Main : Misc ca18det 1200.
[<   Previous  3854  3855  3856  3857  3858  3859  3860  Next   >]
ca18det 1200.
ca18det 1200.Popular
Submitterworks1200More Photos from works1200   Last Update2006/10/23 22:15    Tell a friendTell a friend
Hits2017  Comments3    0.00 (0 votes)0.00 (0 votes)
fronts are 14x7 -9 with 165/65 bridgestone potenza's and the rears are 14x7.5 -7 with the same tire.
cheater_5
Posted: 2006/10/24 0:26  Updated: 2006/10/24 0:26
 Re: ca18det 1200.
holy poo on a stick thats hot. dish on a 1200 is the best investment. dam hot that is. whered you get the mags ?droooooooool
tappet
Posted: 2006/10/24 2:36  Updated: 2006/10/24 2:36
 Re: ca18det 1200.
nice... did someone say Stretch
go the 2door
i have never seen a street datto with that much camber...
What lower control arms are u using????
works1200
Posted: 2006/10/24 4:51  Updated: 2006/10/24 4:51
 Re: ca18det 1200.
you can get the front mags from konig here in the states.. they're called rewinds. i just had the lip polished because it was only machined before. they're $350 a set of four. the rears are longchamp xr4(got from a shop in the los angeles area and rare in this size).
i have normal 1200 lower control arms, but with Battle Version($135) negative camber roll center adjusters. i just had a machinest slot the ae86(85mm) holes to fit the narrower 1200 arm(74mm). rides great!
