There is no page titled ":1.Anti-diesel_valve". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Anti-diesel valve (4175 bytes)
1: ...ove the idle range — if the engine is above 1500 RPM it will still keep running.</blockquote>
4: Anti-Diesel solenoid valve comes on some 1973 and newer carbs.
6: 1973 JAPAN Datsun B210
7: 1973 USA Datsun 1200
8: 1981 AUS Datsun 1200 - Anti-sway bar (7544 bytes)
11: ...ch stiffer bar works well and doesn't overpower a 1200.
15: ...459163}} {{UploadPostH|12526_53f7d8a6c7d65.jpg|459163|300}}
18: '''B210 Sway Bar Upgrade'''
20: Bolt a B210 (1974-1978 Sunny) swaybar on. For around $20 and an hour ...
25: {{SeeMainArticle!|B210 Sway Bar Upgrade}} - Anti-Tramp (2538 bytes)
14: ...nsion_Manual#Rear_Suspension_Modifications|Datsun 1200 Competition Suspension Manual]]
16: {{Album!|15793}}
20: <br>{{Photo!|SlapperBars.jpg}} {{Album|2831}}
23: <br>{{Album|19282}} {{Album|14587}}
28: ... to make yourself: 1-3/4" square tubing, Hyundai H100 tray stops. Custom U-Clamps. Double nuts or loc...
Page text matches
- QR25DE Engine (6399 bytes)
2: ... into a Datsun 510, so you know it will work in a 1200 too.
5: ...ies into a 1200? They've been on the market since 1999 ...
7: ...[[wikipedia:Nissan_QR_engine#QR25DE|QR25DE]] (152-165 hp)
8: 177 hp Australia [[wikipedia:Nissan_X-Trail#Engines...
9: ...issan_Sentra#SE-R/SE-R_Spec_V_(2007–2012)|2007-2012 QR25DE Spec V]] - Carburetor Overview (3155 bytes)
1: ...mm (Secondary). However, the [[Body Styles|Datsun 1200 GX models]] used twin Hitachi 38 sidedraft car...
13: * [[#DCG286]] 1967-1970 Datsun B10
14: * [[#DCG306]] 1970-1975 Datsun B110
15: 1973-1980 Datsun B210
16: 1977-1983 Datsun B310 - Carburettor Diagnosis (3654 bytes)
31: * Anti-diesel valve not working (1973 and newer carburetors)
40: The Anti-diesel Valve started with 1973 models and is also known as the '''idle cutoff...
43: <br>{{Album|1006}}
63: #: {{Album|9815}}
72: The A12 engine is very smooth and quiet. High idling is ... - Ignition Timing (9164 bytes)
8: The stock Datsun 1200 distributor orientation — vacuum advance...
14: ...t them back in. Spec is 0.028-0.032 inch for the A12. Use 0.035" for the smoothest idle. Re-gap if ne...
29: point gap (new points): 0.018-0.021 in (0.45 - 0.55 mm)
31: Spark plug gap: 0.31-0.35 in (0.8 - 0.9 mm)
35: == Late 1200 Electronic Ignition == - Fuel pump pressure test (3334 bytes)
13: ...h engine running should be '''2.6 psi''' for the A12 engine. For other Datsuns between 3.0 and 3.8 is...
20: ...t $25 at [http://www.sears.com/shc/s/search_10153_12605?vName=Tools&cName=Auto+%26+Mechanics+Tools&vi...
29: # Start engine and run at 1,000 rpm for one minute (use a stopwatch)
37: .... The engine won't start until the bowl is about 1/2 full. - Emission Controls (28473 bytes)
1: ...mance, including some of those used by the Datsun 1200.
4: ...ers to three types of emission controls for the B110 model series:
5: * CRANK: Signifies all B110 with crankcase emission control device [PCV, etc...
6: * EXHAUST: Signifies B110 with crankcase emission control and exhaust emis...
7: * EVAPO: Signifies B110 with crankcase emission control, exhaust emissio... - Carburetor Specifications (5272 bytes)
3: ...sed bigger venturis up to A15s which have bigger 21/27 or 23/27 venturis.
7: DCH - electric automatic choke from 1972 USA
9: DCx-306: 26/30 Datsun B110
10: DCx-286: 26/28 Datsun B10
11: DCx-340: Datsun 510/620 - Steering wheel (9551 bytes)
2: ...(overall diameter 15.75"/40cm). They have a 5/8" (16mm) thick rim section.
9: = B110 =
11: ...bumLinkH|Facelift_Coupe#Back_Cover|27308|brochure|168}}
13: ...d on Standard and Deluxe trims. Also used by 1971-1978 Truck.
20: <br>{{Album|3158}} - Weber 32/36 Carburetor (22579 bytes)
8: {{Album|15241}}
10: [{{Post|50418}} Did you notice a performance increase?]
13: * designed for engines displacing 1200cc-2300cc
24: ...427213}} {{UploadPost|13419_50f10d84b15b3.jpg|427213}}
32: x can be either: 1) none - manual choke 2) E - electric choke or 3) ... - Fuel Injection (19607 bytes)
1: Your Datsun 1200 can be converted to fuel injection. Benefits c...
4: ...cars have used injection since at least the early 1960s. Electronic fuel injection (EFI) has made it ...
8: {{Album|1048}} {{Album|14626}}
10: {{Album|1713}}
12: = A12 EFI = - Wiring (8463 bytes)
1: Datsun 1200 wiring is relatively uncomplicated.
6: ...ry. Please double-check the wiring in your Datsun 1200 before connecting parts according to this arti...
35: <br>{{Album|21177}}
40: ...|r41847922darumasan0124-img600x450-1.jpg|Datsun%201200/Parts2}}
49: {{Album!|16498}} - 200SX EFI (11723 bytes)
1: ...m the S110, and an A-series EFI manifold from a B310.
3: ...X_04.jpg}} {{WikiCommons|Nissan_Silvia#110|c/c2|S110_Silvia.jpg}}
6: ...in as many of the parts as you can from a donor S110.
8: You can use either the S110 parts or the B310 parts, or a mixture. Additionally, many of the p...
16: ...nifold. Same design, but runner flanges suit L16/L18 engine - E15 Electronic Distributor Swap (19123 bytes)
1: ...from an E-Series engine such as from an [[Pulsar|N12 Pulsar]]. Fit a drive gear from an A series dist...
3: {{UploadPost|13822_52b7eb4df2d4b.jpg|449414}}
7: * E15S (single carburetor)
8: * E15I (Injected, central throttle body injection)
9: * E16S - Strut (11854 bytes)
1: Datsun 1200 uses front '''MacPherson strut''' [[Front Susp...
12: The original 1200 strut is a rebuildable oil filled tube with sh...
14: {{Album|15173}} {{Album|14291}}
17: <br>{{Album|14297}}
20: <br>{{Album|15857}} - Fuel Requirements (12515 bytes)
1: ...wikipedia:Petrol|petrol]] (gasoline). Even the [[A12GX Engine|GX]] "low gas" engine runs on regular g...
4: For a factory stock A12 engine, what does the Owners Manual say?
5: * 1971 Export Coupe (9.0:1 compression): "gasoline above 90 octane"
6: ...1972 Export (8.5:1 compression): "gasoline above 91 octane"
7: * 1973 Export (8.5:1 compression): "minimum octane rating of 87 ... av... - Turbo (10692 bytes)
4: ...es more power and torque than a worked non-turbo A14, for a fraction of the build cost.
6: {{Main|$1200 EFI Turbo A12}}
10: {{Album|21789}}
12: {{Discussion|9752|regarding Turbocharging A12}}
19: = Stage 1 = - Anti-diesel valve (4175 bytes)
8: 1981 AUS Datsun 1200 - Facelift (3096 bytes)
1: ...ld 1970-1972 in Japan, with the B210 debuting for 1973.
10: 1972 lineup
11: ...br>{{AlbumLinkH|Japan_Brochures#1972_Sunny_Lineup|12777|brochure}}
13: Included in the 1972 facelift were new:
16: {{Album!|11467}} - Tachometer (10506 bytes)
1: Optional for the Datsun 1200 was an 8,000 RPM Kanto-Seiki tachometer. It wa...
4: {{OwnersManual2x|29368|p1=08|29369|p2=09|The tachometer is electrically ope...
7: <br>{{Album|21197}}
9: [[PB110]]
10: <br>{{Album|2129}} - Brake Pads (9387 bytes)
1: Left: B110, Center: B120, Right: JDM B310
2: ...3438 http://datsun1200.com/modules/myalbum/photos/13438.jpg]
5: ...10 and HB310 use similar-looking but wider Type D117 63.5 mm pads.
7: ...12 http://datsun1200.com/modules/myalbum/photos/8912.jpg]
8: <br>B110 vs HB210/HB310
