Brake Lines
(Redirected from Brake Piping)
Category: Brake System
Brake Piping (Brake lines).
Breakdown
Brake Piping Part Numbers
Rear Splitter
Brass brake connector (T-piece) - bolts to the rear diff. The flexible hose bolts to it coming in, with hardlines coming out to the wheels.
3-way Connector
Mounting hole: 8.7mm
28213.jpgAlbum 28213
28212.jpgAlbum 28212
Buy at Bprojects
46303-18000_a.jpg 46303-18000_b.jpg 46303-18000_c.jpg 46303-18000_d.jpg 46303-18000_e.jpg 46303-18000_f.jpg
Front Splitter
Which front splitter is used depends on the model.
#4-way connector for Single brake master cylinder
#3-way Connector for Tandem brake master cylinder
#5-way Connector North America combo splitter/pressure warning switch
3-Way Connector
Used with tandem (dual) master cylinder. Splits the front brake line to each wheel.
26379.jpgAlbum 26379
Buy at Bprojects
Nissan 46234-H1100 3-way brake tube connector
Mounting hole: 6.7mm
46234-H1100_a.jpg 46234-H1100_b.jpg 46234-H1100_c.jpg 46234-H1100_d.jpg 46234-H1100_e.jpg
4-Way Connector
Used with single master cylinder. Splits the single input. For safety, please convert to tandem master cylinder, which will still stop the car even if a leak develops at one wheel.
6458.jpgAlbum click to view
Input: Master cylinder hard line
Output
1. Front Right hard line
2. Front Left hard line
3. Rear hard line
5-Way Connector
North American 1200s were fitted with a 5-way combination splitter with pressure failure warning switch.
See main article: Warning Light Switch
Proportioning Valve
Original Datsun 1200s did not come with a Proportioning Valve.
PB110
OPTIONAL for PB110 was a Proportioning Valve. It was placed in the line to the rear brakes.
See Brake Proportioning#PB110
Late Sunny Truck
The 1200 got a load-sensing valve in October 1989.
See main article: Proportioning Valve
Power Brake Lines
For the stock 1200 power brakes, see Brake Booster.
Hard Lines
The hard lines are 3/16" outside diameter.
* 3/16" lines (4.75 mm) with M10 metric fittings
* Cunifer lines on early 1200s for corrosion resistance
* Later 1200 utes have poly-coated steel lines
Choices
  1. get pre-made lines of various lengths and bend and install it yourself
  2. get brake line material and fittings and cut it, flare it and fit it
  3. pay a shop to make and install custom lines
  4. buy genuine brake lines from Nissan and install. The ute parts are still available, and most will fit a Sedan or Coupe.
The first two are available at the usual spare auto parts stores, or mail order from hot rod stores.
Soft Lines
Brake hoses used by Datsun 1200:
* Rear soft hose to the rear axle
* Front left soft hose to brake caliper
* Front right soft hose to brake caliper
See main article: Brake Hoses
See Brake Piping Part Numbers
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Brake_Lines"
This page has been accessed 23,037 times. This page was last modified 04:56, 13 November 2021. Content is available under Datsun 1200 Club.
