Pushrods
(Redirected from Push Rods)
Category: Valvetrain
Datsun A-series engines use tubular steel pushrods. Oil does not travel through the pushrods, but are oiled from above by the Rocker arms.
Length
It is important to use the correct length for proper Rocker geometry. If the cylinder head is skimmed beyond the service limit, or the block deck is cut down, custom push rods are needed.
* 141.5 mm: A10
* 152 mm: short-deck engines (A12, A12A, and 1980 A13)
* ~167 mm: tall-deck engines (A14, A15, and 1974 A13)
Rocker geometry | uneven valve adjusters
4355.jpg 174_5b67681f1d10d.jpgPost 489159
* 13238-H1001 ROD-push A12, A12A also 1980-1982 A13
Tall-block engines use a different length:
* 13238-H6201 ROD-push A14, A15
Datrats - Custom pushrods made to length from VW pushrods and using the A-series cup. They sit the turned down cup shaft on a ledge in the alloy. Custom made to your length and cheap.
25863.jpgAlbum 25863
Lightweight Pushrods
Tomei brand:
17187.jpgAlbum 17187 23621.jpgAlbum 23621
Unknown brand:
17188.jpgAlbum 17188
Aluminum
150mm length (standard A12 push rods are 152mm)
21241.jpgAlbum 21241
Titan from Bprojects
* Titan: 32.2g
* Stock: 40.0g
* Pitroad Aluminum: 32.5g
22741.jpgAlbum 22741
Roller Rocker Pushrods
16779.jpgAlbum 16779
  • Many local speed shops can make custom pushrods
  • Yella Terra sold their pushrod tooling to "Head Stud Developments" in Melbourne
  • Crow Cams also provide pushrods to customer order, approx. 6.650-6.600 inches long (for A14/A15 subject to your needs) 0.080 wall thickness, Chrome Moly
  • Iskenderian Part# 1235L+.50. - custom pushrods for roller rockers (small block Chevy, +0.050 inch length), 8mm (5/16") ball ends
  • Isky also sells an adjustable pushrod ("universal" pushrod kit for Chevy smallblock)
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Pushrods"
This page has been accessed 20,450 times. This page was last modified 02:36, 19 December 2018. Content is available under Datsun 1200 Club.
