Front Suspension Specification
(Redirected from Front Suspension Specification 2)
Category: Front Axle And Front Suspension
This page is for factory specifications. For modified settings, see Category:Suspension Modifications.
Wheel Alignment
Camber, Caster and Toe-in
See main article: Wheel alignment
Factory Front Suspsension Specifications
Coil Spring Specifications
North America specification
 B110B210B210
with/AC
B310 1980-1982B310 1980-1982
w/AC
B310 1980
w/AC USA
A12A
wire diameter10mm10.5mm10.8mm10.5mm10.8mm10.5mm
coil diameter110mm O.D.
100mm I.D.
100mm100mm 100mm100mm100mm
Free length338mm ±101977: 375mm
1974: 353mm
1977: 388mm375mm
358mm CAN A12A
366mm USA A12A
381mm USA
375mm CAN
375mm
Effective Turns6.257.58.25???
Spring constant1.6kg/mm
(89.6 lb/in)
??1.62kg/mm
(90.7 lb/in)
1.65kg/mm
(92.4 lb/in)
1.62kg/mm
(90.7 lb/in)
Effective Turns: Since the coils are closed on each end, they contribute less to the spring rate. The Actual Turns are about 1.5 more than effective turns.
Note that B310 spring is identical to North America B210 spring. The B310 however uses a different upper spring seat.
120Y
120Y is A12-powered B210. It uses similar suspension to B110, unlike the A14-powered B210.
Spring rate: 90.7 lbs/in.
page FA-16 of FActory Service Manual, released 1976
Coil Springs
Wire Diameter - 10.5 mm (0.413 in)
Coil Diameter - 100 mm (3.94 in)
Coil Turns - 9.0
Coil effective Turns - 7.5
Free length - 357.5 mm LH (14.07 in), 346.5 mm RH (13.64 in)
Spring Constant - 1.62 KG/MM (90.7 lb/in)
1976-up B120
B120 pickup from October 1975:
Coil Spring
  • Wire diameter: 10mm (0.39 in)
  • Coil diameter: 100mm (3.94 in)
  • Loaded (normal load) length: 326mm (12.83 in)
  • Effective turn: 6.2
  • Spring constant: 1.6 kg/mm (90.0 lb/in)
Strut damper
  • Piston Rod diameter: 18mm (0.71 in)
  • Piston diameter: 25mm (0.98 in)
  • Stroke: 164mm (6.46 in)
Damping Force at 0.3m/sec (1.0 ft/sec)
  • Expansion/Rebound: 38-58kg (84-128 lb)
  • Compression: 17-27 kb (37-60 lb)
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Front_Suspension_Specification"
This page has been accessed 21,988 times. This page was last modified 10:14, 8 August 2016. Content is available under Datsun 1200 Club.
