Main : Mechanical I blew this up
[<   Previous  460  461  462  463  464  465  466  Next   >]
I blew this up
I blew this upPopular
SubmitterWALLYMore Photos from WALLY   Last Update2003/3/4 12:09    Tell a friendTell a friend
Hits11158  Comments19    0.00 (0 votes)0.00 (0 votes)
Read with supercharged article
D
Posted: 2003/3/6 13:38  Updated: 2003/3/6 13:38
From: under the Firmament LOL no twiglight effect BS
 Re: I blew this up
Wouldnt that farking gorgeous plenum have worked with a turbo rather than sc??
dimlight65
Posted: 2003/3/6 16:41  Updated: 2003/3/6 16:41
 Re: I blew this up
Wally, how bad was the plenum blown up?
D, it should work fine with either type since, technically, a turbocharger IS a supercharger. It just gets its drive from the exhaust rather than the crank.
YRL05S
Posted: 2003/3/7 1:26  Updated: 2003/3/7 1:26
 Re: I blew this up
What he means by blow off valve, is a purge (or overboost) valve. This is used in the event of a carby backfire or sudden increase of excessive boost(like a disconnected actuator hose). Similar to a blow off valve in design, usually vents externally. Is anyone familar with Jake Edwards' big single turbo yellow LH torana? As this features one directly on top of the plenum and is clearly visible. Backfires whether caused by leaning out or nitrous use have been know to split plenums like wallys, intercooler tanks and piping.
WALLY
Posted: 2003/3/7 8:15  Updated: 2003/3/7 8:15
 Re: I blew this up
We are in the process of setting up a turbo EFI on a race 1200 coupe
The S/S plenum split around front end weld I cut it up to use the flange plate on my current set up
stirlingmac
Posted: 2003/3/7 8:37  Updated: 2003/3/7 8:37
 Re: I blew this up
Even the V8 671 style blowers have an over boost valve it is usually a spring loaded cap/s in the blower manifold. While in a friends supercharged Torana a couple of weeks back he had a carb backfire and the blower stopped spinning so quick it snapped the end of the forged steel crank !! Pro Stock and Funny Car drag cars have sheet metal blow off plates in their manifolds to stop blowers flying off in backfire situations.
b310gx
Posted: 2003/3/7 12:04  Updated: 2003/3/7 12:04
 Re: I blew this up
yes,that's what i meant,an overboost blow off.all the supercharged open wheelers running the nsw hillclimb championships have them fitted,due to the needed to back off for corners.i know they aren't 'look at me,i've got a turbo' valves,but just a pressure relief valve to prevent damage to blowers & mainfolds.
b310gx
Posted: 2003/3/7 12:09  Updated: 2003/3/7 12:09
 Re: I blew this up
sorry,i used the wrong term to describe it,a valve or a burst panel was what i meant.all the supercharged hillclimb cars in the nsw hillclimb championship have these,as they all run billet superchargers,& manifolds.they don't want to break one of these,so they have valves to dump pressure.not one wants to be like john force.
dimlight65
Posted: 2003/3/7 15:15  Updated: 2003/3/7 15:15
 Re: I blew this up
I sit corrected. I had forgotten about the safety valves. They do however blow an air/fuel mixture out when the go off. I guess a small quickly extinguished engine bay fire is still cheaper than sending a Rootes type blower several hundred feet into the air!
WALLY
Posted: 2003/3/8 7:04  Updated: 2003/3/8 7:04
 Re: I blew this up
Tim It takes a man or a real 1200 nutter to admit to being stood corrected I like that
SLAM1024
Posted: 2003/12/22 1:14  Updated: 2003/12/22 1:14
 Re: I blew this up
Hey Dimlight,
I got the adaptor plate a few days ago, thanks for that man :) it looks good
Peace
SLAM1024
roddat
Posted: 2004/6/26 3:11  Updated: 2004/6/26 3:11
Not too shy to talk
 Re: I blew this up
ive got an L20 with twin 40 mm webbers aet up as blow through. on deaccaleration it used to hit 30 psi so i put a blow off valve on. it then blew off the blow off valve. i had to fit a switch on the accelerator peddle thas turned off the supercharger on deacceleration.
b310gx
Posted: 2003/3/5 11:34  Updated: 2003/3/5 11:34
 Re: I blew this up
needed a blowoff valve,& not one of those turbo whooshie things.
dimlight65
Posted: 2003/3/5 16:06  Updated: 2003/3/5 16:06
 Re: I blew this up
Yikes! You would NOT want a blowoff valve on a draw through system like this! That would vent air/fuel mixture into the engine bay!
As an aside, too bad about blowing that up, it is farking gorgeous!
WALLY
Posted: 2003/3/6 11:23  Updated: 2003/3/6 11:23
 Re: I blew this up
Tim don't fret I only blew the plenium up the rest is fine
WALLY
Posted: 2003/3/6 11:33  Updated: 2003/3/6 11:33
 Re: I blew this up
Paul DO NOT EVER fit a blow off valve or a turbo whooshie thing on a flow though set up or you will get more bang than you ever wanted.You wil be smokin at the wrong end
WALLY
Posted: 2003/3/4 12:15  Updated: 2003/3/4 12:15
 Re: I blew this up
This S/S plenium didnot work on the Wally Wagon I had a back fire and because of the amount of fuel sitting inside it split open.
The steam pipe one works better anyway.
See Content management for full article on the Wally Wagon
