There is no page titled ":Emission". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Emission Controls (28473 bytes)
1: ...ower (in fact, they have more horsepower than pre-emissions cars). However, some of the early systems hurt e...
4: Nissan literature refers to three types of emission controls for the B110 model series:
5: * CRANK: Signifies all B110 with crankcase emission control device [PCV, etc]
6: ... B110 with crankcase emission control and exhaust emission control device
7: ...ontrol, exhaust emission control, and evaporative emission control device for CALIFORNIA in U.S.A. - Emission Control Part Numbers (4357 bytes)
4: [[Emission Controls]]
10: ...VALVE11810-A3500 ASS'Y-CONTROL, valve, crank case emission JAPAN
Page text matches
- Datsun 1200 encyclopedia (3415 bytes)
16: * [[:Category:Emission Control And Tune-Up|Emission Controls]] - Ignition Timing (9164 bytes)
148: ...of exceeding the maximum advance at high RPM. The emission controlled distributors have more mechanical adva... - Fuel pump pressure test (3334 bytes)
61: [[Category:Emission Control And Tune-Up]][[Category:Fuel System]]{{En... - Choke Cable (3495 bytes)
48: ... for [[Japan_Emissions#1200_Choke_Warning|E-level emission control]] - Emission Controls (28473 bytes)
7: ...ontrol, exhaust emission control, and evaporative emission control device for CALIFORNIA in U.S.A. - Weber 32/36 Carburetor (22579 bytes)
146: ...wl vent'''. Most have internal venting. Some have emission style venting which is connected to a charcoal [[... - Part Numbers Index (8259 bytes)
9: [[Emission Control Part Numbers|Emission Control]] - Pollution (252 bytes)
3: Air Pollution [[Emission Controls]] consists of three systems:
5: # EVAPO -- evaporative emissions. See:
7: # EXHAUST -- reduction of engine exhaust emissions. See: - Nissan Part Numbers (8833 bytes)
33: 005 EMISSION CONTROL DEVICE - A-series Cylinder Heads (27209 bytes)
62: ...ench" area thereby reducing NOx (nitrogen oxides) emissions.
127: ... high swirl (for better fuel economy and improved emissions). They are used with dished pistons for 8.5:1 in...
192: Sweden emissions head.
255: ...ck engine. Also used in Europe cars except Sweden emissions.
327: ...ere are many part numbers, which differ for year, emission control, accessory fittings, coolant passages, et... - Aftermarket intake manifold (6273 bytes)
61: Round port, pre-emission (no provision for PCV valve) for SU or Hitachi si... - Late-model Vacuum Advance (3498 bytes)
3: ... none are correct for performance -- they are all emission related. The curve can be adjusted. Just remember... - 56-Series Transmission (22662 bytes)
239: ... of the following, for the purpose of controlling emission gear on the engine: - Repair Manual (19444 bytes)
28: ...ic Library, which is even bigger and has Mitchell Emission Diagram books.
94: * 1971/1972 Emission: 20027
328: <br>* [[Emission_Controls#Temperature_Controlled_Air_Cleaner|Tempe...
360: * "Emission's Analysis, The Datsun Guide to Clean Air"
367: ...rvice Manual Datsun 1200 Model B110 Series Engine Emission Control" - Tune-up (10772 bytes)
89: [[Category:Emission Control And Tune-Up]] - Valve adjustment (7052 bytes)
112: [[Category:Emission Control And Tune-Up]] - Fume Control (12344 bytes)
1: ...escapes from a vehicle into the atmosphere (see [[Emission Controls]]). The Datsun 1200 used an early system...
15: ...00s (1980s models) use a return line to help with emissions.
52: ...important system. You want this. Yes, it controls emissions, but it also keeps the carburetor's fuel flow wo...
184: [[Category:Emission Control And Tune-Up]] - ADR (14718 bytes)
1: ...alia Design Rules''' (ADR) which cover safety and emission control standards. Your car from new should have ...
17: ...meets certain ADRs, thus is related to safety and emissions. It is not a manufacturer's plate. Even imports ...
110: 26 Engine emission control Jan 1972
111: 27 Engine emission control Jan 1974
112: 27A Engine emission control Jul 1976 - Hood (6706 bytes)
158: Vehicle Emission Control Information - Chassis numbers (12032 bytes)
31: L-: L-level [[Japan Emissions|emissions]] (1981 Oct - 1989 Oct)
253: {{Main|Emission Controls#Specifications}}
276: 1 1975-OCTOBER [[Japan_Emissions#H|"H" emission standards]]
279: ...8-1989|minor change]] and [[Japan_Emissions#E|"E" emission standards]]
282: 3 1979-AUGUST 1979 year exhaust emissions and vehicle type changed to B121
