Search results
For query "Tranmission"
There is no page titled ":Tranmission". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 5 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Universal Joint (5176 bytes)
    102: ...any looseness (in direction of rotation) with the tranmission in gear. If it is loose, new u-joints won't fix t...
  2. Manual transmission conversion (10504 bytes)
    40: * [[Engine Plate|engine rear plate]] (if the tranmission used it)
  3. Release Bearing (12926 bytes)
    76: ...for 56L transmission, and 2) short length for 56A tranmission. The difference in length is 4.5mm.
  4. 520 (6155 bytes)
    231: ... mount brackets and isolators differ as does rear tranmission mount bracket. These brackets bolt to the frame.
  5. Rigoli (1019 bytes)
    17: Tranmission: Tri-Matic (GM Turbo-Hydramatic 180)
Search in namespaces :
List redirects   Search for
