Main : Members : GreaseMonky GX Head
[<   Previous  2  3  4  5  6  7  8  Next   >]
GX Head
GX HeadPopular
SubmitterGreaseMonkyMore Photos from GreaseMonky   Last Update2007/2/28 14:55    Tell a friendTell a friend
Hits3100  Comments4    0.00 (0 votes)0.00 (0 votes)
Her is a pic of the head
Posted: 2007/2/28 15:18  Updated: 2007/2/28 15:18
 Re: GX Head
Ah:
* large oval ports to go up as high as the top of the manifold bolt holes (A14 heads have oval ports, but they don't go up that high)
* Large twin coolant holes below the intake port (A14 heads have small holes)
For more details, see: A12GX Engine
GreaseMonky
Posted: 2007/2/28 15:24  Updated: 2007/2/28 15:24
 Re: GX Head
is there any way to tell if its a gx bottom end also like some numbers on the block?
Posted: 2007/3/1 1:09  Updated: 2007/3/1 1:09
 Re: GX Head
no, as far as we can tell the bottom end is the same as a standard A12 except for two things:
1. GX camshaft
2. Some GX engines had flat-top pistons, others did not
See: A12 GX Engine
Dodgeman
Posted: 2007/3/1 3:35  Updated: 2007/3/1 3:35
 Re: GX Head
Au contraire. The GX engine came with the dual Hitachi's that wa all know & love, & the manifold was water heated. This meant that there was a fitting & a coolant hose at the front of the manifold that allowed the coolant to pass into the water pump intake pipe. This is the large pipe at the front of the engine that has the lower radiator hose on it.
The 1200 pipe was plain, with no additional fittings, but the GX pipe had a single fitting that pointed sort-of upwards to receive this hose from the manifold.
Edit.
Oops, if I had clicked on your link & read the Wikipedia, I would have known thet this piece of info was already included.
Sorry
