Main : Members 120y
[<   Previous  688  689  690  691  692  693  694  Next   >]
120y
120yPopular
Submitterdatgirl1200More Photos from datgirl1200   Last Update2007/3/31 16:45    Tell a friendTell a friend
Hits1945  Comments5    0.00 (0 votes)0.00 (0 votes)
just bought this
datgirl1200
Posted: 2007/3/31 16:57  Updated: 2007/3/31 16:57
Quite a regular
 Re: 120y
just got this home today. I want to put front end, motor and gearbox in 1200 because of the disc brake front. motor is good and I need it in mine, the cross member is different to the 1200, does anyone know if there is anything else that will stop this from happening fairly easily?
shirley
Posted: 2007/3/31 18:05  Updated: 2007/3/31 18:05
 Re: 120y
Hi Datgirl, Sorry I can't help with your front end enquiry . However I'd be interested in the remains of your 120y after you have finished. Cheers
Anonymous
Posted: 2007/4/1 2:02  Updated: 2007/4/1 2:02
 Re: 120y
We have a Dat Chick, Welcome
Good luck with your wonder Y
datgirl1200
Posted: 2007/4/1 3:16  Updated: 2007/4/1 3:16
Quite a regular
 Re: 120y
thanx gixxer!
However the y is purely a parts car!!!
Team_Dat
Posted: 2007/4/1 10:53  Updated: 2007/4/1 10:53
 Re: 120y
you don't need the 120Y crossmember in there, just the struts from memory.
the engine should just slot in. if it doesn't use the passenger side mount that bolts to your current engine block and put it on the new block, and she should be sweet.
Mildman
Posted: 2007/4/1 13:32  Updated: 2007/4/1 13:32
 Re: 120y
You'll find that the newer 120Y engine wont line up on the mounts of the 1200 crossmember.
A little mucking around, well detailed in this article.
http://datsun1200.com/modules/nsections/index.php?op=viewarticle&artid=13
Good luck!
Datto7
Posted: 2007/4/1 15:36  Updated: 2007/4/1 15:36
 Re: 120y
Put the front sway bar on your ute too.
