510 Parts Donor
From Datsun 1200 Club
Category: Parts Donors
Parts from Datsun Bluebird 510 that fit Sunny.
B10
23164-H0100  	BOLT-SETTING
23153-H0100  	ASSY-NUT,PULLEY
31918-H0100  	ASSY-INHIBITOR SWITCH
31931-H0101  	ASSY-VACUUM,DIAPHRAGM
23127-H0300  	ASSY-COVER,REAR
23230-H0300  	ASSY-DIODE
23133-H0300  	ASSY-HOLDER,BRUSH
23135-H0300  	ASSY-BRUSH(F)
23118-H0300  	ASSY-COVER,FRONT
23236-H0300  	COVER-DIODE
23156-H0300  	ASSY-BOLT,TERMINAL
23247-H0300  	SLEEVE
23131-H0300  	BOLT-THROUGH
23133-H0301  	ASSY-HOLDER,BRUSH
23135-H0301  	ASSY-BRUSH(E)
23131-H0301  	BOLT-THROUGH
B110
16331-H1000  	ASSY-COMPENSATOR
16331-H1000  	ASSY-COMPENSATOR,IDLE
17312-H1000  	DRAIN PLUG PACKING
17310-H1000  	DRAIN PLUG
17312-H1000  	DRAIN PLUG GASKET
A7325-H1000  	FUEL HOSE VINYLE 10X14X10,000
22157-H1000  	ASSY-ROTOR,HEAD
22301-H1000  	VACUUM CONTROL ASSY
22157-H1000  	ROTOR-HEAD
22157-H1000  	HEAD-ROTOR
30537-H1000  	PIN BALL W/DRAWAL LEVER (THREADED TY
43252-H1000  	SEAL-OIL,REAR AXLE SHAFT
A7515-H1800  	FUEL HOSE VINYLE 6X13.5X10.000
A7515-H1800  	FLEXIBLE HOSE C (L=470)
14917-H1902  	TUBE (IDLE COMPENSATOR TO CONNECTOR)
22167-H2300  	CAP CLAMP SET
22136-H2300  	BRAKER PLATE ASSY
22750-H2300  	SCREW SET
22750-H2300  	KIT-SCREW
40052-H2500  	ARM-KNUCKLE RH
40053-H2500  	ARM-KNUCKLE LH
40052-H2501  	ARM-KNUCKLE RH
40053-H2501  	ARM-KNUCKLE LH
13001-H2700  	CAM SHAFT
22119-H2700  	SET-COLLAR
13001-H2700SV	CAM SHAFT
13001-H2710  	CAM SHAFT
65601-H3525  	SET-HOOD LOCK,MALE & FEMALE
65601-H3525  	ASSY-MALE,HOOD LOCK
16510-H3900  	ASSY-MOTOR,VACUUM
16585-H3900  	TUBE (SENSOR TO CONNECTOR)
14959-H3900  	TUBE (SENSOR TO CONNECTOR)
16580-H3900  	ASSY-SENSOR,TEMPERATURE
16582-H3900  	STOPPER
16059-H3910  	VALVE-POWER #150
16059-H3910  	VALVE-POWER #50
30412-21000  	DOWEL-TIMING 9.5 CASE LOCATING
16420-21000  	SPACER-FUEL PUMP
23122-21000  	PACKING
23121-21000  	RETAINER-PACKING
23122-21000  	PACKING
30502-21000  	BEARING-CLUTCH RELEASE
30624-21000  	CUP-PISTON
34410-21000  	TRUNION-GEAR SHAFT ROD
54324-21000  	NUT
54324-21000  	NUT-HEX SELF LOCK
62678-21000  	SHIM-BRACKET
24438-21000  	ROD-BATTERY,FIX
24440-21000  	ROD-BATTERY,FIX
80577-21000  	BOLT-SPECIAL TO FIX STRIKER
80970-21000  	GROMMET-LOCK KNOB
62678-21000  	SHIM-BRACKET BUMPER SIDE FIX BRACKET TO
62678-21000  	SHIM-BRACKET BUMPER SIDE TO FENDER
24438-21000  	ROD-BATTERY FIX A (NOT ADOPTED
24440-21000  	ROD-BATTERY FIX C
16420-21001  	SPACER-FUEL PUMP
23150-21001  	ASSY-PULLEY
23333-21001  	SPRING-BRUSH
80840-21001  	COVER-DRAIN HOLE
17099-21002  	GASKET-FUEL PUMP
23150-21002  	ASSY-PULLEY
74630-21002  	HANDLE-SPARE WHEEL CLAMP
80595-21003  	KNOB-DOOR LOCK
22401-21004  	PLUG-SPARK L44P(HITACHI)
23123-21005  	RETAINER-BEARING
22162-21007  	ASSY-CAP
22401-21007  	PLUG-SPARK L47P(HITACHI)
30537-21010  	PIN-BALL WITHDRAWAL LEVER
41128-21010  	BLEEDER (TOKICO) FOR FORE CYLINDER
41128-21010  	BLEEDER
46038-21011  	CAP-VALVE
41128-21011  	SCREW-BLEEDER
46038-21011  	PLUG-CYLINDER
32005-21100  	COMP-SWITCH REVERSE LAMP
32005-21100  	COMP.-SWITCH,4 TH
32005-21101  	COMP-SWITCH REVERSE LAMP
32005-21101  	COMP-SWITCH,4 TH
65610-21400  	ASSY-FEMALE HOOD LOCK
24420-21401  	FRAME-BATTERY,FIX
76488-21600  	CLIP-SILL MOULDING
00851-21610  	WIRE-LOCK
41128-21900  	SCREW-BLEEDER(NABCO)
44118-21910  	ASSY-LEVER (TOKIKO)
32886-22000  	WASHER-BODY BOLT
22132-22005  	ASSY-CAM
16084-22010  	WASHER
44108-22010  	PISTON-CYLINDER (TOKIKO)
16439-22100  	CLAMP-FUEL TUBE
16439-22100  	CLAMP-HOSE
54313-22127  	OIL-SUSPENSION STRUT (ATSUGI 360C
54313-22128  	OIL-SUSPENSION STRUT (ATSUGI 1000
54313-22129  	OIL-SUSPENSION STRUT (ATSUGI 360C
43066-22500  	SEAT-CONNECTOR BRAKE HOSE
36528-22500  	WASHER-PLAIN
08124-23010  	BOLT-HEX
08124-23010  	BOLT-HEX WITH LOCK WASHER STAY TO HOOD
08134-23510  	BOLT
08915-23610  	WASHER FIXING PROTECTOR
08915-23610  	WASHER-SPRING LOCK
08915-23810  	WASHER-LOCK FIXING INSULATOR TO BRACKET
08915-23810  	WASHER-LOCK M8
08915-23810  	WASHER-LOCK FIXING TRANSMISSION
08915-23810  	WASHER-SPRING LOCK
08915-23810  	WASHER-LOCK UPPER
08915-23810  	WASHER-LOCK LOWER
08915-23810  	WASHER-LOCK REAR
00922-24000  	RING-SNAP
08915-24010  	WASHER-SPRING LOCK M10
08915-24210  	WASHER-SPRING LOCK
08916-24210  	WASHER-TOOTH 12
08911-24610  	NUT
46100-26100  	ASSY-SWITCH BRAKE INDICATOR
32829-26760  	BALL-CHECKING
32829-26760  	BALL-STEEL (7.938)
46056-27260  	SPRING-VALVE INLET (NABCO/TOKIC
46032-27260  	PIN-RELEASE INLET VALVE (NABCO)
46043-27260  	PACKING(NABCO)
46079-27260  	RING-"O"(NABCO)
46070-27260  	RING-SNAP(NABCO/TOKICO)
46100-27260  	COVER-DUST(NABCO/TOKICO)
30611-27260  	SHIM T=1.6MM
30613-27260  	SHIM T=0.5MM
30625-27260  	PISTON
46070-27260  	RING-STOPPER
46042-27260  	PACKING
46079-27260  	PACKING
46042-27260  	PACKING-VALVE
46079-27260  	GASKET-PISTON STOPPER
20602-27700  	NUT-FIXING TUBE END
27075-27700  	CONNECTOR-HEATER
32865-27700  	KNOB-CONTROL LEVER
40225-27700  	NUT-ROAD WHELL
40225-27700  	NUT-ROAD WHEEL
44000-27700  	ASSY-BRAKE REAR RH FOR FRONT DR
44010-27700  	ASSY-BRAKE REAR LH FOR FRONT DR
44030-27700  	ASSY-DISC REAR BRAKE LH
44020-27700  	ASSY-DISC REAR BRAKE RH
62663-27700  	BOLT-BUMPER
62663-27700  	BOLT-BUMPER,B
62663-27700  	BOLT-BUMPER B,BUMPER TO BRACKET
62663-27700  	BOLT-BUMPER B BRACKET TO BUMPER
41100-27727  	KIT-REPAIR WHEEL CYLINDER A
41100-27728  	KIT-REPAIR WHEEL CYLINDER B
41124-28500  	SEAL-PISTON
41127-28500  	BOOT
41135-28500  	RING-RETAINING
46075-28511  	SPRING-PISTON
54313-28525  	OIL-SUSPENSION STRUT (TOKICO 360C
46020-28600  	SET-CAP OIL RESERVOIR(NABCO)
14011-29901  	NUT-FIXING TUBE END
23500-29901  	REGULATOR-VOLTAGE (HITACHI TL1
23500-29902  	REGULATOR-VOLTAGE (HITACHI TLI
23500-29911  	REGULATOR-VOLTAGE (MITSUBISHI
16400-A0600  	ASSY-STRAINER FUEL
16439-A0600  	CLAMP-HOSE FUEL STRAINER SIDE
46123-A0600  	PIN-CLEVIS
86982-A0600  	EYELET-'A'SET BACK
86983-A0600  	EYELET-'B'SEAT BACK
86981-A0601  	PLUG-SEAT BACK
16439-A0602  	CLAMP-HOSE
96830-A0800  	WASHER-PLAIN
38322-A0900  	ASSY-BREATHER
46027-A1100  	SPRING-VALVE
46029-A1100  	SEAT-TUBE
46038-A1100  	CAP-VALVE
65601-A2200  	ASSY-MALE HOOD LOCK
65601-A2201  	ASSY-MALE HOOD LOCK
41129-A2410  	CAP-BLEEDER
41129-A2410  	CAP-BLEEDER (TOKICO) FOR FORE CYLINDE
41129-A2410  	CAP-BLEEDER(NABCO)
41129-A2410  	CAP-BLEEDER SCREW
14875-A3000  	CONNECTOR-VACUUM TO IN TAKE MANIFOLD
21200-A3001  	ASSY-THERMOSTAT 82C
21200-A3005  	ASSY-THERMOSTAT 88C FOR WINTER
11810-A3500  	ASSY-CONTROL VALVE CRANK CASE EMISSIO
31065-A4000  	CLAMP-VACUUM TUBE
26029-A4600  	COVER-TERMINAL
46237-A4600  	GASKET-CLUTCH HOSE TO CYLINDER T=1
26375-A4601  	ASSY-BLADE WIPER
26029-A4601  	COVER-TERMINAL
21060-A4605  	FAN-COOLING D=330 FOR TROPICAL USA
22401-A4605  	PLUG-SPARK BP-5ES(N.G.K)
22401-A4616  	PLUG-SPARK BP-6ES(N.G.K)
22401-A4617  	PLUG-SPARK
22401-A4704  	PLUG-SPARK L47PW(HITACHI)
22401-A4705  	PLUG-SPARK L45PW(HITACHI)
22401-A4706  	PLUG-SPARK L46PW(HITACHI)
22401-A4706  	PLUG-SPARK(L46-PW)
22401-A4707  	PLUG-SPARK L47PW(HITACHI)
22401-A4725  	SET-IGNITION(HITACHI)
22401-A4804  	PLUG-SPARK L44PW(HITACHI)
22433-A5400  	COIL-IGNITION (HITACHI)
22433-A5410  	COIL-IGNITION (HANSHIN)
14911-A5500  	TUBE-EVAPO CONTROL(L=80)
14910-A5501  	ASSY-VALVE FLOW GUIDE
14913-A5501  	TUBE-EVAPO CONTROL L=200
23100-A5501  	ASSY-ALTERNATOR(HITACHI)
23108-A5501  	ASSY-ROTOR
23102-A5501  	ASSY-STATOR
14910-A5502  	ASSY-VALVE FLOW GUIDE
22248-A5502  	SEAL-DUST
46091-A6800  	RESERVOIR-OIL,BRAKE,FOR DRUM
46091-A6800  	RESERVOIR-OIL,BRAKE,FOR DISC
46027-A6900  	SPRING-RESIDUAL VALVE
21060-N0100  	FAN-COOLING,FOR TROPICAL USE
38322-N0100  	ASSY-BREATHER
54324-N0100  	NUT
54324-N0100  	NUT-HEX SELF LOCK
46093-N0400  	FILTER-OIL,FOR DRUM
46092-N0400  	FILTER-OIL,FOR DISC
46093-N0410  	FILTER-OIL
22110-N0901  	ASSY-SWITCH, THERMOSTAT
76486-N1600  	BOLT-SILL MOULDING
80595-N1600  	KNOB-DOOR LOCK
14910-N2200  	ASSY-VALVE FLOW GUIDE
14910-N2202  	ASSY-VALVE FLOW GUIDE
14910-N2203  	ASSY-VALVE FLOW GUID
20720-N2225  	KIT-SEALANT,EXH TUBE JOINT
23500-N3300  	REGULATOR-VOLTAGE (HITACHI TLI
32851-N9000  	PLUNGER-RETURN SPRING
17310-P0100  	PLUG-DRAIN
23193-P0100  	TERMINAL-N
25235-P0100  	ASSY-RELAY,HEATER,AUTO CHOKE
36406-P0100  	PLATE-LOCK HAND BRAKE CABLE
17312-P0101  	PACKING-DRAIN
17312-P0102  	PACKING-DRAIN
87408-P2000  	BOLT-SPECIAL CUSHION FIX TO BACK
21638-P2600  	JOINT-TUBE
21625-P2600  	BOLT-CONNECTOR,OIL COOLER
21626-P2600  	WASHER-SEAL
31086-P2601  	ASSY-GAUGE,OIL LEVEL
32703-P2622  	ASSY-PINION,SPEEDOMETER
20630-P4400  	RING-RUBBER MUFFLER CLAMP
46079-R1200  	GASKET-PISTON STOPPER
46032-R1200  	STOPPER-SECONDARY PISTON
08310-S1614  	SCREW-MACHINE M5 FOR BRACKET TO BODY FI
ST306- 	DRIFT-DRIVE PINION BEARING FOR DIFFEREN
ST325- 	WEIGHT-SIDE BEARING ADJUST FOR DIFFEREN
13210-U0100  	COLLET-VALVE
21430-U0100  	ASSY-CAP PADIATOR
23100-U0100  	ASSY-ALT.12V-35A (HITACHI LT135-13)(DE
23100-U0100  	ASSY-ALTERNATOR 12V-35A (LT135-13)
23108-U0100  	ASSY-ROTOR
23127-U0100  	ASSY-COVER,REAR
23133-U0100  	ASSY-HOLDER,BRUSH
23236-U0100  	COVER-BRUSH
23230-U0100  	DIODE
23102-U0101  	ASSY-STATOR
23127-U0101  	ASSY-COVER,REAR
23133-U0101  	ASSY-BRUSH
44128-U0201  	SCREW-BLEEDER (NABCO)
41129-U0201  	CAP-BLEEDER (NABCO)
41128-U0201  	SCREW-BLEEDER (NABCO)
46027-U0201  	SPRING-VALVE
46029-U0201  	SEAT-SPRING
41129-U0201  	CAP-BLEEDER SCREW
46090-U0201  	RESERVOIR-OIL,FOR DRUM
46090-U0201  	RESERVOIR-OIL,FOR DISC
46020-U0201  	ASSY-CAP,OIL RESERVOIR
46091-U0502  	RESERVOIR-OIL,FOR DISC
44128-U0512  	SCREW-BLEEDER (TOKIKO)
41128-U0512  	SCREW-BLEEDER (TOKIKO)
46090-U0512  	PESERVOIR-OIL FOR DRUM
46090-U0512  	RESERVOIR-OIL FOR DISC
46091-U0512  	RESERVOIR-OIL FOR DISC
46020-U0512  	ASSY-CAP,OIL RESERVOIR
65610-U1702  	ASSY-FEMALE HOOD LOCK
22433-U2000  	COIL-IGNITION (HITACHI)
22120-U2001  	ASSY-SWITCH WATER TEMP
22433-U2010  	COIL-IGNITION (HANSHIN)
22460-U2200  	RESISTER-IGNITION COIL (HITACHI)
44112-U4000  	CUP-PISTON (NABCO)
44113-U4000  	RING-SNAP (NABCO)
44124-U4000  	COVER-DUST'A' (NABCO)
44141-U4000  	SHIM-ADJUSTING 'A' (NABCO)
44142-U4000  	SHIM-ADJUSTING'B' (NABCO)
44144-U4000  	COVER-DUST'B' (NABCO)
44141-U4000  	PLATE-LOCK (NABCO)
44142-U4000  	PLATE-BACK UP (NABCO)
44113-U4010  	RING-SNAP (TOKIKO)
44124-U4010  	COVER-DUST'A' (TOKIKO)
44141-U4010  	SHIM-ADJUSTING'A' (TOKIKO)
44144-U4010  	COVER-DUST'B' (TOKIKO)
44149-U4010  	PLATE-'A' (TOKIKO)
44149-U4010  	PLATE-LOCK (TOKIKO)
46100-U5200  	ASSY-SWITCH BRAKE INDICATOR
43070-H5000  	SPACER RR AXLE
43215-H5000  	BEARING RR AXLE
22100-H5900 DISTRIBUTOR (D411-59K)(ISO) L14
22100-H5900 ASSY-DISTRIBUTOR (D411-59K IS L14
22100-H5901  	ASSY-DISTRIBUTOR L14
23100-H6200  	ASSY-ALTERNATOR 12V 50A (LT150-05)FO
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=510_Parts_Donor"
This page has been accessed 6,770 times. This page was last modified 05:46, 10 January 2012. Content is available under Datsun 1200 Club.
