Main : Misc drag ute build
[<   Previous  3179  3180  3181  3182  3183  3184  3185  Next   >]
drag ute build
drag ute buildPopular
SubmitterIAMDVSMore Photos from IAMDVS   Last Update2007/3/24 3:01    Tell a friendTell a friend
Hits3567  Comments20    0.00 (0 votes)0.00 (0 votes)
another view
benddatsun
Posted: 2007/3/25 20:12  Updated: 2007/3/25 20:12
 Re: drag ute build
Those are some nice flares, how wide of wheel? I rode in a zed that has 14"wide wheels out back and 10s up front one sic ride.
IAMDVS
Posted: 2007/3/28 15:46  Updated: 2007/3/28 15:46
Quite a regular
 Re: drag ute build
18' by 8.5 front and 18 by 9.5 on the back.
hmmm might go wider now ;)
dattodevil
Posted: 2007/4/18 20:41  Updated: 2007/4/18 20:41
 Re: drag ute build
Looks like you've done a bit of work since I last seen it.
12OOU
Posted: 2007/4/19 1:46  Updated: 2007/4/19 1:46
 Re: drag ute build
looks to me as this would be better suited to circuit racing or something, over drag. For starters i dont think ive seen a drag car with 9" wide fronts, more often there about 4". Plus having such a wide track is no advantage when racing in a straight line, reducing the length of the diff and rotational parts and bringing the wheels (same size even) inwards and tubbing would have been more beneficial. Each to their own though i guess. I'll give u credit, it is different but. What engine are u planing on running?
blackhowler
Posted: 2007/4/19 2:41  Updated: 2007/4/19 2:41
 Re: drag ute build
that is a nice car!!! something different~
looks hot!
IAMDVS
Posted: 2007/4/19 6:10  Updated: 2007/4/19 6:10
Quite a regular
 Re: drag ute build
bit of change of heart was going to be mainly drag but now going to see if it can go on the road.
motor wise either rotor or sr might go mad amd go v8
Mitch_photog
Posted: 2008/3/13 0:55  Updated: 2008/3/13 0:55
 Re: drag ute build
seriously think its a bit to phatttt... but my look better when its got the paint on the front...
Burke_a_lot
Posted: 2008/3/13 3:47  Updated: 2008/3/13 3:47
 Re: drag ute build
it's the humvee of dattos anyway it looks mad can't wait to see this on the track..... or where ever it going!
IAMDVS
Posted: 2008/3/13 21:10  Updated: 2008/3/13 21:10
Quite a regular
 Re: drag ute build
sorry to say this ute has gone to the great car yard in the sky. only the running gear and other small bit where saved.
now have a new body that i am working on
Mitch_photog
Posted: 2008/3/13 21:40  Updated: 2008/3/13 21:40
 Re: drag ute build
Why? you have put in so much work? now your going to cut up more parts? and put in the same work?
IAMDVS
Posted: 2008/3/13 23:25  Updated: 2008/3/13 23:25
Quite a regular
 Re: drag ute build
lot's of tin worm , it looks good but was twisted in more than on dir. New body has tin worm but straight as and as shown in new photos changing flares for more tire travel and making sit lower to the ground
Mitch_photog
Posted: 2008/3/13 23:47  Updated: 2008/3/13 23:47
 Re: drag ute build
whats tin worm?
Cable_Tie
Posted: 2008/3/13 23:49  Updated: 2008/3/13 23:49
 Re: drag ute build
Metal Cancer - Rust. . .
IAMDVS
Posted: 2008/3/14 1:35  Updated: 2008/3/14 1:35
Quite a regular
 Re: drag ute build
thats the stuff. The only thing holding it together was the bog and roll cage
Mitch_photog
Posted: 2008/3/14 2:05  Updated: 2008/3/14 2:05
 Re: drag ute build
thought thats what you meant, just never herd it called that before...
Burke_a_lot
Posted: 2007/3/24 19:01  Updated: 2007/3/24 19:01
 Re: drag ute build
that's fri##in mad!
rb20
Posted: 2007/3/24 3:35  Updated: 2007/3/24 3:35
 Re: drag ute build
holey sh#@ baby got some track
PIGDOG
Posted: 2007/3/24 3:48  Updated: 2007/3/24 3:48
 Re: drag ute build
being that wide you would think it would be more of a corners car
pepper
Posted: 2007/3/24 3:49  Updated: 2007/3/24 3:49
 Re: drag ute build
now they are flares!
matty
Posted: 2007/3/24 5:52  Updated: 2007/3/24 5:52
 Re: drag ute build
I've been wondering for awhile why no-one was using a long bed chassis as a base for a drag car. It makes so much more sense.
Who did the flares?
Matty
killer1200
Posted: 2007/3/24 12:10  Updated: 2007/3/24 12:10
 Re: drag ute build
Got flares.
tens_and_twenties
Posted: 2007/3/24 18:15  Updated: 2007/3/24 18:15
 Re: drag ute build
Those look like Skyline wheels. Maybe it has an all Skyline suspension???
IAMDVS
Posted: 2007/3/25 15:23  Updated: 2007/3/25 15:23
Quite a regular
 Re: drag ute build
no only the rear end is skyline front end is tube frame with blue bird struts which are going to tip.
the flares on the back are going to be changing and going to have wider wheels.
