How do I install a 5 speed Sunny box?
From Datsun 1200 Club
Category: Tech Section
This is the old Tech Section article
See the updated article: 5-speeds
Published by: Davo1200 , On: Oct-11-2002
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=How_do_I_install_a_5_speed_Sunny_box%3F"
This page has been accessed 2,779 times. This page was last modified 03:03, 28 July 2015. Content is available under Datsun 1200 Club.
