Main : Misc Wiring hell...
[<   Previous  2985  2986  2987  2988  2989  2990  2991  Next   >]
Wiring hell...
Wiring hell...Popular
SubmitterkululadotgroenMore Photos from kululadotgroen   Last Update2007/5/1 14:37    Tell a friendTell a friend
Hits2077  Comments5    0.00 (0 votes)0.00 (0 votes)
Not really of the top of my head it takes about 7 wires to run the entire engine, that's including fueling, timing, air and water temp. I you have everything like wires and plugs handy, it shouldn't take you more than 2 hours to hook up.
baasw
Posted: 2007/5/28 13:54  Updated: 2007/5/28 13:54
 Re: Wiring hell...
im looking for the same datsun as youres but the 2 door just a roling chasiss with papers if u can help me email me
kululadotgroen
Posted: 2007/5/28 14:31  Updated: 2007/5/28 14:31
 Re: Wiring hell...
Nah, at the time this pic was taken, the old harness was sorted already, just needed a bit of tender loving care. This just referred to the wiring of the Dicktator into the old harness. Car is running now, and wiring working like a charm. I studied electical engineering up to N3, not that it says anything about ones abilities to do wiring... As they say, if it ain't broken, don't try to fix it...
I'm unsure if you are referring to the Coup
kululadotgroen
Posted: 2007/5/1 14:45  Updated: 2007/5/1 14:45
 Re: Wiring hell...
O, that's for the Dicktator management system. It can be found here Dicktator. The entry model like I'm using, does it's timing via the VW TP100 module. The dizzy has been retrofitted with a clover and VW hallsender, and uses a conventional coil. The more upscale models can do 60-2 and 36-1.
Don't think that the entry model doesn't make big horses, it's timing is just easier, or should I say more conventional, and if something gives up the ghost, the parts are easier to source. I'm sure an A series dizzy could be fitted with a hallsender, and then make use of this management for injection.
Burke_a_lot
Posted: 2007/5/2 21:16  Updated: 2007/5/2 21:16
 Re: Wiring hell...
Been there done that!
baasw
Posted: 2007/5/28 13:49  Updated: 2007/5/28 13:49
 Re: Wiring hell...
hey im from the east rand za did u think of rewireing youre car talk to me im a auto elec
