Main : Misc Toyota k40 gearbox swap... the hard way.
[<   Previous  3396  3397  3398  3399  3400  3401  3402  Next   >]
Toyota k40 gearbox swap... the hard way.Popular
Submitter3RotorMore Photos from 3Rotor   Last Update2007/2/6 4:41    Tell a friendTell a friend
Hits5912  Comments1    0.00 (0 votes)0.00 (0 votes)
LAGWAGON
Posted: 2007/2/6 23:34  Updated: 2007/2/6 23:34
 Re: Toyota k40 gearbox swap... the hard way.
mate what the heck are you doing? is that gonna work???
akinaspeedstar
Posted: 2007/2/7 0:15  Updated: 2007/2/7 0:15
that should work, just it ill be fairly difficult..
i would go a k50 personaly for better fuel economy.. but k40's are even cheaper and should stand up alright to most driving behind a datto motor..
3Rotor
Posted: 2007/2/7 1:36  Updated: 2007/2/7 1:36
Considering that this is the very first time I tried this, I have to say, it's a helova lot easier than I thought it would be, I imagined myself a hole lot of trouble with it, but not at all, was very easy, so far.....
Indeed the K50 would have gone over much nicer, but I had this one already and the ute need to get running ASAP. hopefully if I'm lucky.... the k50's internals will fit into an K40 casing, since they are identical from the outside.... I'll have to investigate.... then I might later on get an K50, and just change out the internals..... then again I'm never that lucky
here is the std Toyota T-bearing, much smaller than required for the Nissan P-Plate. Problem is that the 2 bearings are not the same diameter on the inside, so had to make a plan. Now it's all good and ready.
