Main : Members ca18det coupe almost finished
[<   Previous  790  791  792  793  794  795  796  Next   >]
ca18det coupe almost finishedPopular
SubmitterbluecoupeMore Photos from bluecoupe   Last Update2006/9/18 5:15    Tell a friendTell a friend
Hits2136  Comments6    0.00 (0 votes)0.00 (0 votes)
just got it back from exhaust shop full 3inch system
Turboute
Posted: 2006/9/18 7:14  Updated: 2006/9/18 7:14
 Re: ca18det coupe almost finished
The wheels look good.
bluecoupe
Posted: 2006/9/18 8:04  Updated: 2006/9/18 8:04
Not too shy to talk
yeah they arent to bad at all.There finally back on another blue 1200 lol..
BAD310
Posted: 2006/9/18 8:13  Updated: 2006/9/18 8:13
Is that an alloy drop tank I can see under there?
If so, what sort of pump/surge tank setup do you have.
Cheers Mitchell
bluecoupe
Posted: 2006/9/18 8:50  Updated: 2006/9/18 8:50
Not too shy to talk
certainly is no surge tank needed its all in the tank s13 setup in the tank
BAD310
Posted: 2006/9/18 9:18  Updated: 2006/9/18 9:18
Ahh thats music to my ears
I have a S15 sr20 in tank pump setup, that I was planning on putting in a drop tank.
Just a quick question if I may, how have you fixed the pump to the inside of the tank?
Did you use a gasket between the pump bracket and the tank or did you make up a new pump bracket out of alloy?
Also who made the tank for you?
Cheers Mitchell
bluecoupe
Posted: 2006/9/18 9:22  Updated: 2006/9/18 9:22
Not too shy to talk
we used the whole s13 pump unit with the fuel gauge sender on it and it bolts into the top of the tank easy as
BAD310
Posted: 2006/9/18 9:28  Updated: 2006/9/18 9:28
hmmm, maybe the S15 sr20 pump is a bit different, oh well.
Thanks anyway.
