Search results
For query "Cooler"
There is no page titled ":Cooler". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
  1. Differential Oil Cooler Assy (219 bytes)
    1: ...84 Nissan Competition Catalog]] listed a diff oil cooler.
    5: * 21652-P9000 OIL COOLER ASSY
Page text matches
  1. Racing History (28818 bytes)
    228: ..., tubular a-arm suspension and a differential oil cooler. Although having a heavy weight of 717kg (about 1...
  2. Choosing A Carburetor (18692 bytes)
    163: ... big difference, and is a nearly free -- no "intercooler" needed.
  3. Datsun B10 (13387 bytes)
    125: Air conditioning 27600-10025 Kit-Cooler
  4. Repair Manual (19444 bytes)
    146: 5. Cooler
  5. Turbo (10692 bytes)
    41: Or go to 10 psi for short bursts on cooler days.
    47: * Fit Intercooler (precludes use of draw-through)
    68: * Fit Intercooler (precludes use of draw-through)
    72: * Oil Cooler
    125: Cooling: Radiator, Intercooler and Water Injection
  6. Oil Pump Coolers (4882 bytes)
    1: ...ving. Normal driving does not benefit from an oil cooler, as oil is designed to work at a temperature of a...
    3: [[Nissan Competition]] sells oil coolers, which utilize a sandwhich plate bolted between ...
    8: ...ng or towing the oil may heat up. Fortunately oil cooler parts are not rare.
    12: ...ng, etc -- Ford type fits the Datsun. The the oil coolers are available from Jeff Taylor and others.
    26: ...wer. These thermostats are designed to bypass the cooler until the oil reaches 215 [F] degrees.</blockquot...
  7. Oil pump (3453 bytes)
    7: ...ery few high performance cars have a separate oil cooler. So this means:
    16: ...wing there is more to talk about. See: [[Oil Pump Coolers]].
  8. Radiator (12968 bytes)
    158: 21475-H2300 SHROUD-UPPER FOR COOLER 7980-
    159: 21776-G1660 SHROUD-LOWER FOR COOLER 7980-
    161: 21775-G1660 SHROUD-UPPER FOR COOLER 7804-7907
    162: 21476-H2300 SHROUD-LOWER FOR COOLER 7804-7907
  9. SR engine swap (16940 bytes)
    362: ...xy mirrors, holden door handles, plasma man inter cooler and radiator
  10. South Africa 1400 Brochure (12141 bytes)
    58: ...e, while the big loadbox swallows everything from cooler boxes to surfboards. Whether you’re playing or w...
  11. Air Intake Systems (1554 bytes)
    4: ... big difference, and is a nearly free -- no "intercooler" needed.
  12. Automatic Transmission (16405 bytes)
    83: ...add a cooler or a radiator that includes built-in cooler.
    248: ...d require the radiator to have transmission fluid cooler fittings.
  13. Air conditioning (13213 bytes)
    1: ...e market [[B120|Sunny Truck]]. Also known as a '''cooler'''.
    41: 27630-G1660 COMPRESSOR-COOLER DKKC
    42: 27630-W7002 COMPRESSOR-COOLER DKKC [B421]
    45: 92610-G1900 COMPRESSOR-COOLER DKKC [B421]
    188: <br>Car Cooler}}
  14. 1979 aircon (7412 bytes)
    1: ...a very nicely designed unit, however the interior cooler protrudes into the passenger legroom and preclude...
    13: ...l and easy to install. Unfortunately the interior cooler unit is bulky and protrudes farther into the pass...
    18: * Ass'y indoor "[[#Interior Unit|#cooler unit]]" (with integrated air volume switch, evapo...
    55: Cooler Unit lines: Evaporator Inlet & Outlet and drain h...
    94: COOLER KIT 27600
  15. Spark plugs (14960 bytes)
    266: DENSO 16 is one heat range cooler than NGK 6 (same as NGK 5). This heat range was r...
  16. Ddgonzal's Sunny Truck (18606 bytes)
    96: ...n the central valley, it was so hot it was almost cooler to roll the windows back up. it was so hot when I...
  17. Water pump (9463 bytes)
    72: OP.COOLER [[Water_Pump_Part_Numbers#Truck|PART NUMBERS]]
  18. Fan belt (4281 bytes)
    51: {{SearchPart|11721-H7200}} BELT-FAN&ALTERNATOR (COOLER USE L=970 BANDO) 7804-8109
    52: {{SearchPart|11721-H7201}} BELT-FAN&ALTERNATOR (COOLER USE L=980 BANDO) 8110-
    54: {{SearchPart|11721-H7210}} BELT-FAN&ALTERNATOR (COOLER USE L=975 &#12511;&#12469;&#12508;&#12471;) 8504-
  19. Fan (5434 bytes)
    66: 21060-N0110 FAN-COOLING OP.COOLER 7804-8109 <x> 21060-G1210
    67: 21060-G1210 FAN-COOLING OP.COOLER 8110-
  20. 140Z (7545 bytes)
    92: 13 row oil cooler
Search in namespaces :
List redirects   Search for
