There is no page titled ":Headlight". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Headlight Wiring (9105 bytes)
1: ... of the headlights or the high (MAIN) beam of the headlights.
3: Also see: [[Headlight Specifications]]
6: The headlights are grounded via the main wiring harness.
8: Completing the headlight features is the "High Beam" light in the instrume...
10: So the headlight circuit has these components: - Headlight Aiming (894 bytes)
1: For your [[Headlights|headlamps]] to work at full potential -- whether...
4: ...with tape at the same height as the center of the headlights.
9: Turn the [[Headlights#Adjusters|adjusting screws]] to adjust the beam ... - Headlight Part Numbers (4010 bytes)
2: [[Headlights]] - 620 Headlight Wiring (5044 bytes)
1: ...not use the [[510 Headlight Wiring|switched-earth headlight wiring]] system of the Datsun [[510]].
3: = 4-headlight system =
10: ...Fuse Box]], specifically the 'L' (lamp) fuse. The headlight switch provides power OUT when pulled to the 3rd ...
17: GROUND - headlight sockets are grounded at earth point
46: * SR311/SP311 Headlight Relay (Datsun Roadster) - 510 Headlight Wiring (4065 bytes)
1: Datsun [[510]] uses headlights that are always hot, but not connected to ground...
5: Headlights are not permanently grounded as in newer Datsuns
6: Headlights are permanently connected to HOT via the Fuse Bo...
9: One fuse powers both Headlights
11: 1969-1973 Dual-Fuse Headlight Circuit]
Page text matches
- Parts Sources (15979 bytes)
89: ...ttery]], [[Lighting System|headlights (standard 2-headlight units), dome lamp, dash lamps, turn-signal and pa... - Part Numbers Index (8259 bytes)
98: [[Headlight Part Numbers|Head Light]] - Wiring (8463 bytes)
78: = Headlights =
79: See [[Headlight Wiring]]
148: ...ere's the kinds of smaller lights (other than the headlights) that a Datsun 1200 uses. - Lamp Wiring (8404 bytes)
3: {{See|Headlight Wiring}}<br>
186: ... words, the Reverse light should work even if the headlights or running lights are off. - Songs (8924 bytes)
132: ...12504;ッドライト}} [Headlight by Kenji Shinuma, 1977] - Grille (9210 bytes)
10: [[#Coupe Grille]] (black headlight surrounds)
13: ...[#Mid-Model Truck|#1978-1989 Ute Grille]] (silver headlight surrounds)
16: [[#Square Headlight Truck|#Late Sunny Truck/Bakkie Grille]] (1989-200...
37: Black headlight surrounds: ([[#Coupe Grille|#coupe]])
40: Silver headlight surrounds: Mid [[#Mid-Model_Truck|#Pickup]] (1978... - B120 (15443 bytes)
125: ...acelift occurred: Sunny Truck changed to a square-headlight [[Grille]], NISSAN [[Badges]], and gray interior. - Lighting System (2956 bytes)
4: == Headlight Switch ==
15: headlights
31: = Headlights =
32: {{Main|Headlights}}
50: {{See|Headlights}} - Model names (18990 bytes)
72: ...ent engines are different trim (for example, four headlights for the Violet, but only two for the Sunny). In ...
288: * 1986-2002 260 EUR (square headlight) - Parts interchange (3718 bytes)
4: ...1985 that have a "two headlight" system (a single headlight on each side of the grille).
7: * [[Lights|Headlights]]: large round 12V type, any car - foreign or do...
25: * [[Headlights]] and other [[Lighting System|light bulbs]] - B310 (13642 bytes)
16: ...980-1982 Square Headlight model | 1978-1979 Round Headlight
97: ...ith round headlights. Late 1979 changed to square headlights.
126: Round headlight KOITO
130: Square headlight: bolts to headlight surround
163: * 1979 and early 1980 [[Model year]]: round headlights - Instruments and Controls (5794 bytes)
40: == Headlight Beam Indicator Light ==
93: ...ou push the turn signal lever switch forward, the headlight high beams will be turned on ... Pull the lever t...
96: * Knob in the 1st Position, NO HEADLIGHTS for US models
100: ...he light switch clearance lights, parking lights, headlights, taillights, license plate light and instrument ...
104: ..., tail, license, instrument panel lights and then headlight low beams. - Headlight Wiring (9105 bytes)
10: So the headlight circuit has these components: - Headlights (12167 bytes)
1: {{BackTo|Lighting_System|Headlights}}
3: ...-inch round sealed beam headlamp. 12V large round headlights from *any* car will fit circa 1956-1986.
8: * [[Headlight Aiming]]
9: * [[Headlight Wiring]]
10: * [[Lighting_System#Headlights|Lighting System]] for specifications - Wiring Diagram (7077 bytes)
16: * Headlight switch for Australia has two-position dimmer and ...
83: ...h. headlight feed changed to R (from RY) to match headlight switch. High beam out changed to RY from RW to ma... - Knuckle Arm (6390 bytes)
135: ALL round headlight except GX#,Wagon
136: S,K.A12A/A13 square headlight
139: GX# round headlight (OPTION)
140: S,K.A14/A15 square headlight
151: {{searchPart|40300-W8300}} S,K,W square headlight S/# {{searchPart|40300-W5700}} - Periodical Maintenance and Lubrication Schedule (3155 bytes)
72: * Check [[Headlight aiming]] - Measurements (5294 bytes)
30: * Headlight Centers width: 1125 mm
31: * Headlight Centers from ground, sedan: 660 mm (also van)
32: * Headlight Centers from ground, coupe: 665 mm - Chrome Trim (1561 bytes)
18: * [[Grille Surround|Headlight]] "eyebrow" surrounds - Rocker cover (9250 bytes)
82: Late A14 with front vent ([[B310]] round headlight models)
