THE LIGHTWEIGHT HEAVIES
From Datsun 1200 Club
Category: Documentation
<-- back to AUS brochures <-- back to B310 Brochures
Title: THE LIGHTWEIGHT HEAVIES [B310 panel van & 1200 pickup carrying large tyre]
1982.12 commercial vehicles: VB310 & B120 B120
Format:4 page booklet Size:A4 (210 x 297 mm) Publication Number:12 82/DPR 1663/4M
Comments? Questions? More photos or info? Reply to main forum: POST Brochures wanted
28319.jpg#cover 28320.jpg#van 28321.jpg#ute 28326.jpg#specs
cover
THE LIGHTWEIGHT HEAVIES.
28319.jpgAlbum 28319
TAKING THE HIGH COST OUT OF TRUCKING.
NISSAN DATSUN
van
1200cc SUNNY VAN. [B310 panel van]
28320.jpgAlbum 28320
On the inside, this zippy little van is more like a sedan than a hard-working commercial vehicle. With features like push-button radio, colour keyed carpet and individual reclining front bucket seats, business is a positive pleasure. Even the load area features a floor mat. GVM is just 1375kg with an excellent power-to-weight ratio — and economy to match.
ute
1200cc 1/2 TONNE UTILITY.
28321.jpgAlbum 28321
Believe it or not, the Datsun 1200cc ute is the longest selling vehicle currently on the market in Australia — maybe the world. Since they were first launched in 1971, these tried and true utilities have been lugging over a 1/2 a tonne thoughout the length and breadth of the country.
With their steel sides, the GVM of 1315kg belies their toughness. These utes can mix it up with the best of them. And when it comes to economy, there's nothing to touch them.
28327.jpgAlbum 28327 28328.jpgAlbum 28328
specifications
SUNNY VAN SPECIFICATIONS
DATSUN 1200 UTE SPECIFICATIONS
28326.jpgAlbum 28326
Printing Date: Dec. 1982/12 82/DPR 1663/4M
NISSAN DATSUN
Nissan Motor Company (Australia) Pty. Ltd.
Standard Equipment
Laminated windscreen
AM push button radio
Side window demist vents
Front inertia reel seat belts
Individually reclining front bucket seats with
  head-restraints
Steel radial tyres
Loop pile carpet — passenger compartment
Left and right hand side exterior mirrors
Day/Night rear view mirror
Fingertip control stalks for wiper/ washer, lights,
  headlight flasher, indicators, lane change
Quartz clock
Centre console
Tripmeter
Bi-level flow through ventilation system with three
  speed fan
Illuminated heater controls, cigarette lighter,
  ashtray
Hazard flashers
Passenger side package tray
Lockable fuel flap
Armrests on doors
Passenger grab handle
Door operated courtesy light
Rear load area floor mat
Full headlining in load area
Instrumentation
Speedometer with odometer and tripmeter
Quartz clock
Fuel gauge
Temperature gauge
Warning lights for:
- Highbeam
- Brake fluid level
- Park brake
-Oil pressure
- Alternator charge
-Choke
Engine
Type A12, 4 cyl. O.H.V.
Bore x Stroke: 73x 70mm
Displacement: 1171cc
Compression Ratio: 9:1
Transmission
4 speed all synchro floor change
Gear ratios: 1st 3.757:1, 2nd 2.169:1, 3rd 1.404:1,
  Top 1:1. Reverse 3.64:1.
Final drive ratio: 3.889:1.
Suspension
Front: Independent struts with coil springs,
  stabiliser bar and double acting hydraulic
  shock absorbers Rear: Leaf springs
Wheels and Tyres
Wheels: 4.5J x 13 Steel disc
Tyres: 155SR 13 steel belted radials
Fuel System
Carburettor: 2 barrel downdraft
Fuel pump: Mech. Diaphragm
Tank capacity: 47 litres
Steering
Type: Recirculating ball
Ratio: 16.4:1
Turning circle: 10m wall to wall
Turns, lock to lock: 3.5
Electrical System
12 volt
Maintenance free Battery: 40 amp/hour
Alternator: 35 amp
Cooling System
Radiator: Pressurized
Thermostat: Pellet type
Water pump: Centrifugal
Dimensions (Nominal)
Wheel base: 2340 mm
Front track: 1300 mm
Rear track: 1300 mm
O/All length: 3985 mm
O/All width: 1580 mm
O/All height: 1395 mm
Ground clearance: 152 mm
GVM: 1375kg
Kerb weight: 830kg
Total carrying capacity: 545kg*
Brakes
Power assisted dual circuit hydraulic brakes with rear
  pressure proportioning valve
Front: Disc
Rear: Drums with leading and trailing shoes
Engine
Cylinders: 4 in-line, water cooled 4 cycle O.H.V.
Bore and Stroke: 73.0x70.0mm
Compression Ratio: 9.0:1
Fuel System
Tank Capacity: 37 litres
Fuel Pump: Mech. Diaphragm
Carburettor: Dual Barrel, downdraft type
Air Cleaner: Paper Element
 Cooling System
Pressurized radiator, 4 blade fan
Pump Type: Centrifugal
Electrical System
Maintenance free Battery: 12 Volt 40 A.H.
Alternator: 35 amps
Starter: 12V magnetic shift
Clutch
Type and size: 180 mm
Single Dry/Disc with diaphragm spring
Transmission
4 forward speeds, all synchromeshed
Gear Ratios: 1st 3.76, 2nd 2.17, 3rd 1.40,
  4th 1.00, Rev. 3.64
Steering
Recirculating ball type
Gear Ratio: 15.1:1
Turns lock to lock: 3.3
Brake System
Hydraulic service drum brakes with tandem master
  cylinder
Front: Two leading shoes
Rear: Leading and trailing shoes. Parking brake
  mechanically operated on rear wheels
Suspension
Front: Independent strut with coil springs, tension
  rods and stabilizer bar
Rear: Semi-elliptic leaf springs with telescopic
  double acting shock absorbers
Differential ratio: 4.111
Wheels & Tyres
Wheels: Five 4J x 12 steel
Tyre Sizes:
Front: 5.00 x 12 x 4 ply rating.
Rear: 5.00 x 12 x 8 ply rating
Dimensions/Weights
Lengths:
Wheel base 2300 mm.
Front overhang 605 mm.
Rear overhang 925 mm.
Rear deck max. floor length 1670 mm.
Overall length 3845 mm
Widths: Front track 1250 mm.
Rear track 1245 mm.
Rear deck inside width 1285 mm
Width between rear wheelarches 980 mm.
Tailgate aperture width 1160 mm
Overall width (excl. mirrors) 1495 mm
Heights:
Rear deck depth 410 mm.
Rear deck loading height (unladen) 595 mm.
Minimum ground clearance (unladen) 160 mm.
Overall height 1395 mm
Turning circle diameter: Wall to Wall 8.2 m
Weights:
Gross front axle 444 kg.
Gross rear axle 871 kg.
Gross vehicle mass 1315 kg.
Kerb mass 720 kg.
Total carrying capacity: 595 kg*
Standard Equipment
Individual seats with head restraints
2 speed fan boosted heater demister
Collapsible steering column with lock
Retractable lap sash seat belts
Colour keyed passenger car-type interior
Flow through ventilation
Reversible key for door and petrol locking cap
Electrically operated windscreen washers
Interior armrests
2 speed electric windscreen wipers
Cigarette lighter
Electric clock
Centre console
Hazard warning flashers
Driver's door courtesy light
Outside rear vision mirrors
Two sunvisors
Rear window protection bars
Opening quarter vent windows
Rear rubber bumperettes
Tool kit
Instruments
Speedometer, odometer with tenths.
Gauges for fuel level and water temperature.
Warning lights for oil pressure, battery charge,
  high-beam, park brake, brake fluid level
  • Includes driver and passenger
All illustrations, information and specifications presented and referred to in this brochure were correct at the time when the brochure was approved for printing, however Nissan Motor Company (Australia) Ply. Ltd. and/or Motor Manufacturing Company (Australia) Pty. Ltd. reserve(s) the right, subject to the laws of Australia and/or any applicable State or Territory thereof and/or the regulations of any competent Authority which may apply from time to time, at their or its discretion at any time and without prior notice to discontinue or change the models, features, specifications, designs and prices of the products referred to in this brochure and any optional equipment therefore without incurring any liability whatsoever lo any purchaser or prospective purchaser of any of such products. All capacities, measurements, dimensions and weights quoted in this brochure are approximate only. Some of the items referred to herein are optional at extra cost. Some options may be required in combination with other options. Always consult your Datsun Dealer for the latest information on models, specifications, features, prices, options and availability.
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=THE_LIGHTWEIGHT_HEAVIES"
This page has been accessed 1,653 times. This page was last modified 05:34, 26 January 2025. Content is available under Datsun 1200 Club.
