Main : Mechanical : Drive Train Gearbox bearing numbers F5W60L
[<   Previous  596  597  598  599  600  601  602  Next   >]
Gearbox bearing numbers F5W60LPopular
SubmitterGrunterhunterMore Photos from Grunterhunter   Last Update2006/12/22 0:47    Tell a friendTell a friend
Hits2278  Comments1    0.00 (0 votes)0.00 (0 votes)
total came to $923 +GST for genuine parts. ouch.
b310gx
Posted: 2006/12/23 21:07  Updated: 2006/12/23 21:07
 Re: Gearbox bearing numbers F5W60L
get the old bearings & go to somebody like CBC Bearings or SKF,& they should be able to supply these for between $100 to $150. I've put new bearings in both types of 5 speeds over the years & if you can give them the numbers off the existing bearings,they have them in stock.this is one case where buying from Nissan is not economical. Where do you think nissan gets the bearings from, anyway ? it's a lot to pay for some pretty boxes.
Chassis_slappin_1200
Posted: 2006/12/22 22:26  Updated: 2006/12/22 22:26
From: whakatane, but most of the time canterbury NZ
I jus bought the main shaft bearing the counter shaft bearing and the tailshaft bearing for this same box from bay engineers (a local bearing supplier) for $60nz. and 1 of those bearings had to come from aussie.
I thought that was preety cheap.
