Main : Mechanical camber tops
[<   Previous  393  394  395  396  397  398  399  Next   >]
camber tops
camber topsPopular
SubmitterTyrieMore Photos from Tyrie   Last Update2006/12/20 4:13    Tell a friendTell a friend
Hits4110  Comments9    0.00 (0 votes)0.00 (0 votes)
camber tops for 120Y
Tyrie
Posted: 2006/12/20 4:15  Updated: 2006/12/20 4:15
 Re: camber tops
I've been having a little fiddle but cant figure out how i would install these???
Can someone give me a rundown on how to put them in, and will they raise the front end?
cheers
Tyrie
Posted: 2006/12/21 6:56  Updated: 2006/12/21 6:56
 Re: camber tops
bump I'm sure someone knows how to install them
PIGDOG
Posted: 2006/12/21 7:40  Updated: 2006/12/21 7:40
 Re: camber tops
what are you having trouble with
just take the struts out
take the strut top off, and replace it with this
will also have to hammer the studs out of the old strut top and put them in these by the looks of it
would probably lower the front if anything, unless you have 1200 strut tops in already
Tyrie
Posted: 2006/12/21 7:53  Updated: 2006/12/21 7:53
 Re: camber tops
thanks dude, guess I wont be installing them then
PIGDOG
Posted: 2006/12/21 8:10  Updated: 2006/12/21 8:10
 Re: camber tops
why is that?
and ill take them if you have no use for them
dattodude
Posted: 2006/12/21 8:26  Updated: 2006/12/21 8:26
 Re: camber tops
You use 8mm bolts instead of the studs..but that's the easy bit.
Many adjustable strut tops expect you have fitted smaller diameter springs. You may also need to fit a 'half moon' part between the strut top and the spring cup, otherwise they bind up, and might cause something to break.
So it's not all beer and skittles..
Tyrie
Posted: 2006/12/21 8:38  Updated: 2006/12/21 8:38
 Re: camber tops
they were built for the car, and have been installed before, so I'd assume they will work.
I'm keeping them, its just I need higher springs first (car too low as it is)
PIGDOG
Posted: 2006/12/21 10:38  Updated: 2006/12/21 10:38
 Re: camber tops
just put them in and see if it does actually change the ride height first
you might have to make up spacers and stuff to make it all sit in there properly, and then have the same ride height
Tyrie
Posted: 2006/12/22 8:05  Updated: 2006/12/22 8:05
 Re: camber tops
I was only gonna put them in to raise it, I can get a bit of neg camber if i want by moving the LCA out, but yeah not too keen to do that
