Main : Mechanical : Body and Interiors 1200 sedan cheap buy
[<   Previous  3699  3700  3701  3702  3703  3704  3705  Next   >]
1200 sedan cheap buyPopular
Submitterdatsun_guyMore Photos from datsun_guy   Last Update2007/1/24 22:49    Tell a friendTell a friend
Hits3310  Comments7    0.00 (0 votes)0.00 (0 votes)
the dato
Curtis
Posted: 2007/1/25 10:47  Updated: 2007/1/25 10:47
 Re: 1200 sedan cheap buy
yea 90cc head on a 160cc.was told by a mate that that they do fit but i never got round to getting one. he could be lying
banksy200b
Posted: 2007/1/25 11:15  Updated: 2007/1/25 11:15
Quite a regular
how much u lookin for 4 the car and where do u live
datsun_guy
Posted: 2007/1/25 11:44  Updated: 2007/1/25 11:44
its not for sale i got it cheap
Dodgeman
Posted: 2007/1/25 14:35  Updated: 2007/1/25 14:35
Of course, if you want to place an obstruction in front of your Datsun, you could power it with a mild improvement.
It's based on a late 1955 Victa lawnmower engine & runs a Tillotsen carb from a Silhl chainsaw. It has many more modifications than meet the eye & I built it for my Deckson minibike.
Or if you want something with a bit more pep.
This one is based on a 1957 or '58 Victa 'Special 18' lawnmower engine & runs dual Tillotsens with MASSIVE ports, a reed valve & the good old Sunday wake up call, a megaphone exhaust.
Both run Victa high comp race heads but this engine is the full on flat out, balls to the wall, grenade race engine.
When the mowing gets tough, the tough get mowing.
datsun_guy
Posted: 2007/1/25 23:17  Updated: 2007/1/25 23:17
that now has a touque converter on it and it hits 80kph at 5500rpm and it has a lighted flywheel as well with gen3 piston which is flat top in sted of dome
Dodgeman
Posted: 2007/1/26 8:34  Updated: 2007/1/26 8:34
Did you lighten the flywheels inside the crankcase [not a good move] or did you lighten the external flywheel?
The machined balancing holes in both my engines internal flywheels are filled with corks & then sealed with laquer to increase the crankcase compression.
There's not much you can do to reduce the weight of the early external flywheels without seriously weakening them & a flywheel explosion at high revs, that close to my family jewels is not a happy thought.
Do you have a torque converter, or do you mean a centrifugal clutch.
Curtis
Posted: 2007/1/25 10:19  Updated: 2007/1/25 10:19
get hold of one of the 90cc heads(gives more compression) and get a motobike carb(one of those pocket bicycle ones) and she'll fllllyyyy, goooo victa
datsun_guy
Posted: 2007/1/25 10:35  Updated: 2007/1/25 10:35
its a 160cc a 90cc head isnt gunna fit on it it has a motor cycle carb on it now and a power pipe its a very scary ride and an engine squish. sorry bout tthe pic its the only 1 i had of the car lol
sidedraught
Posted: 2007/1/25 0:16  Updated: 2007/1/25 0:16
A very interesting pic, you could have called it lot of things, so I am surprised that you chose "The Datto" as the description, maybe "the bike" would have been more appropriate.
