Strut Specification
From Datsun 1200 Club
Category: Front Axle And Front Suspension
Datsun 1200 (B110) uses 45mm diameter strut tubes, while B210 with discs uses 50.8 as with almost all other Datsuns. Australia-built B210 uses 45mm strut tube with discs.
Measurements
From wetdriftwarrior
441mm: strut tube base (mounting surface) to the top of the strut tube
656mm: strut with Monroe insert uncompressed
459mm: strut with Monroe insert compressed
standard spec. Monroe insert
440mm - compressed.
637mm - uncompreessed
419mm - insert body length
195mm - shaft length from top of insert body to below thread
25mm of thread
Hub and Spindle
Model Diameter (drum type) Diameter (disc type)
B10 N/A N/A
B110 45 mm 45 mm
B210 45 mm early
 ? late
50.8 mm
Aussie: 45mm
B310  ? 50.8 mm
SPINDLE
Spindle B110 disc 1974-1975 disc 1976-1978 A14 B310 A14
D1 ~25 mm 27 mm 32 mm
D2 ~15 mm 17.5 mm 19 mm
L  ? 110 mm 104 mm  ?
HUB
strut sidecap side
Hub B110 disc 1974-1975 disc 1976-1978 A14 B310 A14
D1  ? 50.29 mm 59.13 mm
D2  ? 39.88 mm 45.24 mm
S  ? 50 mm 49 mm
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Strut_Specification"
This page has been accessed 6,940 times. This page was last modified 03:23, 11 March 2013. Content is available under Datsun 1200 Club.
