[< Previous 658 659 660 661 662 663 664 Next >]
diff2
shirley 2007/5/31 23:51 Tell a friend
2464 3 0.00 (0 votes)
| Progress on diff center removal. The center was quite easy to tap out with a small lever and hammer. Now only the nut on the flange to remove. So far so good. |
| Poster |
Thread |
| oan878 |
Posted: 2007/6/1 8:41 Updated: 2007/6/1 8:41 |
No life (a.k.a. DattoMaster)   Joined: 2005/8/26 From: Posts: 1877 |
 Re: diff2 wouldn't it have been easyer to remove the net 1st?
| Poster |
Thread |
| PIGDOG |
Posted: 2007/6/1 8:56 Updated: 2007/6/1 8:56 |
No life (a.k.a. DattoMaster)   Joined: 2004/10/28 From: Geelong, Vic Posts: 6184 |
 Re: diff2 yes now that the diffs apart he finds out that its easier to get the pinion nut off with the diff still together...unless he has a rattle gun
| Poster |
Thread |
| ddgonzal |
Posted: 2011/11/10 4:25 Updated: 2011/11/10 4:26 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31851 |
 Re: diff2 I found it was tricky... but easy with a 16" pipe wrench to hold the flange, and a socket on a 16" breaker bar to remove the nut. Did two in a row, fairly easy.
