Template:Silvia speedometer
From Datsun 1200 Club
The 71-series gearbox speedometer drive works with the 1200 speedometer cable. If you need a longer cable, the Datsun 810 (200B) cable fits.
If the gearbox has an electronic sender for electronic speedometer, you can unbolt it and bolt in cable drive:
Cable drive (obtain from any 71C gearbox)
Silvia engines do not need the electronic speedometer signal. If it is installed, it can be used for overrun fuel-cut (increased fuel economy) plus the Silvia gauge cluster can be fitted to the 1200 dash.
See Main Article: Electronic Speedometer
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Template:Silvia_speedometer"
This page has been accessed 742 times. This page was last modified 05:37, 30 August 2016. Content is available under Datsun 1200 Club.
