RPM
From Datsun 1200 Club
Category: Engine Mechanical
6400 RPM: Stock engine
6800 RPM: A12 GX Engine
7000 RPM: Aftermarket racing valve springs are needed
8500 RPM: To raise the rpms, we first added a larger oil pump.
9000 rpm: would require worked rods with better rod bolts (or at least new rod bolts all of the time).
9500 PM: RWhen we switched to aftermarket rods we could go to 9500-10,000.
10,000 RPM: Next we found the valve train weaknesses. Make sure to replace the rocker threads with steel inserts. By using rocker tower studs; or going to 10mm bolts, 10,000 was fine with the A12 (9200-9400 with the A14 and A15).
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=RPM"
This page has been accessed 5,723 times. This page was last modified 08:15, 18 December 2009. Content is available under Datsun 1200 Club.
