Main : Mechanical : Body and Interiors 1000 turbo project car front-1
[<   Previous  3884  3885  3886  3887  3888  3889  3890  Next   >]
1000 turbo project car front-1Popular
SubmitterTopgearMore Photos from Topgear   Last Update2007/3/8 1:32    Tell a friendTell a friend
Hits2683  Comments6    0.00 (0 votes)0.00 (0 votes)
Burke_a_lot
Posted: 2007/3/8 14:32  Updated: 2007/3/8 14:32
 Re: 1000 turbo project car front-1
best of luck
Dundee1000
Posted: 2007/3/8 15:54  Updated: 2007/3/8 15:54
4 coupes at my place.. pitty they are all getting pretty sad now.. :(
Dodgeman
Posted: 2007/3/8 2:20  Updated: 2007/3/8 2:20
Oooooh, another 1970 KB10, good score, & it's red too. We can see just how good the original red can look when we look at Mopar's red rocket.
If you do as good a job on this as you did on the H165 LSD's, then this one's already a winner.
If you plan to end up with a boostrd engine, might I suggest that you start with a 1200 engine instead of the A10.
The little A10 is a good design, but if it ends up boosted, then I suspect that the three main bearings might not hold up so well as the five main bearings in the 1200 will. Also, the short 59mm stroke of the A10, particularly a stock A10, means that it will be down on torque compared to the stock 1200 engine, & with the Coupe being the heavyweight of the B10 range, you will very likely find that it will need to rev a bit more to keep it bubbling along.
Although, if you can get reliability & 70kw atw from your previous car, then perhaps I don't give the A10 enough credit.
With the appeal of being a direct drop-in, into the B10 chassis, I regard the 1200 engine as the substitute 'standard replacement' engine.
TnPshow
Posted: 2007/3/8 14:18  Updated: 2007/3/8 14:18
Nice - Glad I'm not the only one with more than 1 KB10
Can we see some pics of your track car too?
beattie
Posted: 2007/3/8 1:48  Updated: 2007/3/8 1:48
ohh she looks a bit rough! What did you pay for this fine peice of motor engineering? Also what gearbox/diff combo are you looking at using so i can copy?
Topgear
Posted: 2007/3/8 1:54  Updated: 2007/3/8 1:54
Ill start with std and see what happens from there...
I know they probably wont last if treated badly, but had the std items last on my 70wk atw turbo 1000 previously...
