Search results
For query "Pickups"
There is no page titled ":Pickups". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Engine Swaps (25633 bytes)
    156: ... inexpensive coming out of Nissan Navara/Hardbody pickups.
  2. Rear Axle Swaps (25587 bytes)
    413: ...atsun Roadsters, 1600 wagons, 320/520/620/720/D21 pickups and other Datsuns.
  3. Emission Controls (28473 bytes)
    137: ...ll USA models, and later Japan and Australia 1200 pickups were required to control the amount of gasoline v...
  4. Ignition Switch (13030 bytes)
    71: ... for USA 1200s, JDM GL and GX, and newer JDM 1200 pickups
  5. PB110 (13860 bytes)
    11: * There were no Excellent 2-dr sedans, wagons or pickups
  6. Datsun B10 (13387 bytes)
    99: ...f the heavy body-on-frame construction of the 320 pickups.
  7. Trayback Utes (2462 bytes)
    1: [[B120|Datsun 1200 pickups]] -- being [[Coupe Utility|Coupe Utilities]] (ute...
  8. B120 (15443 bytes)
    193: ...They are commonly called '''Camionetas''' (little pickups) and also nicknamed '''Picopita''' (micro pickup)...
    196: ...óviles de Ecuador) assembled CKD LHD Nissan 1200 Pickups in an in-country assembly plant from 1987-1999. T...
  9. Console (9655 bytes)
    12: * [[B120]] Pickups as standard equipment (except STD models)
  10. L-series Engine Swap (21326 bytes)
    231: ...B (610) sump is slightly more rearward. Sumps and pickups can be interchanged, but the blocks may need to b...
  11. Borg Warner Differential (6981 bytes)
    126: ...ng, about as strong as the [[H190]] in the Datsun pickups.
  12. Ddgonzal's Sunny Truck (18606 bytes)
    169: ...able]], so no clutch cylinder is needed. LHD 1200 pickups I expect will have a clutch cylinder system.
  13. Datsun History (23455 bytes)
    311: ...sun''' name used as a model name in Japan for D21 pickups (known as Navara or Harbody in other countries).
  14. Canby (11736 bytes)
    23: Along with Z-cars, wagons, Pickups and Roadsters, These Datsun Sunnys were spotted:
  15. KA Engine Swap (19582 bytes)
    1: ...ly available and inexpensive coming out of Nissan pickups and Nissan 240SX (USA silvia S13 & S14). It will ...
    144: * Nissan pickups: RWD
  16. Axle Shaft (14409 bytes)
    140: * Nissan D21,D21U,D22 Hardbody/Datsun pickups 1986-2000
  17. Sedan Grille (5928 bytes)
    3: ... fitted with a stainless metal grille. Early 1200 Pickups (1971-1977) use this too. The 1972 JDM [[Facelift...
  18. Finn JAE (4160 bytes)
    16: pickups, 1200s, B310, others
  19. Sales (876 bytes)
    31: = Pickups =
  20. Electric Fuel Pump (6998 bytes)
    29: Stock on newer Nissan Patrol and Datsun 720 pickups:
Search in namespaces :
List redirects   Search for
