Search results
For query "Injector"
There is no page titled ":Injector". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Fuel Injection (19607 bytes)
    26: * four fuel injectors
    61: ...luding high-pressure fuel pump, fuel distributor, injectors/throttle bodies and lines.
    141: ...$20 used, [http://www.extrudabody.com/servlet/the-Injectors/Categories $70 new])
    167: ...$20 used, [http://www.extrudabody.com/servlet/the-Injectors/Categories $70 new])
    182: ...CU and GM sensors. Or fitting Ford TBI with Bosch injectors and a GM brain.
  2. 200SX EFI (11723 bytes)
    8: ...y of the parts are available on the 280ZX such as injectors, sensors and fuel pump. See the EGI article for ...
    56: Fuel injector
    69: * Injector - usually included with used Manifold
    174: ...eously and independent of the engine stroke. Each injector supplies half the amount of fuel required by the ...
    190: Injector Wiring for the 1981 ECU:
  3. A-series Cylinder Heads (27209 bytes)
    529: * Oval Ports with ?notch for injector
  4. 1/4 mile time log (25722 bytes)
    909: * Injector:750cc
    1051: * 1600cc Injectors
    1102: * 12 x 1600cc Injectors - C16 Fuel
  5. EGI (26741 bytes)
    198: * has notches at the top for the injectors
    566: == Injectors ==
    567: See main article: [[Injectors#16603-N7616]]
    570: 16612-N8500 HOLDER-INJECTOR [lower] 7910- $6.33 USD
    571: * replaced 16612-N4200 HOLDER-INJECTOR -7909
  6. Carburetor Part Numbers (7751 bytes)
    29: 17 16171-25710 WEIGHT INJECTOR A12 CRANK
    108: 23 16171-25710 WEIGHT-INJECTOR A12 EXHAUST & EVAPO
  7. DCH Carburetor Part Numbers (7505 bytes)
    54: 28 16171-25710 WEIGHT-INJECTOR -672
    55: 28 16171-H7010 WEIGHT-INJECTOR 0772- 0 16171-25710
    143: 28 16171-25710 WEIGHT-INJECTOR -672
    144: 28 16171-H7010 WEIGHT-INJECTOR 0772- 0 16171-25710
  8. Fuel Part Numbers (24315 bytes)
    112: * 16171-25710 WEIGHT-INJECTOR 1 A12 EXHAUST & EVAPO -
    208: * 16171-25710 WEIGHT-INJECTOR 1 A12 -672 2
    209: * 16171-H7010 WEIGHT-INJECTOR 1 A12 0772- 0 16171-25710
    295: * 16171-25710 WEIGHT-INJECTOR 1 A12 -672 2
    296: * 16171-H7010 WEIGHT-INJECTOR 1 A12 0772- 0 16171-25710
  9. Hyundai EFI (3787 bytes)
    25: ...size all the way through but close up towards the injectors)
    50: ....com/catalog/x,carcode,1208045,parttype,6224 Fuel Injector]
  10. Raw List (34158 bytes)
    461: 16171-25710 WEIGHT INJECTOR
    823: 16171-25710 WEIGHT-INJECTOR
    919: 16171-25710 WEIGHT-INJECTOR
    920: 16171-H7010 WEIGHT-INJECTOR
    1006: 16171-25710 WEIGHT-INJECTOR
  11. MR.12.00 (3716 bytes)
    30: * Ford Falcon CFI throttle body (twin injector)
  12. Cylinder Head Part Numbers (24003 bytes)
    356: * Medium Oval Ports with notch for injector
  13. 14035 (3030 bytes)
    100: ...8x32 mm intake ports (medium oval) with notch for injector
  14. Zenith EFI (3807 bytes)
    1: ...buretor-replacement system for Nissan A15 engine (injector and fuel inlet at top)
    6: * 15 psi injector
    18: 2 GASOLINE INJECTOR (O-RINGS INCL.) C282-366
    19: 2A O-RING KIT (GASOLINE INJECTOR & FUEL PRESSURE REG.) C282-14
    45: * INJECTOR, GASOLINE (O-RING INCL.)
  15. EFI Manifold (5846 bytes)
    57: * Nissan RB30 injectors
    68: 35mm motor bike throttle bodies with injectors inbuilt
    100: ...75 Hilborn] injection manifold (A15 manifold with injector bosses welded on)
  16. Injectors (11277 bytes)
    3: = Injector Sizing =
    4: ...utput by boosting fuel pressure, for example some injectors might be safe at 70lbs pressure.
    11: With 4 injectors, they need to be 25 lbs/hr
    12: ...for 80% operation, you should get 30 lbs/hr rated injectors. If you are planning on raising power output lat...
    14: = High or Low Resistance Injectors? =
  17. EGI Wiring (5246 bytes)
    18: * Injectors
    30: * Injector outputs (4)
    127: = Injector Wiring =
    128: How the injectors are wired depends on the [[ECU]] you use. The fo...
    134: <br>{{Photo|200X_EFI_injectors.jpg|Datsun%201200/wiki/200sxEFI}}
  18. EGI MegaSquirt (4668 bytes)
    3: = Manifold and Injectors =
    10: * the fuel injectors included
    56: * injectors
    64: Obtain a dropping resistor pack, and connect to injectors
    96: * injector flow rate 188
  19. Nissan Optical CAS (7489 bytes)
    179: ...e donor Nissan. For spark-only control, leave the injector harness unplugged. Custom spark maps cab be progr...
  20. A14E Service Manual (12757 bytes)
    59: 7. Fuel injector
Search in namespaces :
List redirects   Search for
