[< Previous 464 465 466 467 468 469 470 Next >]
Radius Rods
angrywabbit 2003/4/27 13:59 Tell a friend
5144 4 0.00 (0 votes)
| A better shot of the modified Falcon radius rod. Top is the final rod, middle is standard 1200 and the bottom is standard Falcon with one hole welded. |
| Poster |
Thread |
| ddgonzal |
Posted: 2003/4/27 18:26 Updated: 2003/4/27 18:26 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: Radius Rods Looks like a good mod. Weld one hole, cut the shape, drill two new holes. What series of Falcon is this from?
Is their an advantage to this over using the B210 (120Y) rods, which are longer than the 1200 and bolt right in? The thread portion of the shaft is bigger with the Ford rods.
| Poster |
Thread |
| angrywabbit |
Posted: 2003/5/1 14:21 Updated: 2003/5/1 14:21 |
Just popping in   Joined: 2003/3/28 From: Brisbane Posts: 18 |
 Re: Radius Rods Any Falcon from XA to XF. The advantage is a bigger diameter right through including thread (the weakest point) as well as being adjustable.
| Poster |
Thread |
| Tommy |
Posted: 2005/8/19 8:31 Updated: 2005/8/19 8:31 |
Home away from home   Joined: 2003/7/4 From: Wamboin near ACT(canberra) Posts: 878 |
 Re: Radius Rods is it just me or does the top and middle rods look similiar???, the top 1 is a 120y rod and middle is a standard rod. the holes seem 2 line up im just worried about the diamitar of the thread at the top. does anybody know 4 sure if the 120y rods fit on 2 a 1200 ute and can and function fine???
| Poster |
Thread |
| dattodevil |
Posted: 2005/8/19 9:37 Updated: 2005/8/19 9:37 |
No life (a.k.a. DattoMaster)   Joined: 2004/1/20 From: Christchurch. NZ Posts: 1382 |
 Re: Radius Rods I think you'll find that the top rod is the finished product, after modification is finished on the lower one.
