Search results
For query "CA18DET"
There is no page titled ":CA18DET". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Magazine Articles (23807 bytes)
    33: ...ishing 185hp at the rears' (green Datsun 1200 Ute CA18DET Turbo 'INJ18L', 4-pages)
    34: ...uff CA18 Datto ute]]' 'TOUGH ENOUGH: Slot a turbo CA18DET into a Datto ute and live to drive' (Datsun 1200 ...
    37: ...2966130082|Fast Fours 2010 Aug}} {{cover|22288}} 'CA18DET DATSUN 1200 300HP WIDE LOAD!' [[18s#QKCOOP|QKCOOP...
    41: ...PE! TURBO CA18 [[RockOn#FastFours_Feb_2015|RockOn CA18DET blue coupe]]
    51: * Hot4s 2002 Jun green Datsun 1200 ute with a CA18DET
  2. QR25DE Engine (6399 bytes)
    88: ...earbox is big around, but shorter than a [[71]]C (CA18DET type) gearbox). Auto tunnel is needed or the usua...
  3. Engine Swaps (25633 bytes)
    161: ...as much and doesn't rev as high as the SR20DET or CA18DET. So it's a good engine for street use, but the SR...
    173: * CA18DET. The legendary DOHC turbo engine
    179: Many say the CA18DET is the very best engine for a Datsun 1200 swap. E...
    215: ...nes in the matter of power/weight ratio. A 300 hp CA18DET (282 pounds) would weigh nearly half that of 300 ...
    219: == CA18DET ==
  4. Rear Axle Swaps (25587 bytes)
    55: ...bout a build CA18DET turbo? ca18det_man's 202rwhp CA18DET used an [[H190]] rear axle with alloy carrier. Se...
    188: ... differential, which is strong enough for a stock CA18DET engine. It bolts right into a coupe or sedan, wit...
  5. CA-Series Engine Swaps (10958 bytes)
    1: ...e CA18DE is a dual overhead cam engine, while the CA18DET is the factory turbo version. It will fit into th...
    4: Internally stock CA18DET
    16: CA18DET DOHC Turbo (Double Overhead Cam)
    31: * Entire package with CA18DET and intercooler, fitted by a professional shop co...
    48: * Bigger Diff (ute diff for stock CA18DET)
  6. Toyota 4A engine (9960 bytes)
    55: ...re 25kgs lighter than a Nissan [[Nissan CA Engine|CA18DET]] engine. Most people take off the supercharger a...
  7. Trayback Utes (2462 bytes)
    34: ...n1200.com/modules/myalbum/photo.php?lid=9129 1200 ca18det] was planning to make a custom trayback 1200
  8. VB110 (5735 bytes)
    119: [[CA-Series_Engine_Swaps|CA18DET]]-powered
  9. Model names (18990 bytes)
    271: ...mon donor car for the turbocharged [[Engine Swaps|CA18DET]] engine, and for large [[S13 Brakes]]
  10. Brake Swaps (21279 bytes)
    488: ...odules/newbb/viewtopic.php?topic_id=15104&forum=1 CA18DET Wagon is go]
  11. 1/4 mile time log (25722 bytes)
    21: * 12.0 secs: ca18det_man's Datsun 1200 with CA18DET engine
    569: = CA18DET =
    580: *MOTOR: ca18det
    595: * MOTOR:standard internal ca18det
    611: * MOTOR: CA18DET
  12. Body Side Panels (7946 bytes)
    117: [{{Post|364299}} Rob's CA18DET 1200 UTE] - Lower end of A-piller
  13. Australian Race Tracks (7923 bytes)
    90: * Car: Datsun 1200 Sedan CA18DET
    121: === ca18det_man ===
    124: * Car: Datsun 1200 Coupe CA18DET (nearly stock)
    174: * Car: Datsun 1200 Coupe CA18DET (ca18det_man's)
    176: === ca18det_man ===
  14. Transmission Overview (6766 bytes)
    144: * 43.5kg: CA18DET 5-speed (rwd edition)
  15. Console (9655 bytes)
    244: For CA18DET shifter position: {{wiki|Hyundai Getz}} modified
  16. Automatic Transmission (16405 bytes)
    383: CA18DET: JATCO with trans brake and scatter shield
  17. Z-series Engine Swap (3141 bytes)
    3: ...ia. If price is no object, the [[Nissan CA Engine|CA18DET]] is a lighter and far more powerful engine. Howe...
  18. Ddgonzal's Sunny Truck (18606 bytes)
    28: ...se engines', especially hot ones like SR20DET and CA18DET. They can get you a JDM car too. USA fans, ask fo...
    110: ... goes. The company I bought it from had all these CA18DETS, RB sixes, SR20s, etc. sitting there for sale .....
  19. Videos (7264 bytes)
    57: ...tube.com/watch?v=G2F-EY76aCk Datsun 1200 Utility (CA18DET)] time: 20
    76: *: How a CA18DET should start and idle
    132: ...//www.youtube.com/watch?v=XlZ0Y9VFIMI Datsun 1200 CA18DET boil - Joel] time: 11
    135: ...//www.youtube.com/watch?v=V5q2AB04ITY Datsun 1200 CA18DET burnout - Sleepe] time: 21
    138: ...//www.youtube.com/watch?v=5gXuszou4Kc Datsun 1200 CA18DET burnout - Joel] time: 26
  20. JCCS (15921 bytes)
    149: * [[works1200]]'s 2-dr Sedan: America's only CA18DET Datsun 1200
Search in namespaces :
List redirects   Search for
