There is no page titled ":Widths". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 11 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Diff Widths (2667 bytes)
Page text matches
- Rear Axle (11437 bytes)
59: {{See|Diff Widths}} - Rear Axle Swaps (24555 bytes)
65: Datsun 1200 [[Diff_Widths|rear axle assembly width]] is 1305 mm drum to dru...
111: * B10: [[Diff Widths|1120 mm]]
112: * B120: [[Diff_Widths|1185 mm]] (H165, same as H145 B120/B110 - 65 mm w...
321: ...converting to two short axles — same [[Diff Widths]] as 510 or S110. Will fit a 1200 using high-offs...
338: Rear Axle assembly Widths: - Offset (16590 bytes)
134: ... Factory Steel vs. Aluminum wheels have different widths -- the alloy wheels are 1/2" wider (13mm), and th...
328: = Rim Widths =
329: Tire manufacturer recommended wheel widths - R160 Swap (4433 bytes)
38: Drum-to-drum Width (see [[Diff Widths]]) - H190 (17111 bytes)
106: = Widths = - H165 (17243 bytes)
222: Also see: [[Diff Widths]] - Rack and Pinion Steering (13839 bytes)
90: ...kes adjustable & custom boxes suitable for narrow widths - Rim Types (8905 bytes)
7: ...") are available in a large variety of diameters, widths, and offset. - B310 rear axle (1488 bytes)
15: width: [[Diff Widths|53.5 in]] (1360 mm) - THE LIGHTWEIGHT HEAVIES (8330 bytes)
198: Widths: Front track 1250 mm.
