Main : Mechanical : Suspension 4 link rear end
[<   Previous  469  470  471  472  473  474  475  Next   >]
4 link rear end
4 link rear endPopular
SubmitterstirlingmacMore Photos from stirlingmac   Last Update2003/3/13 1:52    Tell a friendTell a friend
Hits10654  Comments6    0.00 (0 votes)0.00 (0 votes)
This is the rear of my long term racecar project. The radius rods are hi tensile aluminium. Everything in the car I fabricated myself including the coilovers and the stainless exhaust. The rear crossmember has a bulkhead and all of this is visible thru the rear window.
MLS
Posted: 2006/8/16 9:51  Updated: 2006/8/16 9:51
 Re: 4 link rear end
Just noticed this pic, and I realise it is fairly old but how did the rear end go?
Just from what I can see it looks as though it would bind as it went through its range of motion.
Usually with a 4-bar system like you have pictured you don't need / want a torque link, alternatively when running a torque link the radius rods are usually mounting to a freely rotating 'bird-cage' on the diff.
stirlingmac
Posted: 2006/8/16 10:33  Updated: 2006/8/16 10:33
 Re: 4 link rear end
It works fine...the bottom A arm has a sliding bar inside a delrin bushed tube so there is no bind and the A arm only controls the sideways movement..good spotting though. I have used this style of A arm set up on many rear ends and it has been very successful.
MLS
Posted: 2006/8/17 12:04  Updated: 2006/8/17 12:04
 Re: 4 link rear end
Do you think you could post a shot of the 'A-arm' attachment to the bottom of the diff?
Is there any particular reason you didn't go for a panhard rod instead?
And, do you have any roll centre control with the setup you have?
stirlingmac
Posted: 2006/9/18 9:37  Updated: 2006/9/18 9:37
 Re: 4 link rear end
There is no roll centre adjustment as such. The centre off the rod end under the diff is the true roll centre. The design of the rollcage determined the rear end set up and there is nothing to mount a panhard rod to anyway. I got this idea from crawling under a Roush Mustang Trans Am car probably 15yrs ago, it was simple and light which was the design brief when I was building the car.
teretonga
Posted: 2003/10/25 11:04  Updated: 2003/10/25 11:04
 Re: 4 link rear end
Hi Stirling - impressive work. Is this in the LHD car?
datman
Posted: 2003/10/25 21:10  Updated: 2003/10/25 21:10
Not too shy to talk
 Re: 4 link rear end
yeah this is his lhd coupe running the 12a its even better when seen in real life!!You should see the engine bay!!!
Carl.
