Main : Members : 2QK4U my 1200SR build
[<   Previous  8  9  10  11  12  13  14  Next   >]
my 1200SR build
my 1200SR buildPopular
Submitter2QK4UMore Photos from 2QK4U   Last Update2007/5/16 18:03    Tell a friendTell a friend
Hits2877  Comments8    0.00 (0 votes)0.00 (0 votes)
120Y struts with SR20 turbo brakes
LAGWAGON
Posted: 2007/5/17 13:38  Updated: 2007/5/17 13:38
 Re: my 1200SR build
mate you are going to have to take off that paint from the disk face, otherwise you'll have a few more months of re detailing
2QK4U
Posted: 2007/5/18 4:48  Updated: 2007/5/18 4:48
 Re: my 1200SR build
wont it just come off the first time i step on the brakes?
cheater_5
Posted: 2007/5/17 9:07  Updated: 2007/5/17 9:07
 Re: my 1200SR build
bump
cheater_5
Posted: 2007/5/17 1:14  Updated: 2007/5/17 1:14
 Re: my 1200SR build
looks really good. got any photos of them apart? find theconversion easy ?
BAD310
Posted: 2007/5/17 3:27  Updated: 2007/5/17 3:27
 Re: my 1200SR build
They look great Pierre, what spring rate have you used, to support the SR?
converted
Posted: 2007/5/17 11:10  Updated: 2007/5/17 11:10
 Re: my 1200SR build
blue painted disc faces???
PIGDOG
Posted: 2007/5/17 11:17  Updated: 2007/5/17 11:17
 Re: my 1200SR build
yeah that paint will make the first few stop interesting... might need to clean the pads after the first run
2QK4U
Posted: 2007/5/17 12:25  Updated: 2007/5/17 12:25
 Re: my 1200SR build
yeah nah im guessing the paint will come straight off regardes spring rates... i think kev mentioned 180lbs is suitable, luckily the springs i already had in mine suited the weight well so i didnt change them.
2QK4U
Posted: 2007/5/17 12:28  Updated: 2007/5/17 12:28
 Re: my 1200SR build
and regards the conversion kev rowley did it for me. but besides that its not a rocket science thing to do. the hub is machined down to suit the silvia disc, adds six mill 3mm each side to my track width. difficult to find wheels witht hte right offset, in supalites i need 20+ offset. the calpiper sits a fair bit out from the hub face on the disk. ill try find some more pics for you.
bobs1200
Posted: 2007/5/18 5:27  Updated: 2007/5/18 5:27
 Re: my 1200SR build
need to clean the paint before off rotor faces before running the paint wiil bake into the pours of the pads and have very erratic braking and brake pull I recomend to hve the rotors surfaced easyiest way to clean without running the rest of the paint also if paint isn't high temp in willburn after the brakes get hot
