Main : Misc dash2
[<   Previous  3686  3687  3688  3689  3690  3691  3692  Next   >]
dash2
dash2Popular
SubmitterutheremateMore Photos from utheremate   Last Update2006/12/10 9:37    Tell a friendTell a friend
Hits2498  Comments7    0.00 (0 votes)0.00 (0 votes)
with guages
ang94541
Posted: 2006/12/10 11:55  Updated: 2006/12/10 11:55
 Re: dash2
Very nice.
Can't wait to see how it looks finished.
Dodgeman
Posted: 2006/12/10 12:35  Updated: 2006/12/10 12:35
 Re: dash2
Good Lord, are you sure you have enough instruments there?
Are you trying to make the inside of your Cessna look like your 1200? Good job & very impressive, looking forward to seeing it all assembled.
A14force
Posted: 2006/12/10 15:38  Updated: 2006/12/10 15:38
 Re: dash2
WOW! How much did you spend on all those?
I'm part way through a custon instrument panel too. All I need is a big wad of cash to buy the instruments.
Lobster
Posted: 2006/12/11 8:11  Updated: 2006/12/11 8:11
 Re: dash2
Would you be able to list what the guages are?
I thought there was only 3 guages in the world
Speedo
Tacho
Fuel
Looks like you might have doubled up on those a few times
utheremate
Posted: 2006/12/11 8:14  Updated: 2006/12/11 8:14
 Re: dash2
the guages are 2,1\6"
fuel level,fuel pressure,air\fuel,oil pressure,oil temp,trans temp,diff temp,boost\vac,volts,water temp (at radiator),head temp, and the three on the way are pyrometer and two brake pressure (going to have a willwwod brake bias valve between the two brake pressures)
160mph speedo and 10k tacho are 3.3\8"
sunny
Posted: 2006/12/13 10:05  Updated: 2006/12/13 10:05
 Re: dash2
I think your missing the steering angle guage
when you get bored in traffic
all i have time to look at is shift light and oil pressure light - big red one.
dazzasute
Posted: 2006/12/13 10:20  Updated: 2006/12/13 10:20
 Re: dash2
you don't have one for traction either???
seriously tho, would you actually have time to look at all those while you are driving? It would be enough to memorise which gauge should be in which position when....
Nice work though, definately looks the part
short-coupe
Posted: 2006/12/13 10:55  Updated: 2006/12/13 10:55
 Re: dash2
are any mechanical gauges? or are they all electronic?
