Vacuum
From Datsun 1200 Club
Categories: Brake Modifications | Fuel System
Also See: Vacuum Advance
vacuum reservoir
Since twin Weber manifolds have no Plenum, there is no place to get a steady vacuum signal. The reservoir is usually connected to all four intake runners and acts as a Plenum for vacuum. Connect the brake booster and vacuum gauge to the reservoir.
Larger ones also function as a Vacuum Reserve Canister. So when pulling a long hill you don't run out of vacuum for the brakes. Because vacuum is not made at heavy throttle it stores a little extra as a reserve.
If it's multi carb then you need a vacuum manifold (a tube to each runner connected to single reservoir) . Connect the distributor to the reservoir.
Use a vacuum reservoir about the size of two golf balls
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Vacuum"
This page has been accessed 4,590 times. This page was last modified 09:33, 23 July 2015. Content is available under Datsun 1200 Club.
