Tail Lights
(Redirected from Sedan Rear Lights)
<-- back to Lighting_System
Taillights, tail lamps, or as Nissan calls them "rear combination lamps", combine the running lights, reverse lights, brake lamps (stop lights) and turn-signal lamps (blinkers).
Sedan (short) vs Coupe (long)
9806.jpgAlbum click to view
AUS/Europe: white-red-orange
Japan/USA/ZA: white-red-red
Sedan: USA vs AUS
1549.jpgAlbum 1549 10520.jpgAlbum 10520
Coupe: AUS vs USA
7034.jpgAlbum 7034 8570.jpgAlbum 8570
Wagon and Sedan (Australia)
5164.jpgAlbum 5164
Ute
2851.jpgAlbum 2851
Van (Australia)
638.jpgAlbum 638
Sedan (portugal)
47.JPGAlbum 47
Sedan: Europe orange blinkers vs USA red blinkers
2842.jpgAlbum 2842 9857.jpgAlbum 9857
Facelift Sedans used a different taillight:
755.jpgAlbum 7551524.jpgAlbum 1524
Troubleshooting
Inoperative rear taillights, Turn Signal lights, or brake lights? Check for adequate grounding/earthing of the plastic combination lamp assembly.
Service Bulletin
24397.jpgAlbum 24397
1. Check the metal-to-metal contact of the ground wire (black) from the right side tail light assembly at the grounding post on the panel inside the trunk area. Remove any paint or dirt that prevents good contact
Sedan
24398.jpgAlbum 24398
Coupe
24399.jpgAlbum 24399
2. Using an ohmmeter, check the ground wire (black) from the harness in the engine compartment to the battery negative post for continuity to the instruments and lights of the vehicle. If continuity is lacking, repair the break or replace the wire
3. A heavy gauge ground strap connecting the engine to the body of the vehicle assures proper grounding. The ground strap is built into the original negative battery cable
21177.jpgAlbum 21177
Bulbs
Main: Bulbs
All 1200s use a 3-section taillight. Japan market and North American market use these bulbs:
* 26717-89900 12V-23W   [Top/Outer bulb]
* 26717-89920 12V-23/8W [Middle bulb]
* 26717-89900 12V-23W   [Bottom/Inner bulb]
Japan-market has an additional small bulb in the middle section:
* 26261-89900 12V-3.4W (Wedge socket)
  used until Aug 1986 in the Truck
Japan small bulb (sedan)
Japan small bulb (coupe)
Sedan
Note that non-GX and GX use the same taillights
11336.jpgAlbum 11336 750.jpgAlbum 750
#H10 Japan and #H16 North America tail light have Red blinkers, instead of Yellow/Orange
20733.jpgAlbum 20733
#H19 Australia/Europe lenses have Orange for the blinkers
20738.jpgAlbum 20738
LENS
20734.jpgAlbum 20734 20735.jpgAlbum 20735
RIM | lens with RIM fitted
20743.jpgAlbum 20743 20706.jpgAlbum 20706
PACKING (rubber seal -- lens-to-body)
20736.jpgAlbum 20736
HOUSING (available as complete Combination Lamp Assembly)
20737.jpgAlbum 20737
PB110
H28 PB110 sedan - similar to B110 coupe, but longer
25536.jpgAlbum 25536
Facelift
H31 1972 Japan-market (facelift) models had new tail lamps:
20715.jpgAlbum 20715 20729.jpgAlbum 20729
1524.jpgAlbum 1524 1975.jpgAlbum 1975
20730.jpgAlbum 20730 20731.jpgAlbum 20731 20732.jpgAlbum 20732
26550-H3101 LAMP ASS'Y-rear combination (R.H.)
26555-H3101 LAMP ASS'Y-rear combination (L.H.)
* 23W bulb (4)
* 23/8W bulb (2)
* 3.4W bulb (2)
26552-H3101 RIM ASS-Y (2)
26553-H3101 PACKING ASS'Y (2)
26551-H3101 LENS ASS'Y (R.H.)
26556-H3101 LENS ASS'Y (L.H.)
IKI 4034
Clear Sedan
Just add one white, one red, and one amber LED bulb.
Levy production
21117.jpgAlbum 21117 21563.jpgAlbum 21563 21158.jpgAlbum 21158 21119.jpgAlbum 21119 21116.jpgAlbum 21116
NOTE: Not legal for road use, as they do not have a reflector or approved lens pattern.
Custom Sedan
Round
Coupe On Sedan
Coupe taillights on sedan | Compare to #Facelift
5494.jpgAlbum 5494 1524.jpgAlbum 1524 3815.gifAlbum 3815
H10
original type. Four bulbs/side. No Yellow/Amber in lens. Used only by Japan/asia market. Looks like #H16 but has four bulbs per side (USA has only 3 bulbs/side).
JAPAN market - 4 bulb
26550-H1001 ASS'Y-LAMP, rear combination (R.H.)
26555-H1001 ASS'Y-LAMP, rear combination (L.H.)
* 23W bulb (2 per side)
* 23/8W (1 per side)
* 3W (1 per side)
26552-H1001 ASS'Y-RIM (2) $38.82 USD
26553-H1000 ASS'Y-PACKING (2) $18.33 USD
26551-H1001 ASS'Y-LENS (R.H.) NLA
26556-H1001 ASS'Y-LENS (L.H.) NLA
26563-H1000 ASS'Y-HARNESS (R.H.)
26568-H1000 ASS'Y-HARNESS (L.H.)
H16
Modified for North America lens standards. On the outside looks just like JAPAN #H10 (no yellow section)
  • lens reflection differs
  • Uses three bulbs per side vs JAPAN 4-bulb
USA tail light have RED-RED-CLEAR
P1020699.jpg 20733.jpgAlbum 20733
USA - 3 bulb
26550-H1902 ASSY-LAMP REAR COMBNATION RH (ICHIKHO) $143.10 USD
26555-H1902 ASSY-LAMP REAR COMBNATION LH (ICHIKHO)
26550-H7000 ASSY-LAMP REAR COMBINATION RH FROM 0772 $143.10 USD
26555-H7000 ASSY-LAMP REAR COMBINATION LH FROM 0772
26551-H1902 ASSY-LENS RH RED-RED-WHITE (ICHIKHO) $35.63 USD
26556-H1902 ASSY-LENS LH RED-RED-WHITE (ICHIKHO) $35.63 USD
26563-H1600 ASSY-HARNESS,R.H NLA
26564-H1600 ASSY-HARNESS,L.H NLA
* No 3W bulb
H19
For worldwide market
YELLOW-RED-CLEAR
20738.jpgAlbum 20738 15056.jpgAlbum 15056
EverAce T-1756 & T-1757
27867.jpgAlbum 27867 27868.jpgAlbum 27868
27869.jpgAlbum 27869
Ever Wing T-1756, T-1757. Yellow indicator with 4-bulb housings
IKI 4004 R & 4004 L -- 1 E4 310 R-120 SAE ISTR 69
4004a.jpg 4004b.jpg 4004c.jpg 4004d.jpg 4004e.jpg 4004f.jpg 4004La.jpg 4004Lb.jpg 4004Lc.jpg 4004Ld.jpg 4004Le.jpg 4004Lf.jpg 4004Lg.jpg 4004Lh.jpg
Coupe
Coupe tail lights have a silver, light gray, or dark gray surround in the chromed rim (all same part number, appears to be production variance).
5618.jpgAlbum 5618 14005.jpgAlbum 14005 511.jpgAlbum 511 1417.jpgAlbum 1417
Mounting
25311.jpgAlbum 25311 25312.jpgAlbum 25312
Amber-Red-White (AUS & EUR)
10207.jpgAlbum 10207 18045.jpgAlbum 18045
Red-Red-White (Japan & USA)
20739.jpgAlbum 20739 20740.jpgAlbum 20740
3-bulb Type vs 4-bulb Type
20711.jpgAlbum 20711 20742.jpgAlbum 20742
20741.jpgAlbum 20741
USA 3-bulb harness
amber 4-lamp - Australia?
25992.jpgAlbum 25992 25993.jpgAlbum 25993 25994.jpgAlbum 25994
IKI4005R RH SAE
26030.jpgAlbum 26030 26031.jpgAlbum 26031 26032.jpgAlbum 26032
PB110 Coupe
PB110 coupe - similar to B110 Sedan lights, but they protrude out
25854.jpgAlbum 25854
See Coupe Rear Combination Lamp Part Numbers
* Japan and North America both use Red lenses (no amber)
* the red lenses differ, presumably in reflective pattern
* the center section has two bulbs (Japan) or one bulb (NA)
  Therefore the assembly housing and Harness differ
All other parts are the same (Bulbs, Rim, Packing, white reverse Lens)
Custom
White-outside rears
1417.jpgAlbum 1417
Supra lights on Coupe:
5606.jpgAlbum 5606 2869.jpgAlbum 2869 24277.jpgAlbum 24277 24278.gifAlbum 24278
Wagon
638.jpgAlbum 638 13022_4e3cb98ba155c.jpgPost 378695 2998.jpgAlbum 2998 5090.jpgAlbum 5090 20195.jpgAlbum 20195
Also fits 620 Pickup
400px-Datsun_620_622.JPGWIKI click for photo
26551-H1401, Koito 220-23461
25527.jpgAlbum 25527 25528.jpgAlbum 25528 26551-H1401_s.jpg 26551-H1401_t.jpg
Housing
LENS style 2
20744.jpgAlbum 20744
Reverse Lens
Repair
5145.jpgAlbum 5145
174_5d8159050dcc3.jpgPost 492625 174_5d8158f8e4031.jpgPost 492625
1000
See main article: B10 Lights
2196.jpgAlbum 2196 6431.jpgAlbum 6431 20700.jpgAlbum 207006146.jpgAlbum 6146 6877.jpgAlbum 6877 8337.jpgAlbum 8337 20704.jpgAlbum 20704
Pickup
Black-rim OR Silver-rim tail lights
7899.jpgAlbum 7899 5648.jpgAlbum 5648
Datsun 1200 (Pickup) has three-segment rear corner lamps:
20713.jpgAlbum 20713 18255.jpgAlbum 18255
* Top section is for turn signals, 23W single filament bulb
  * Yellow in Japan market
  * Aftermarket clear lenses are available, which use color bulbs
* Middle section is red for brake & running lights, 23W/8W dual filament bulb
* Bottom section is clear for backup lights, 23W single filament bulb
20716.jpgAlbum 20716 20717.jpgAlbum 20717 17268.jpgAlbum 17268
Lenses are held in place by 8 screws
26033.jpgAlbum 26033
The lens frame (Rim) was offered in Silver or Black:
20694.jpgAlbum 20694
1971-1978: were silver/chrome through 1978 March
20693.jpgAlbum 20693
1978-1989: changed to black from 1978 April
20692.jpgAlbum 20692 25639.jpgAlbum 25639
1971-1973 Chrome. Spade connector
1973-1978 Revised tail & stop (middle) lens
1978-8608 Black. Pin connector (JAP) or locking spade (AUS)
8608-2004 3-bulb type (no parking lamp)
Gasket (Packing)
20696.jpgAlbum 20696
Wiring early - Spade connector
20714.jpgAlbum 20714
Wiring late - Pin connector (positive locking)
20695.jpgAlbum 20695
Wiring AUS - 6-Spade connector (positive locking)
25789.jpgAlbum 25789
Spacers on the attachment studs
26034.jpgAlbum 26034
Plugs were used from 1989 October, to cover the hole for the missing small bulb
26035.jpgAlbum 26035
2785.jpgAlbum 2785 2851.jpgAlbum 2851 2852.jpgAlbum 2852 2994.jpgAlbum 2994 5355.jpgAlbum 5355 16760.jpgAlbum 16760 16887.jpgAlbum 16887 17561.jpgAlbum 17561 18255.jpgAlbum 18255
600x450-2015062100362.jpg 600x450-2015062100363.jpg 20150607210843497.jpg 20150607210843566.jpg 20150607210843630.jpg 20150607210843699.jpg 20150607210843769.jpg 20150607210843834.jpg 20150607210843908.jpg 20150607210843975.jpg
See Truck Rear Combination Lamp Part Numbers
Bulbs
* 26717-89900 12V-23W (4) [Top bulb, Bottom bulb]
* 26717-89920 12V-23/8W -8608 (2) [Middle bulb]
* 26261-89900 12V-3.4W (2) [small middle bulb]
WIRING
* 26563-G1000 HARNESS ASSY-REAR COMBINATION -7803 [spade connectors]
* 26563-G1060 HARNESS ASSY-REAR COMBINATION 7804-8608 PIN CONNECTOR [4-bulb type]
* 26563-G1900 HARNESS ASSY-REAR COMBINATION -8608 [3-bulb type]
LAMP ASSY-REAR COMBINATION
G100     -7803 [chrome]
G106 7804-8608 [black, 4-bulb]
G190 8608-     [black, 3-bulb]
Export
JDM vs Export
20707.jpgAlbum 20707 20708.jpgAlbum 20708
Round reflector section varies in size
輸出用 - Export , small reflector
国内 - Domestic, larger reflector
Aftermarket Ute
Semi-Clear
White trim
16820.jpgAlbum 16820
Chrome trim
23471.jpgAlbum 23471 2137.jpgAlbum 2137
Black trim
14390.jpgAlbum 14390 15841.jpgAlbum 15841 17087.jpgAlbum 17087 17088.jpgAlbum 17088
Clear
1783.jpgAlbum 1783 1948.jpgAlbum 1948 1949.jpgAlbum 1949 9306.jpgAlbum 9306 20376.jpgAlbum 20376 20377.jpgAlbum 20377 20381.jpgAlbum 20381 2137.jpgAlbum 2137
Fumiya-brand clears
Custom
14913.jpgAlbum 14913 14933.jpgAlbum 14933 15431.jpgAlbum 15431 19423.jpgAlbum 19423
ストップラ ランプ レンズ ウインカー テールレンズ テール レンズ
Reflectors
In most countries, reflecting surfaces are built-into the rear lamps.
For those countries where they are not, or where a bigger relector is required -- such as Australia and Kenya -- separate rear reflectors were added:
See Main Article: Reflectors#Tailgate
Third Brake Lamp
Center High Mount Stop Lamp (CHMSL) a.k.a. 3rd brake light can be adapted to the 1200, or a "universal" fitted. USA data indicates a long-term enduring crash-reduction benefit of 4.3%.
2554.jpgAlbum 2554
Mandatory for new cars
* United States and Canada since 1986
  light trucks since 1994
* Australia and New Zealand since 1990
* Many European countries since 1998
Google search: third brake light
North America Notes
USA regulates the wattage, color and placement of the tail lights.
Canada generally adopts the same standards as USA.
USA "Federal Motor Vehicle Safety Standard No. 108 [1968] allows rear turn signals to be either red or amber in color... amber signals show a 5.3% effectivenss in reducing involvement in two-vehicle crashes where a lead vehicle is rear-struck in the act of turn left, turning right, merging into traffic, changing lanes, or entering/leaving a parking space. The advantage of amber rear turn signals is shown to be statistically significant." -- NTSHA document.
Nevertheless, amber was slow in coming. Even in the 1990s red rear turns signals are commonplace. The Nissan Altima even changed three times, from Amber to Red to Amber and back to red.
"In Europe and many other countries, rear turn signals are required to be amber. Currently [2009], manufacturers ... [for] North American markets choose whether to produce [amber or red rear turn signals]." -- NTSHA document.
テールランプ
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Tail_Lights"
This page has been accessed 60,612 times. This page was last modified 20:33, 19 March 2022. Content is available under Datsun 1200 Club.
