Main : Misc boot
[<   Previous  3881  3882  3883  3884  3885  3886  3887  Next   >]
boot
bootPopular
Submittersikdatto1200More Photos from sikdatto1200   Last Update2006/10/18 11:50    Tell a friendTell a friend
Hits1794  Comments3    0.00 (0 votes)0.00 (0 votes)
surge tank/ fuel pump setup
mad120y
Posted: 2006/10/19 23:25  Updated: 2006/10/19 23:25
 Re: boot
Can i ask if there is any reason you put all the fuel gear on that side of the boot?
Anyway it looks like a good setup, what pumps and stuff are you using?
I must put my surge tank in some day :)
sikdatto1200
Posted: 2007/1/8 10:29  Updated: 2007/1/8 10:29
 Re: boot
yea my battery is on that side, keep the cable to one side! Its a forklift lift pump of all things 3.5v6, and vl turbo fuel pump, ive since added filter between surge and pump due to pump failure, cheers
Posted: 2007/1/9 17:05  Updated: 2007/1/9 17:05
 Re: boot
Failure ... most GM pumps are designed to run submerged in the fuel tank. Is this one designed to run dry (outside the tank)?
dattodude
Posted: 2007/1/9 20:40  Updated: 2007/1/9 20:40
 Re: boot
Yep, Commodore VL Turbos are external. Although I've long touted the overheating characteristics of these pumps in the Australian Summer. I recommend wiring in a switch and a ignition coil dropping resistor, to lower the voltage in summer traffic. Obviously running full 12v under power.
