FIXING WATER PUMP 5 A12 -
  • 21051-18000 PULLEY-FAN & WATER PUMP 1 A12 -
  • 21060-H1001 FAN-COOLING 1 A12 - $24.86
  • 21060-A4605 FAN-COOLING D=330 FOR TROPICAL USA 1 OP A12 CRANK - superceded
  • 21060-N0100 FAN-COOLING,FOR TROPICAL USE 1 OP.A12 - 2 21060-A4605 $24.86
  • 08120-62010 BOLT-HEX FIXING FAN 4 A12 -
  • 21069-21000 WASHER-COCK FIXING FAN 2 A12 -
11720-G0300 BELT-FAN L=838 1 A12 - 11720-18002 $8.88
  • 11720-18002 BELT-FAN L=838 1 A12 - superceded
  • 21400-H1900 ASSY-RADIATOR 1 - 2 21400-H1002 NLA
  • 21400-H1003 ASSY-RADIATOR 1 A12 0871- 2 21400-H1900 NLA
  • 21400-H1002 ASSY-RADIATOR 1 - NLA
  • 21430-10600 ASSY-CAP 1 - superceded
21430-89902 ASSY-CAP PADIATOR 1 A12 1272- 21430-U0100 $10.83
  • 21430-U0100 ASSY-CAP PADIATOR 1 A12 1272- 2 21430-10600 superceded
  • 21480-18000 HANDLE-DRAIN COCK 1 -
  • 21481-18000 PACKING-DRAIN COCK 1 -
  • 08110-61662 BOLT-HEX,WITH WASHER 4 -
  • 21501-H1000 HOSE-RADIATOR,UPPER 1 - $4.28
  • 21503-H1000 HOSE-RADIATOR,LOWER 1 - superceded
  • 21506-H1101 ASSY-HOSE,RADIATOR,LOWER,FORHEATER 1 OP. 0970- 21503-H1000,21503-H1100,21504-H1100 $10.74
  • 21503-H1100 HOSE-RADIATOR,LOWER,FRONT FOR HEATER 1 OP. -870 0 superceded
  • 21504-H1100 HOSE-RADIATOR,LOWER,REAR FORHEATER 1 OP -870 0 superceded
  • 08723-13600 CLAMP-HOSE 4 -
27075-H1000 CONNECTOR-HEATER 1 OP. - 27075-27700 $7.48
  • 27075-27700 CONNECTOR-HEATER 1 OP. - superceded
  • 21475-H2300 SHROUD-RADIATOR UPPER 1 AUTOMATIC - $18.71
  • 21475-H2300 SHROUD-RADIATOR,UPPER FOR HEAVY DUTY S 1 OP. - $18.71
  • 21476-H2300 SHROUD-RADIATOR,LOWER 1 AUTOMATIC - $20.40
  • 21476-H2300 SHROUD-RADIATOR,FOR HEAVY DUTY SPEC 1 OP. - $20.40
  • 08513-51612 SCREW-TAPPING M5 6 -
  • 08915-43510 WASHER-PLAIN 6 -
  • 08963-10510 NUT-SPRING M5 4 -
  • 11223-H1000 INSULATOR-ENGINE MOUNTING FRONT 2 A12 - $9.53
  • 11221-H1000 BRACKET-ENGINE MOUNTING FRONT RH 1 A12 -
  • 11222-H1001 BRACKET-ENGINE MOUNTING FRONT LH 1 A12 -
  • 08915-53810 WASHER-PLAIN FIXING INSULATOR TO 8 A12 -
  • 08915-23810 WASHER-LOCK FIXING INSULATOR TO BRACKET 8 A12 -
  • 08911-20810 NUT-HEX FIXING INSULATOR TO BRACKET 8 A12 -
  • 11321-H1000 ASSY-INSULATOR ENGINE MOUNTING REA 1 A12 MANUAL - $26.39
  • 11321-H1020 ASSY-INSULATOR ENGINE MOUNTING REA 1 A12 AUTOMATIC - $40.64
  • 11322-H1002 MEMBER-ENGINE MOUNTING REAR 1 A12 MANUAL - NLA
  • 11322-H1020 MEMBER-ENGINE MOUNTING REAR 1 A12 AUTOMATIC - NLA
  • 08110-61410 BOLT-HEX M6 FIXING INSULATOR TO MEMBER 4 A12 -
  • 08915-13610 WASHER-SPRING LOCK M6 INSULATOR TO 4 A12 -
  • 08911-10610 NUT-HEX M6 4 A12 -
  • 08154-02510 BOLT-HEX MEMBER TO BODY FIX 2 A12 -
  • 08915-14010 WASHER-SPRING LOCK TO BODY FIX 2 A12 -
  • 08915-44010 WASHER-PLAIN M10 TO BODY FIX 2 A12 -
  • 11335-18000 BOLT-ENGINE MOUNTING REAR INSULATOR TO 2 A12 MANUAL -
  • 11335-20300 BOLT-ENGINE MOUNTING REAR INSULATOR TO 2 A12 AUTOMATIC -
  • 08915-14010 WASHER-SPRING LOCK M10 2 A12 -
  • 08911-14010 NUT-HEX M10 2 A12 -
  • 62611-H1000 COVER-UNDER,FRONT 1 A12 - NLA
  • 08915-43610 WASHER-PLAIN 4 A12 -
  • 08915-13610 WASHER-LOCK 4 A12 -
  • 08110-62010 BOLT 4 A12 -
  • 16010-H1901 ASSY-CARBURETOR 1 A12 EXHAUST & EVAPO - 2 16010-H1900 superceded
  • 16010-H1902 ASSY-CARBURETOR HITACHI DCG306-3A 1 A12 EXHAUST & EVAPO 1070- 2 16010-H1901, 16010-H1602 $243.83
  • 16010-H1900 ASSY-CARBURETOR 1 A12 EXHAUST & EVAPO -
  • 16118-H1910 ASSY-CHAMBER FLOAT 1 A12 EXHAUST & EVAPO -
  • 16145-91460 SPRING-IDLE ADJUST SCREW 1 A12 EXHAUST & EVAPO -
  • 16145-50000 SPRING-THROTTLE ADJUST SCREW 1 A12 EXHAUST & EVAPO -
  • 16129-14811 SCREW-THROTTLE ADJUST 1 A12 EXHAUST & EVAPO - 2 16129-25715
  • 16129-25715 SCREW-THROTTLE ADJUST SCREW 1 A12 EXHAUST & EVAPO - superceded
  • 16455-H6200 SET-GASKET 1 A12 EXHAUST & EVAPO - 2 16455-H1000
  • 16144-B0815 SCREW-IDLE ADJUST SCREW 1 A12 EXHAUST & EVAPO -
  • 16082-18010 PLATE-ADJUST THROTTLE 1 A12 EXHAUST & EVAPO -
  • 16133-H1000 LEVER-STARTING 1 A12 EXHAUST & EVAPO -
  • 16116-18010 SLEEVE 1 A12 EXHAUST & EVAPO -
  • 16134-H1910 LEVER-THROTTLE 1 A12 EXHAUST & EVAPO -
  • 16236-H1910 LEVER (A) 1 A12 EXHAUST & EVAPO -
  • 16116-H1910 SLEEVE (A) 1 A12 EXHAUST & EVAPO -
  • 16249-H1910 LEVER 1 A12 EXHAUST & EVAPO -
  • 16034-19915 JET-MAIN #98 1 A12 EXHAUST & EVAPO -
  • 16135-33815 JET-MAIN #135 1 A12 EXHAUST & EVAPO -
  • 16272-36710 PLUG-DRAIN 2 A12 EXHAUST & EVAPO -
  • 16059-14810 VALVE-POWER #60 1 A12 EXHAUST & EVAPO -
  • 16148-H1000 SPRING-PISTON RETURN 1 A12 EXHAUST & EVAPO -
  • 16151-H1000 PISTON 1 A12 EXHAUST & EVAPO -
  • 16025-H1000 TUBE-EMULSION P 1 A12 EXHAUST & EVAPO - superceded
  • 16026-25710 TUBE-EMULSION S 1 A12 EXHAUST & EVAPO -
  • 16026-B0810 TUBE-EMULSION S 1 A12 EXHAUST & EVAPO - 2 16026-25710
  • 16050-18010 BLEED-MAIN AIR #80 2 A12 EXHAUST & EVAPO -
  • 16171-25710 WEIGHT-INJECTOR 1 A12 EXHAUST & EVAPO -
  • 16055-14811 JET-SLOW #43 1 A12 EXHAUST & EVAPO -
  • 16054-B0810 JET-SLOW #50 1 A12 EXHAUST & EVAPO -
  • 16011-H1600 ASSY-CHOKE CHAMBER 1 A12 EXHAUST & EVAPO - superceded
  • 16011-H1601 ASSY-CHOKE CHAMBER 1 A12 EXHAUST & EVAPO - 2 16011-H1600
  • 16204-08000 BLEED-SLOW AIR #100 1 A12 EXHAUST & EVAPO -
  • 16213-08000 BLEED-SLOW AIR #220 1 A12 EXHAUST & EVAPO -
  • 16052-85060 BLEED-SLOW AIR #200 1 A12 EXHAUST & EVAPO - 1 16213-08000
  • 16098-25710 FILTER 1 A12 EXHAUST & EVAPO -
  • 16101-H1000 VALVE-NEEDLE 1 A12 EXHAUST & EVAPO -
  • 16066-18010 SHAFT-FLOAT 1 A12 EXHAUST & EVAPO -
  • 16061-18010 FLOAT 1 A12 EXHAUST & EVAPO -
  • 16307-04000 COVER-PUMP 1 A12 EXHAUST & EVAPO -
  • 16302-H1910 LEVER-PUMP 1 A12 EXHAUST & EVAPO -
  • 16305-19915 SHAFT-PUMP LEVER 1 A12 EXHAUST & EVAPO -
  • 16452-H1000 SPRING-PUMP LEVER 1 A12 EXHAUST & EVAPO -
  • 16453-H1000 WASHER (T=2MM) 1 A12 EXHAUST & EVAPO -
  • 16155-H1910 ARM-THROTTLE 1 A12 EXHAUST & EVAPO -
  • 16161-H1911 HANGER-SPRING 1 A12 EXHAUST & EVAPO 1170- 2 16161-H1910
  • 16161-H1910 HANGER-SPRING 1 A12 EXHAUST & EVAPO - superceded
  • 16165-H1600 ARM-CHOKE WIRE 1 A12 EXHAUST & EVAPO -
  • 16160-H1001 SPRING-THROTTLE RETURN (FOR 16010-H 1 A12 EXHAUST & EVAPO 1070- 2 16160-H1000
  • 16160-H1000 SPRING-THROTTLE RETURN 1 A12 EXHAUST & EVAPO - superceded
  • 16248-H1000 ROD-CHOKE CONNECTOR 1 A12 EXHAUST & EVAPO -
  • 16143-H1910 ROD-PUMP 1 A12 EXHAUST & EVAPO -
  • 16141-18010 ROD-CONNECTOR 1 A12 EXHAUST & EVAPO -
  • 16262-H1910 DIAPHRAGM-SURVO 1 A12 EXHAUST & EVAPO -
  • 16455-H1000 SET-GASKET 1 A12 EXHAUST & EVAPO - superceded
  • 16475-H1910 SCREW & WASHER SET B 1 A12 EXHAUST & EVAPO -
  • 16465-H1000 SCREW & WASHER SET A 1 A12 EXHAUST & EVAPO -
  • 16009-H1910 KIT-REPAIR A CARBURETOR 1 A12 EXHAUST & EVAPO - superceded
  • 16009-H7000 KIT-REPAIR A CARBURETOR 1 A12 EXHAUST & EVAPO - 2 16009-H1910 superceded
  • 16009-H6200 KIT-REPAIR A CARBURETOR 1 A12 EXHAUST & EVAPO - 2 16009-H7000
  • 16307-04000 PUMP-COVER 1 A12 EXHAUST & EVAPO -
  • 16009-H1911 KIT-REPAIR B CARBURETOR 1 A12 EXHAUST & EVAPO -
  • 16129-25715 THROTTLE ADJUST SCREW 1 A12 EXHAUST & EVAPO - superceded
  • 16129-14811 THROTTLE ADJUST SCREW 1 A12 EXHAUST & EVAPO - 2 16129-25715
  • 16144-B0815 IDLE ADJUST SCREW 1 A12 EXHAUST & EVAPO -
  • 16101-H1000 NEEDLE VALVE 1 A12 EXHAUST & EVAPO -
  • 16066-18010 FLOAT SHAFT 1 A12 EXHAUST & EVAPO -
  • 16453-H1000 WASHER 1 A12 EXHAUST & EVAPO -
  • 16010-H3901 ASSY-CARBURETOR (DCH306-1A) 1 A12,MANUAL - 2 16010-H3900
  • 16010-H3902 ASSY-CARBURETOR (DCH306-1B) 1 A12,MANUAL -672 22 16010-H3901
  • 16010-H7000 ASSY-CARBURETOR (DCH306-4) 1 A12,MANUAL 0772- 0 16010-H3902
  • 16010-H3920 ASSY-CARBURETOR (DCH306-3) 1 A12,AUTO -
  • 16010-H3921 ASSY-CARBURETOR (DCH306-3A) 1 A12,AUTO - 2 16010-H3920
  • 16010-H3922 ASSY-CARBURETOR (DCH306-3B) 1 A12,AUTO -672 22 16010-H3921
  • 16010-H7100 ASSY-CARBURETOR (DCH306-5) 1 A12,AUTO 0772- 0 16010-H3900
  • 16010-H3900 ASSY-CARBURETOR (DCH306-1) 1 A12,MANUAL -
  • 16011-H7011 ASSY-CHAMBER,CHOKE 1 A12,MANUAL 0772- 0 16011-H3910
  • 16011-H3920 ASSY-CHAMBER,CHOKE 1 A12,AUTO -672 2
  • 16011-H3910 ASSY-CHAMBER,CHOKE 1 A12,MANUAL -672 2
  • 16011-H7111 ASSY-CHAMBER,CHOKE 1 A12,AUTO 0772- 0 16011-H3920
  • 16182-H3920 POT-DASH 1 A12,AUTO -
  • 16302-H3910 LEVER-PUMP 1 A12 -
  • 16258-H3920 HOLDER-DASH POT 1 A12,AUTO -
  • 16143-H3910 ROD-PUMP 1 A12 -
  • 16262-H3910 DIAPHRAGM-SERVO 1 A12 -
  • 16118-H3910 ASSY-CHAMBER,THROTTLE 1 A12 -
  • 16118-H3911 ASSY-CHAMBER,THROTTLE 1 A12 -672 22 16118-H3910
  • 16118-H7011 ASSY-CHAMBER,THROTTLE 1 A12 0772- 0 16118-H3911
  • 16145-91460 SPRING-IDLE ADJUST SCREW 1 A12 -
  • 16145-50000 SPRING-THROTTLE ADJUST SCREW 1 A12 -
  • 16129-25710 SCREW-THROTTLE ADJUST 1 A12 -
  • 16129-25715 SCREW-THROTTLE ADJUST 1 A12 -672 22 16129-25710
  • 16114-H7010 SCREW-THROTTLE ADJUST 1 A12 0772- 0 16129-25715
  • 16144-M0110 SCREW-IDLE ADJUST 1 A12 -672 2
  • 16144-H7010 SCREW-IDLE ADJUST 1 A12 0772- 0 16144-M0110
  • 16147-E6600 CAP-IDLE LIMITTEY 1 A12 1070-0672 2
  • 16082-H3910 PLATE-ADJUST 1 A12 -672 2
  • 16082-H7010 PLATE-ADJUST 1 A12 0772- 0 16082-H3910
  • 16116-H3910 SLEEVE(B) 1 A12 -
  • 16128-H3910 LEVER-FIRST IDLE 1 A12 -
  • 16249-H3910 LEVER-OPENER 1 A12 -
  • 16389-H7010 COVER-THERMO 1 A12 0772- 0 16389-H3910 $40.45
  • 16389-H3910 COVER-THERMO 1 A12 -672 2
  • 16267-H3910 PIPE-VACUUM 1 A12,MANUAL -
  • 16267-H3920 PIPE-VACUUM 1 A12,AUTO -
  • 16161-H1911 HANGER-SPRING 1 A12,MANUAL -672 2
  • 16161-H7010 HANGER-SPRING 1 A12,MANUAL 0772- 0 16161-H1911
  • 16134-H1910 LEVER-THROTTLE 1 A12,MANUAL -
  • 16134-H3920 LEVER-THROTTLE 1 A12,AUTO -
  • 16116-H1910 SLEEVE(A) 1 A12 -
  • 16236-H1910 LEVER 1 A12 -
  • 16452-H1000 SPRING-PUMP LEVER 1 A12 -
  • 16453-H1000 WASHER 1 A12 -
  • 16025-H1000 TUBE-EMULSION(P) 1 A12 -
  • 16160-H1910 SPRING-THROTTLE RETURN 1 A12 -
  • 16171-25710 WEIGHT-INJECTOR 1 A12 -672 2
  • 16171-H7010 WEIGHT-INJECTOR 1 A12 0772- 0 16171-25710
  • 16061-18010 FLOAT 1 A12 -
  • 16026-B0810 TUBE-EMULSION(S) 1 A12 -
  • 16151-H1000 PISTON-POWER 1 A12 1070-
  • 16148-H1000 SPRING-PISTON RETURN 1 A12 -
  • 16141-18010 ROD-CONNECTING 1 A12 -
  • 16305-19915 SHAFT-PUMP LEVER 1 A12 -
  • 16307-04000 COVER-PUMP 1 A12 -
  • 16272-36710 PLUG-DRAIN 2 A12 -
  • 16066-18010 SHAFT-FLOAT 1 A12 -
  • 16101-H1000 VALVE-NEEDLE 1 A12 -
  • 16098-25710 FILTER 1 A12 -
  • 16029-18010 WASHER 1 A12 -
  • 16065-H1010 SCREW 1 A12 -
  • 16033-L0101 JET-MAIN #97 1 A12 -672 2
  • 16033-H7010 JET-MAIN #95 1 A12 0772- 0 16033-L0101
  • 16043-25715 JET-MAIN #140 1 A12 -
  • 16055-14811 JET-SLOW #43 1 A12 -
  • 16054-B0810 JET-SLOW #50 1 A12 -
  • 16050-18010 BLEED-SLOW AIR #80 2 A12 -
  • 16204-08000 BLEED-SLOW AIR #100 1 A12 -
  • 16051-H3910 BLEED-SLOW AIR #215 1 A12 -
  • 16059-H3910 VALVE-POWER #50 1 A12 -671 1
  • 16059-H3911 VALVE-POWER #45 1 A12 0771-0672 22 16059-H3910
  • 16059-14810 VALVE-POWER #60 1 A12 0772- 2 16059-H3911
  • 16196-H7010 ASSY-CUT,FUEL 1 A12 0772-1072 2
  • 16196-H7011 VALVE-ANTI DIESELING SOLENOID 1 A12 1172- 0 16196-H7010
  • 16455-H1000 KIT-GASKET 1 A12 -672 2
  • 16455-H6200 KIT-GASKET 1 A12 - 2 16455-H1001
  • 16455-H6200 KIT-GASKET 1 A12 - 2 16455-H1000
  • 16455-H1001 KIT-GASKET 1 A12 0772- 2 16455-H1000
  • 16475-H3910 KIT-SCREW & WASHER(B) 1 A12 -1072 2
  • 16475-H7010 KIT-SCREW & WASHER (B) 1 A12 1172- 0 16475-H3910
  • 16465-H3910 KIT-SCREW & WASHER(A) 1 A12 -
  • 16009-H1910 KIT-REPAIR A, CARBURETOR 1 A12 -672 2
  • 16009-H7000 KIT-REPAIR A,CARBURETOR 1 A12 0772- 2 16009-H1910
  • 16009-H6200 KIT-REPAIR A CARBURETOR 1 A12 - 2 16009-H7000
  • 16009-H7010 KIT-REPAIR B,CARBURETOR 1 A12 0772- 2 16009-H3910
  • 16009-H3910 KIT-REPAIR B, CARBURETOR 1 A12 -672 2
  • 16500-H3901 ASSY-CLEANER,AIR 1 A12 0771- 5 16500-H3900 superceded
  • 16500-H7000 ASSY-CLEANER,AIR 1 A12 0772- 0 16500-H3901 $185.26
  • 16500-H3900 ASSY-CLEANER,AIR 1 A12 0671-0771 1 superceded
  • 01237-00011 NUT-WING 1 A12 0671- superceded
  • 16551-08000 NUT-WING 1 A12 - 2 01237-00011
  • 16510-H3900 ASSY-MOTOR,VACUUM 1 A12 0671- $42.05
16580-01B01 ASSY-SENSOR,TEMPERATURE 1 A12 16580-H3900 $44.69
  • 16580-H3900 ASSY-SENSOR,TEMPERATURE 1 A12 0671- superceded
  • 16582-H3900 CLAMP-SENSOR & TUBE 1 A12 0671-
  • 22318-C0601 TUBE-VACUUM MOTOR TO TUBE L=200 1 A12 0671-
  • 22318-C0601 TUBE-VACUUM CONTROL L=320 1 A12 0671-
  • 16573-H1001 SUPPORT-AIR CLEANER 1 A12 0671-
  • 16574-H1001 SUPPORT-AIR CLEANER,FRONT 1 A12 0671-
  • 08120-61210 BOLT 5 A12 0671-
  • 08915-13610 WASHER-LOCK 5 A12 0671-
  • 08915-43610 WASHER-PLAIN 2 A12 0671-
  • 08915-53610 WASHER-PLAIN 1 A12 0671-
  • 16530-B3901 DUCT-COVER TO AIR CLEANER 1 A12 0671-
  • 08723-14400 CLAMP-DUCT 2 A12 0671-
  • 16590-H3900 ASSY-COVER,EXHAUST MANIFOLD 1 A12 0671-
  • 08190-81210 BOLT 3 A12 0671-
  • 08915-43810 WASHER-PLAIN 3 A12 0671-
  • 08915-13810 WASHER-LOCK 3 A12 0671-
  • 14896-25600 BAND-HOSE 1 A12 0671-
  • 14875-H1900 CONNECTOR-VACUUM 1 A12 0671-
  • 17201-H1902 ASSY-TANK FUEL 40L 1 SEDAN EVAPO 0570- 2 17201-H1901 superceded
  • 17201-H2800 ASSY-TANK FUEL 40L 1 SEDAN EVAPO 1070- 2 17201-H1902 $250.69
  • 17201-H1901 ASSY-TANK FUEL 40L 1 SEDAN EVAPO - superceded
  • 17342-18000 RING-O 1 SEDAN -
  • 17343-H1001 PLATE-LOCK 1 SEDAN -
  • 17343-14801 PLATE-LOCK 1 SEDAN - 2 17343-H1001
  • 25060-H1900 GAUGE-FUEL TANK 1 SEDAN EVAPO -
  • 17312-14800 PACKING-DRAIN 1 SEDAN -
  • 17312-H1000 PACKING-DRAIN 1 SEDAN - 2 17312-14800
  • 17312-P0101 PACKING-DRAIN 1 SEDAN 1070- 2 17312-H1000
  • 17312-P0102 PACKING-DRAIN 1 SEDAN 1070- 2 17312-P0101
  • 08931-44210 PLUG 1 SEDAN -
  • 17310-H1000 PLUG-DRAIN 1 SEDAN - 2 08931-44210
  • 17310-P0100 PLUG-DRAIN 1 SEDAN 1070- 2 17310-H1000
  • 17251-H1900 CAP-FILLER 1 SEDAN - superceded
  • 17251-H1000 CAP-FILLER 1 SEDAN EVAPO 0570- 2 17251-H1900 superceded
  • 17251-H1900 CAP-FILLER 1 SEDAN EVAPO 0672- 2 17251-H1000 superceded
  • 17251-H1901 CAP-FILLER 1 SEDAN EVAPO 0672- 2 17251-H1900 superceded
  • 17251-H1902 CAP-FILLER 1 SEDAN EVAPO 0173- 2 17251-H1901 $22.62
  • 17264-18000 PACKING 1 SEDAN -
  • 17220-H1901 TUBE-FILLER UPPER 1 SEDAN EVAPO -
  • 17222-H1000 NECK-FILLER 1 SEDAN - $3.43
  • 17221-H1000 PACKING FILLER NECK 1 SEDAN -
  • 08310-40812 SCREW 3 SEDAN EVAPO -
  • 17229-H1900 HOSE-FILLER 1 SEDAN EVAPO - $29.26
  • 08723-15800 CLAMP-HOSE 2 SEDAN EVAPO -
  • 08360-82014 BOLT WITH LOCK WASHER 4 SEDAN -
  • 08915-53810 WASHER-PLAIN 4 SEDAN -
  • 17314-H1000 GROMMET 1 SEDAN -
  • 17350-H1900 ASSY-TANK RESERVOIR 1 SEDAN EVAPO -
  • 17351-H1900 CONNECTOR-3 WAY 1 SEDAN EVAPO -
  • 17351-H1901 CONNECTOR-3 WAY 1 SEDAN EVAPO - 2 17351-H1900
  • 17352-H1901 SEPARATOR 1 SEDAN EVAPO -
  • 17352-H1902 SEPARATOR 1 SEDAN EVAPO 0570- 2 17352-H1901
  • A8742-20040 HOSE-FUEL RUBBER (10X17X2.2M) 1 SEDAN EVAPO - 2 08742-20040
  • 08742-20040 HOSE-FUEL RUBBER (10X17X2.2M) 1 SEDAN EVAPO - 2 A7515-H1900
  • A7515-H1900 HOSE-FUEL RUBBER(10X16DX5M) 1 SEDAN EVAPO -
  • A7515-H1800 HOSE-FUEL RUBBER(6X13.5X5M) 1 SEDAN EVAPO -
  • 08742-20020 HOSE-FUEL RUBBER (6X13.5X2.2M 1 SEDAN EVAPO - 2 A7515-H1800
  • 08723-11400 CLAMP-HOSE 1 14 SEDAN EVAPO -
  • 16439-22100 CLAMP-HOSE 1 14 SEDAN EVAPO - 2 08723-11400
  • 17230-H1900 HOSE-FILLER 2ND 1 SEDAN EVAPO - superceded
  • 17230-H1901 HOSE-FILLER INNER 1 SEDAN EVAPO - 2 17230-H1900 $8.50
  • 08723-13600 CLAMP-HOSE 1 SEDAN EVAPO -
  • 08723-11400 CLAMP-HOSE 2 SEDAN EVAPO -
  • 16439-22100 CLAMP-HOSE 2 SEDAN EVAPO - 2 08723-11400
  • 17361-H1922 TUBE-EVAPO 1 SEDAN EVAPO AUTOMATIC -
  • 17361-H1902 TUBE-EVAPO 1 SEDAN EVAPO MANUAL -
  • 17361-H1903 TUBE-EVAPO 1 SEDAN EVAPO MANUAL - 0 17361-H1902
  • 17201-H1802 ASSY-TANK FUEL 38L 1 COUPE EVAPO -
  • 17342-18000 RING-"O" 1 COUPE -
  • 17343-H1001 PLATE-LOCK 1 COUPE -
  • 17343-14801 PLATE-LOCK 1 COUPE - 2 17343-H1001
  • 25060-H1800 GAUGE-FUEL TANK 1 COUPE -
  • 17312-P0101 PACKING-DRAIN 1 COUPE - 2 17312-H1000
  • 17312-P0102 PACKING-DRAIN 1 COUPE - 2 17312-P0101
  • 17312-H1000 PACKING-DRAIN 1 COUPE - 2 17312-14800
  • 17312-14800 PACKING-DRAIN 1 COUPE -
  • 17310-H1000 PLUG-DRAIN 1 COUPE - 2 08931-44210
  • 17310-P0100 PLUG-DRAIN 1 COUPE - 2 17310-H1000
  • 08931-44210 PLUG-DRAIN 1 COUPE -
  • 17251-H1902 CAP-FILLER 1 COUPE EVAPO 0173- 2 17251-H1901
  • 17251-H1900 CAP-FILLER 1 COUPE -
  • 17251-H1000 CAP-FILLER 1 COUPE EVAPO 0470- 6 17251-H1900
  • 17251-H1901 CAP-FILLER 1 COUPE EVAPO 0672- 2 17251-H1000
  • 17264-18000 PACKING 1 COUPE -
  • 17220-H1802 HOSE-FILLER UPPER 1 COUPE EVAPO -
  • 17220-H1803 HOSE-FILLER UPPER 1 COUPE EVAPO 0470- 0 17220-H1802
  • 17222-H1000 NECK-FILLER 1 COUPE -
  • 17221-H1000 PACKING FILLER NECK 1 COUPE -
  • 08310-40812 SCREW-MACHIN 3 COUPE -
  • 17229-H1802 HOSE-FILLER 1 COUPE EVAPO -
  • 17228-H1400 GROMMET 1 COUPE -
  • 08723-15800 CLAMP-HOSE 2 COUPE -
  • 17230-H1802 HOSE-FILLER INNER 1 COUPE EVAPO - 2 17230-H1801
  • 17230-H1801 HOSE-FILLER 2ND(NOT ADOPTED) 1 COUPE EVAPO -
  • 08723-13600 CLAMP-HOSE 1 COUPE EVAPO -
  • A7325-H1000 TUBE-VINYLE(10X14DX5M) 1 COUPE -
  • A7515-H1900 TUBE-RUBBER(10X16DX5M) 1 COUPE EVAPO -
  • 08742-20040 TUBE-RUBBER 1 COUPE EVAPO - 2 A7515-H1900
  • 16439-22100 CLAMP-HOSE 2 COUPE - 2 08723-11400
  • 08723-11400 CLAMP-HOSE 2 COUPE -
  • 17324-H1800 GROMMET 1 COUPE EVAPO -
  • 08110-82062 BOLT WITH LOCK WASHER 5 COUPE -
  • 08915-53810 WASHER-PLAIN 5 COUPE -
  • 17350-H1801 ASSY-TANK RESERVOIR 1 COUPE EVAPO -
  • 17350-H1802 ASSY-TANK RESERVOIR 1 COUPE EVAPO 0470- 0 17350-H1801
  • 63140-78500 NUT-JAM 3 COUPE EVAPO -
  • 08410-61610 SCREW 3 COUPE EVAPO -
  • 08915-13610 WASHER-LOCK 3 COUPE EVAPO -
  • 17335-H1801 TUBE-BREATHER RH 1 COUPE EVAPO -
  • 17335-H1802 CONNECTOR 2 COUPE EVAPO 0470- 0 17335-H1801
  • 17336-H1801 TUBE-BREATHER LH 1 COUPE EVAPO -
  • 17515-H1817 HOSE-FUEL FIX FUEL TANK TO EVAPO TANK(L 1 COUPE EVAPO - 2 17230-H1801
  • A7515-H1800 HOSE-FUEL(6X13.5X5M) 1 COUPE EVAPO -
  • 08742-20020 HOSE-FUEL(6X13.5X2200MM) 1 COUPE EVAPO -
  • A7515-H1800 HOSE-FUEL(6X13.5X10M) 1 COUPE EVAPO 0470-
  • 08742-20020 HOSE-FUEL(6X13.5X2200MM) 1 COUPE EVAPO - 2 17230-H1801
  • 08742-20020 HOSE-FUEL (6X13.5X2.2M) 1 COUPE EVAPO - 2 A7515-20020
  • 16439-22100 CLAMP-HOSE 1 16 COUPE EVAPO - 2 68723-11400
  • 08723-11400 CLAMP-HOSE 1 16 COUPE EVAPO -
  • 17351-H1800 CONNECTOR-3 WAY 1 COUPE EVAPO 0470-
  • 17351-H1801 CONNECTOR-3WAY 1 COUPE EVAPO - 2 17351-H1801
  • 17361-H1800 TUBE-EVAPORATION 1 COUPE EVAPO MANUAL -
  • 17361-H1801 TUBE-EVAPORATION 1 COUPE EVAPO MANUAL - 0 17361-H1800
  • 24251-H1801 GROMMET 1 COUPE EVAPO -
  • 00951-10600 GROMMET 2 COUPE EVAPO -
  • 00951-11000 GROMMET 4 COUPE EVAPO -
  • 00951-11200 GROMMET 2 COUPE EVAPO 0470-
  • 46115-C0400 GROMMET 2 COUPE EVAPO 0470-
  • 17337-H1800 PROTECTOR-FUEL HOSE 1 COUPE EVAPO 0470-
  • 24210-89964 CLIP 1 COUPE EVAPO 0470-
  • 74890-H1800 PROTECTOR-FILLER HOSE 1 COUPE EVAPO -
  • 08110-62010 BOLT FIXING PROTECTOR 3 COUPE EVAPO -
  • 08915-23610 WASHER FIXING PROTECTOR 3 COUPE EVAPO -
  • 08915-43610 WASHER FIXING PROTECTOR 3 COUPE EVAPO -
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Fuel_Part_Numbers"
This page has been accessed 3,347 times. This page was last modified 10:20, 7 January 2012. Content is available under Datsun 1200 Club.
